Suzuki SFV650 Gladius Side Stand / Indicator Relay question
kiddakidda
PostPosted: 13:43 - 02 May 2012    Post subject: Suzuki SFV650 Gladius Side Stand / Indicator Relay question Reply with quote
Love them or Loathe them I have decided to install a Clifford GP1000T Alarm and Immoboliser to my bike.
It's not installed yet but I have hit upon a potential problem with the indicator wire.
This is what the text from the installation manual says:
NOTE: A diode may need to be inserted in the motorcycle indicator relay supply if the
indicator circuit can feed back to the ignition on the bike. To test if a diode is required,
activate one of the direction indicators, turn ignition off and then arm the alarm. If the
alarm triggers the indicators are supplying 12 volts to the alarm ignition wire.
Now the problem I have is that the indicator circuit does look like it feeds back to the ignition system through the Br wire. Obviously Suzuki use a combined Indicator / Side stand relay but on the wiring diagram looks as if the Side Stand & Indicator Relay are seperate within the unit with the side stand section having a diode already installed.
Can anyone shed any light on the above? Do the Side Stand & Indicator relay share the diode or do I need to work out a way to attach a diode to the indicator side?
I can provide the wiring diagram if it helps??
kiddakidda
PostPosted: 22:06 - 02 May 2012    Post subject: Reply with quote
OK, let me try another question.
The Suzuki Side Stand / Turn Signal relay is obviously in one housing with a built in Diode.
Is the unit effectively 2 seperate Relays? And if it is, does the Diode only service the side stand or the turn signal relay as well?
The last post was made 14 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 32.49 Kb
