NSR fork rebuild advice please.
jimmyjaffa
PostPosted: 10:38 - 03 May 2012    Post subject: NSR fork rebuild advice please. Reply with quote
Hi all, just need some advice about fork rebuild. I'm all ok about changing the seals etc it's just what grade of oil to use. I'm a big lad at about 20 stone and the forks where a bit soft( no surprising ), I was thinking of using 20w oil with a spacer on top of the spring. Do you think this would be ok. Cheers for any advice. Jim.
supZ
PostPosted: 14:51 - 03 May 2012    Post subject: Reply with quote
speak to https://www.mctsuspension.com/home.htm
they're great with general advice and will do a top job if you decide to get them to do it as well. cant recommend them enough.
CBR954RR - Daily toy
CBR600RR - Trackbike
PostPosted: 15:07 - 03 May 2012    Post subject: Re: NSR fork rebuild advice please. Reply with quote
Ideally you want to get a spirng that is correct for your weight if possible.
The spacer will add pre-load to the spring, however it'll still be the same basic spring which will probably not be designed for a range that includes your weight.
Thicker oil will make damping stiffer, but this doesn't address the spring.
However, if budget is tight, try a thicker oil and preloaded spring to see how it feels - it's a bodge that can make things better if not ideal.
alains
PostPosted: 18:53 - 03 May 2012    Post subject: Reply with quote
use fork oil grade 20 instead of 5 or 10
jimmyjaffa
PostPosted: 23:03 - 03 May 2012    Post subject: Reply with quote
Right, the way I have gone is I have used 15wt oil and spaced with 4x 2 pence pieces per fork. Will fit them tomorrow and when the weather gets better ill try them out. But they are stiffer than before.
PostPosted: 00:35 - 04 May 2012    Post subject: Reply with quote
If you suck the same amount of oil out each side, you can then add lighter or heavier to make a mix somewhere inbetween if you want a bit of 'fine tuning'.
Remember the air gap also gives some 'tuning' potential near the bottom of the stroke too.
jimmyjaffa
PostPosted: 19:57 - 05 May 2012    Post subject: Reply with quote
Hi all, just been out on the bike and what can I say. Totally different ride, just the right stiffness in the forks and no leaks.
The last post was made 14 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.53 - MySQL Queries: 13 - Page Size: 50.47 Kb
