| barryd |
 barryd Nova Slayer
| at106 |
 at106 Brolly Dolly
| MyCarVsYourHe... |
 MyCarVsYourHe... Nova Slayer
 Posted: 18:01 - 02 May 2012 Post subject: |
You need to remove around 6 bolts to gain complete access to the light housing, these should be found here:
https://i.imgur.com/7aLmp.jpg
or if you can just remove the V shaped fairing at the front which is around 3 screws, and put your arm down, but this is only easy when you know what your doing.[/img] |
| barryd |
 barryd Nova Slayer
| Alpha-9 |
 Alpha-9 Super Spammer
| barryd |
 barryd Nova Slayer
| MyCarVsYourHe... |
 Posted: 04:34 - 03 May 2012 Post subject: |
I fucking hate accessing the spark plug on peugeot speedfights, there's next to no room for play if you're using a ratchet, you have to use a 21mm spark plug socket and a wrench. I use this tool kit from argos, it has all the bits neccesary to completely strip my speed fight.
https://www.argos.co.uk/static/Product/partNumber/7001868/Trail/searchtext%3ETOOL.htm
I'm unsure what your problem with the lights are, from what I can gather, when your left light (main beam) is on the right light (dip beam) is off and vice versa, if so then this is normal. |
| barryd |
 barryd Nova Slayer
| barryd |
 barryd Nova Slayer
| MyCarVsYourHe... |
| stevo as b4 |
| barryd |
 barryd Nova Slayer
The last post was made 14 years, 128 days ago. Instead of replying here, would creating a new thread be more useful? |
