| garth |
 garth World Chat Champion
| andym |
 andym World Chat Champion
| garth |
| G |
 G The Voice of Reason
| garth |
| G |
 Posted: 10:46 - 03 May 2012 Post subject: |
| garth |
 Posted: 10:47 - 03 May 2012 Post subject: |
Don't think the MOT man will like that.
Speaking of which, it ran out today.  ____________________ You ain't a has been if you never was |
| P.addy |
 P.addy Red Rocket
 Posted: 10:54 - 03 May 2012 Post subject: |
Erm...
How does the light on hornet work.
Do you have a small side light and a big bulb with dipped and high beam. Pretty sure the "Pass" is the full beam part of the bulb. So having the bulb swapped out might sound stupid but I'd swap it out..
I remember when I used G's bike the pass button didnt work.. and I could never get full beam Could be spastic though. |
| garth |
| andym |
| andym |
| P.addy |
 P.addy Red Rocket
| garth |
 Posted: 11:17 - 03 May 2012 Post subject: |
The little push button does work, the big flick button doesn't.
Contacts look clean and I have sprayed WD on them.  ____________________ You ain't a has been if you never was |
| andym |
| garth |
| andym |
| Timmeh |
 Timmeh World Chat Champion
| garth |
| G |
 Posted: 09:03 - 04 May 2012 Post subject: |
There will probably be a relay for the headlight, so the full power doesn't go through switch.
(As opposed to my Delica, which it turns out does have full power going through the stalk, when the fuse blew due to a short and I replaced it with one from a dodgy batch that it turns out don't blow - cue a fair bit of smoke pretty quickly and lots of melted stuff.) |
| garth |
| lihp |
 lihp World Chat Champion
| chris-red |
| G |
 Posted: 11:04 - 04 May 2012 Post subject: |
Wiring diagram:
https://s574.photobucket.com/albums/ss182/hmmmnz1/Honda/?action=view¤t=cb600f.jpg
No relays it seems.
Mistakenly thought it was the ZX9 and first looked at wiring diagrams for that - turns out the single headlight C doesn't have a relay but the dual headlight E does, as a point of interest.
So if the pass button works it very much points to it being a switch.
Possible it could be either the main lighting switch (though the sidelight bit of that works, it's a separate bit) or the 'dimmer' switch.
Should be able to unplug the ends get the multimeter out and poke it into the appropriate bits to see if a connection is made for both. |
| garth |
The last post was made 14 years, 132 days ago. Instead of replying here, would creating a new thread be more useful? |
