NSR125 full rebuild?
skatefreak
PostPosted: 10:30 - 02 May 2012    Post subject: NSR125 full rebuild? Reply with quote
Afternoon all,
So I have the engine apart,
as expected the crank bearings were buggered (engine was left in a bin bag in a garden for umpteen years thus rusted/weathered, not run to buggery) so new bearings and seals in the post.
I got a second hand crank mighty cheap off a friend and it's pretty tight (lateral play on crank/con bearing) and the gearbox/clutch is in fantastic condition (all parts miles from limits and almost no sign on wear).
Sooo, I was wondering aside from a piston kit, spit shine the cylinder/carb/exhaust, and carbon reeds, is there anything else I should do whilst I'm in there? Am I missing anything?
I'm not looking to invest a huge amount as the engine coming out will be rebuilt as well but I would like to sell one of the engines in the near future and want to be sure its going to last Smile
Any thoughts would be much appreciated.
Best regards
-Jvr
skatefreak
PostPosted: 12:14 - 02 May 2012    Post subject: Reply with quote
Any idea how much it would be to get the crank checked/balanced?
Will look into doing it myself but it certainly may be worth looking to get it done!
Much appreciation for the suggestion.
Best regards
-Jvr
skatefreak
PostPosted: 13:13 - 02 May 2012    Post subject: Reply with quote
Cool,
will get onto that.
Conrod play was miles less than the old one and seemed to be within tolerances by eye, will look into checking that closer though.
The run out I have no way of checking accurately to be fair. Will have a call around and see.
Best regards
-Jvr
skatefreak
PostPosted: 18:21 - 04 May 2012    Post subject: Reply with quote
Right,
Crank runout and con rod play are within limits, new bearings and seals going in for the crank shaft.
All the other bearings seem silky smooth, seals seem fine, clutch & gearbox components are well within limits according to the manual...
Is there anything else I should be worrying about for the bottom end?
If not, will get her back together over the weekend Smile
Best regards
-Jvr
skatefreak
PostPosted: 18:45 - 04 May 2012    Post subject: Reply with quote
Workshop manual to hand - check.
Have checked and cleaned off all traces of gasket from all mating surfaces, thoroughly cleaned them and have a complete gasket kit for the engine!
The majority of the surface between the halves is absolutely fine however there are a few *dips* at some outer extremities, behind mounting holes if that makes sense. They are pretty far from the inside of the engine gasket material wise.
This being said, I am planning to whip up some JB weld once the bearings are in to bring this surface back to the correct level (assuming it wont cause a problem operationally, it doesn't look great...)
Smile
-Jvr
The last post was made 14 years, 140 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 59.13 Kb
