leccy help - mtx lights !!!
69chris
PostPosted: 15:04 - 30 Apr 2012    Post subject: leccy help - mtx lights !!! Reply with quote
hey guys,
im trying to sort out the headlight on an mtx200 - having problems !!!
sides light and rear light working fine, headlight (dip and main) are as dim as a really dim thing - the side light is brighter !!!
iv stripped and cleaned the switch and all the connectors, checked the earths etc and its just the same,
iv tested the wiring coming up to the funny junction box thingy behind the headlight and the white/yellow wire (headlight feed ??) has minimal voltage, i say minimal as i havent found my c/tester from our recent move yet so im having to use a test bulb ( Embarassed ) and it hardly even lights that up Laughing
what do we think ? lighting coil dying or is there something else common to these that im over looking ???
i know someone will say get a manual - i have one coming, just wanted to make a start on the old girl Smile
thanks guys Thumbs Up
PostPosted: 15:32 - 30 Apr 2012    Post subject: Re: leccy help - mtx lights !!! Reply with quote
Do they run on AC?
Have you tested it while revving the engine?
Often they'll be dim until the bike is revved.
69chris
PostPosted: 17:50 - 30 Apr 2012    Post subject: Reply with quote
yep give it a rev and the bulb goes from barely visible to a tiny glow,
anyhow, i dug a little deeper - what this called ??
https://i157.photobucket.com/albums/t78/71bugslug/010-2.jpg
id have said either the reg or the rec - but i also have another little box that says that is the reg/rec
https://i157.photobucket.com/albums/t78/71bugslug/021.jpg
anyhow, iv tested this plug (engine to reg/rec) and iv got good voltage...... i mean a bright test light bulb !!!
https://i157.photobucket.com/albums/t78/71bugslug/011-1.jpg
so i tested this wire (as its the same colour as the headlight circuit) coming out of the mystery box......
https://i157.photobucket.com/albums/t78/71bugslug/012-1.jpg
and it has the same tiny amount as what i have at the switch/ bulb
so, er......erm...... help ........ pls Confused
bikenut
PostPosted: 13:17 - 01 May 2012    Post subject: mtx200 Reply with quote
:karma: hi dude,
head light is ac from memory, lots of bad conections by the look.......first fined box is ( green earth, white ac feed to unit when h.lights off?? ) may be zenner diode, to get rid of ac for h/lights when off and turn into heat?
dont have manual for this bike but i know a girl who does.......mb/mtx.....will see her at weekend.
PostPosted: 13:43 - 01 May 2012    Post subject: Reply with quote
I had a similar issue when sorting out my c90 wiring; it turned out to be a dodgy earth and was taking some weird route, so I'd be tempted to test that (to be absolutely sure, get a spare strip of wire and run it from the bulb to the battery negative).
After that, I'd look at tracing the wiring back and working out where it goes.
If you need AC voltage, I wouldn't expect it to be coming out of a regulator rectifier - maybe the unit which looks like one is just a regulator, while the other unit does both, so outputs DC?
69chris
PostPosted: 21:56 - 01 May 2012    Post subject: Reply with quote
thanks guys,
i'l have a more enthusiastic look for my c/tester tomorrow and give all the connectors a good clean...... im hoping just the threat of a c/tester, a hammer and me combined will be enough to scare the light into working as i hate leccy problems Laughing
69chris
PostPosted: 17:20 - 02 May 2012    Post subject: Reply with quote
found tester, located headlight feed wire from alt/stator and got..
3.2v at idle, 4.6v with a few revs,
me thinks that might be the problem Laughing Laughing
The last post was made 14 years, 132 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 52.52 Kb
