R6 JUST WENT DEAD(electrics)
R6 Wilson123
PostPosted: 18:20 - 01 May 2012    Post subject: R6 JUST WENT DEAD(electrics) Reply with quote
Went to start up my '03-05 R6 last night, never had any problems whatsoever with it
Turned the key as normal, it was halfway through the bleeeeeep noise that it usually makes when it just stopped dead. Everything went off like I'd just chopped a wire in half and then it failed to turn on again
Similar to what I believe would happen if the fuse blew
Now it won't start and I don't know what to do
I tried to bump start it but with no luck
Please help
Skudd
PostPosted: 18:29 - 01 May 2012    Post subject: Reply with quote
Check a fuse.
R6 Wilson123
PostPosted: 18:31 - 01 May 2012    Post subject: Reply with quote
Cheers. Everyone seems to think it's a fuse
How would I go about doing that? Anyone know what fuse it requires? Big job or easy change?
R6 Wilson123
PostPosted: 18:38 - 01 May 2012    Post subject: Reply with quote
https://www.ebay.co.uk/itm/SPARE-BLADE-FUSE-fuses-YAMAHA-600cc-YZF-R6-/250796153064?pt=UK_Motorcycle_Parts&hash=item3a649d98e8#ht_3196wt_1344
Anyone know if that'll do as a replacement?
McJamweasel
BCF Junkie
PostPosted: 19:07 - 01 May 2012    Post subject: Reply with quote
1) Find fusebox.
2) Remove the first fuse.
3) Check the fuse that's in your fingers.
4) If popped, replace with appropriatly sized new fuse.
5) If fuse not popped, replace and return to 2).
McJamweasel
BCF Junkie
PostPosted: 19:08 - 01 May 2012    Post subject: Reply with quote
And slightly less sarcastically, if all electrics are dead check the main power fuse which is often seperate to the fusebox. They're generally 30 or 40A.
Budgetboy
PostPosted: 19:50 - 01 May 2012    Post subject: Reply with quote
Faulty alarm cutting power, as in like theft..
Check this first. Thumbs Up
www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken.
R6 Wilson123
PostPosted: 20:17 - 01 May 2012    Post subject: Reply with quote
Just had a look and the metal connector that connects the wire to the battery had snapped, no idea how as it's thick as anything.. fixed now though
Cheers all
Skudd
PostPosted: 20:31 - 01 May 2012    Post subject: Reply with quote
Cheers all
That could be the cause, but check that the tyres are at the correct presure.
The last post was made 14 years, 142 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 58.79 Kb
