Bandit indicator issues
timboellis
PostPosted: 12:44 - 01 May 2012    Post subject: Bandit indicator issues Reply with quote
I have been having a recent issue with the indicators(non LED) they will work but very very slow occasionally not at all, with bike running and without bike running.proven bulbs are all okay , switchgear all working okay, battery fine, the only thing left I can think of is the wiring/earth or the relay.
However if the relay was faulty is the the case it will ether work or not or not at all and would it be worth just getting one to try?
I put an avo meter on the connections going to the relay and idicators off no power and indicators on gives me 12-13v so can i take from that, that the relay is suffed or could this still be a wring issue?
Also when i rev over 4k the indicators when working blink even slower.
If i connect the 2 connectors together without going to the relay then when i switch them on they should be constant?
Any other suggestions?
My only
jimmyjaffa
PostPosted: 13:03 - 01 May 2012    Post subject: Reply with quote
If you join the two connections together you should get them on constant when you switch the indicators on, bang a relay on as it's more than likley that.
timboellis
PostPosted: 13:05 - 01 May 2012    Post subject: Reply with quote
Thanks I have ordered a new relay to test, however will try joining them together to try , did not want to do that incase i fused it as not a clue about electrics
timboellis
PostPosted: 18:09 - 05 May 2012    Post subject: Reply with quote
New relay fixed the issue
The last post was made 14 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.38 - MySQL Queries: 13 - Page Size: 39.24 Kb
