Honda Ns125 Micron Exhaust Help!
Ns-125R
PostPosted: 15:39 - 01 May 2012    Post subject: Honda Ns125 Micron Exhaust Help! Reply with quote
Hi, i have just bought a 1988 Ns125 which came with a new micron exhaust, the previous owner has put some bigger jets in to run the engine lean for the running in process as it has just had a full top and bottom end rebuild, i picked it up yestoday and it started with one kick everytime, i took it round the block and everything was fine, all the gears there smooth clutch and all that lot, it was pretty warm here yestoday and i come to start it this morning (cold and windy) and it fired up but cut out a few seconds later (hadn't turned the petrol tap on) and now it wont start, i did a compression test and its reaching 90psi the plug was pretty black (assuming this is oil?) so i cleaned it and still nothing does anyone have any ideas? could it be the jets? what size do i need with a micron exhaust? thanks john.
thomp1983
PostPosted: 15:43 - 01 May 2012    Post subject: Reply with quote
my old ns125rk ran fine on the stock jets with a micron can so id suggest going back to stock and working from there. as for the non starting, have you checked your definitely getting a spark, adn secondly have you tried bump starting it?
chris
Ns-125R
PostPosted: 15:57 - 01 May 2012    Post subject: Reply with quote
okay ill have to look into the jets abit more, and could this be a reason its not starting? and ill check i have a good spark i havnt tried bumping it i shall try that aswell, thanks john
Ns-125R
PostPosted: 16:17 - 01 May 2012    Post subject: Reply with quote
Took the plug out, cleaned off the carbon and she come to life, need to look into the jets, do you know what the standard jet size is for this bike and if i did need bigger ones which ones would suit the exhaust? thanks john
thomp1983
PostPosted: 17:03 - 01 May 2012    Post subject: Reply with quote
i couldn't tell you unfortunately i haven't had my nsr for a couple of years now and i sold the haynes manual with it. the stock size jets will be fine with the exhaust though, i ran mine for the best part of a year like that
chris
Ns-125R
PostPosted: 17:15 - 01 May 2012    Post subject: Reply with quote
no problem Smile thanks for your help ill have a look into it and get my hands on a manual, thanks john
The last post was made 14 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.57 - MySQL Queries: 15 - Page Size: 47.07 Kb
