Repost - Not All 125's Are Equal
Efes123
PostPosted: 08:20 - 04 May 2012    Post subject: Repost - Not All 125's Are Equal Reply with quote
I did post this in one of the threads, but thought it might be useful to give it more coverage
One thing I've never seen mentioned on this board is that not all 125s are equal. Some are only useful for the A1 (light) rather than the A2 (standard) test.
Sub-category A1 (light motorcycle)
A sub-category A1 motorcycle is a solo motorcycle between 75 and 125 cc.
They have a power output of no more than 11 kilowatts
If you pass your test on a motorcycle in this sub-category you can ride motorcycles up to 125 cc as a full licence holder.
Sub-category A2 (standard motorcycle)
A sub-category A2 motorcycle a solo motorcycle between 121 and 125 cc.
They must be capable of more than 62.5 mph (100 km/h)
If you pass your test on this sub-category of motorcycle you can ride motorcycles with a power output of no more than 25 kilowatts. That's the same as 33 brake horse power. This restriction will last for two years.
After two years the restriction will end automatically. You can then ride a motorcycle of any engine size and power output.
You can check out which bikes fit which category here:
https://www.direct.gov.uk/prod_consum_dg/groups/dg_digitalassets/@dg/@en/@motor/documents/digitalasset/dg_197021.pdf
Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD
tbourner
PostPosted: 08:39 - 04 May 2012    Post subject: Reply with quote
Also some are shit and some are good. Very Happy
Trev, now a biker?
Looking for first big bike.
Ribenapigeon
PostPosted: 10:02 - 04 May 2012    Post subject: Reply with quote
Hmmm Does that mean if I pass my test just using my Yammy wr250x (15HP) then I could get a Kawasaki 250 Ninja for a couple of years. If so this changes my plans as I dread the DAS as a route to getting a bigger bike.
Teflon-Mike
tl;dr
PostPosted: 10:45 - 04 May 2012    Post subject: Reply with quote
There are 3 test options. Tests are the same, only difference is the bike you take them on. (Note Mod 1 & 2 MUST be taken on the SAME class of machine to gain a full licence)
1/ Light-Bike
75-120cc motorcycle, or 125cc motorcycle NOT capable of 62Km/k or not on DSA approved 'Standard-Bike' list.
Passing tests under 'light-bike' rules, you get an A1 group, 'full' licence.
A1 provides FULL Licence entitlement to ride a motorcycle up to 125cc & 11Kw, (as Provisional Entitlement) but you do not have to display L-Plates, MAY carry Pillions, and MAY use Motorways.
2/ standard-Bike
120-125cc machine up to 11Kw power output, vapable of more than 62Km/h and on the DSA approved 'Standard-Bike' list. NOTE that the Aprillia RS125, is on the list with endorsement; 'Must Provide Proof of restriction'. This may apply to other machines that are supplied as standard above 11Kw Learner power limit, that are not on DSA list.
Passing tests under 'Standard Bike' rules, gains you CURRENTLY a FULL A-Froup licence, with two year 25Kw/33bhp power 'probation.
You may ride any capacity machine; carry pillions, use motorways.
BUT bike must be under 33bhp for two years from date of passing test. AFTER that, you may ride any power bike, you do NOT need to take any further test.
3/ Big-Bike / DAS
Rider must be over 21 years old. Machine requirements are I BELIEVE that the bike has to be over 395cc and 33Kw/45bhp... bit hazy on them figures... has to be a 'big-bike' basically, full power GS500 or up.
Pass tests on a Big/DAS bike, you get full A group entitlement, same as passing under 'Standard-Bike' rules, only difference is you DONT have the 2 year power probation.
Re interpreting his post:
Efes123 - ought to have wrote:
If you are buying a 125 to get your tests on... CHECK the DSA list of approved bike for 'Standard-Bike' test, becouse if the bike you are looking at ENT on the list, you may onlt take the 'light bike' test and NOT get a licence worth the paper its printed on for the effort; OR if you book a 'standard bike' test, be refused when you turn up for NOT having an eligible machine to test on. Pay particular heed, that many CHINESE branded bikes are NOT on the DSA approval list!
These Schemes are those that have been in force for MANY years, and are about to be chucked out the window, January 18th next year.... Ie aprox seven months, 28 weeks, less than 200 days, from date of this post!
After that; NEW Euro-Complient 3rd Directive rules will apply.
1/ Light-Bike / A1 Test
Rules become those currently in effect for 'Standard-Bike'.
Passing on such a machine, will gain a Full A1 group licence as now. Licence entitlementy will remain as now. (11Kw/125cc, pillions motorways, no L-'s)
And these entitlements will remain in force perpetually. You wont be granted higher entitlement after any probation period, that's ALL you will ever be able to ride WITHOUT taking another test.
2/ Standard-Bike/ A2 Test
the A2 licence catagory will come into legal existance. (Note people talk of '33bhp restricted licence currently as 'A2' it is not, the group does NOT yet exist in UK system!)
You will have to have held an A1 licence a minimum of 2 years and be 19 years old, to test for A2 licence.
Machine requirements are for a machine I believe between 395cc & 600cc, with between 40 & 45bhp... (again OTMH without actually checking specs!)
Passing test wiull gain A2 Full licence entitlement; allowing you to ride any capacity of machine, up to 45bhp, provided it has NOT been 'restricted' from a standard model that makes more than 90bhp.
You will NOT be able to ride anything more powerful, without passing further test!
3/ Big-Bike/ Full A licence tests
You must be over 21 years old, and have held an A2 category licence a minimum of two years before you are eligible to test for full A. OR Be over 24 years old to test under DAS rules.
Machine requirements, I think call for a machine over 595cc and above 45bhp, from memory, basically a 600+
Passing gains full unrestricted A group licence entitlement, as currently under DAS rules.
THOSE are the new test-rules, give or take, though DfT are still haggling details.
Its 'suggested' there may be a 'direct' access route to A2 for 19+ year olds, to skip the 2 years on A1. But its merely a 'suggestion' they have NOT put any actual words on papoer by way of draft legislation, yet as far as I know.
Its ALSO suggested that, the 'upgrade' tests from A1 to A2 and A2 to full A, MIGHT have a substitute 'Upgrade by Training' alternative, so rather than re-do the 'test' under a DSA examiners eye; you do a Course, of 'some sort'... probably something like CBT... and send certificate of completion away with your licence to get higher group added. AGAIN, they have cannily NOT put anything in writing.
No... dont meet criteria for ANY of the test regimes. Too big for Light or standard, too small for DAS.
Ribenapigeon
PostPosted: 11:11 - 04 May 2012    Post subject: Reply with quote
Sorry i meant if i pass my standard test on my Yammy wr125X then would i be entitiled to use a 250 Ninja as they are rated at less than 33HP
fatjames
PostPosted: 12:03 - 04 May 2012    Post subject: Reply with quote
Yes. You will be able to ride anything upto 33bhp. You can even get a litre bike and restrict it if you wanted to.
HTH
FJ
Efes123
PostPosted: 16:57 - 04 May 2012    Post subject: Reply with quote
Laughing Thumbs Up Laughing
TLDR =
Perhaps I should have added "and some (Chinese) are no use at all.
Ribenapigeon
PostPosted: 22:08 - 04 May 2012    Post subject: Reply with quote
Cool in that case I will save myself the expense of the DAS and just do my test on my 125. My plan was to just get a 250 for a couple of years anyway after the test.
Hokum
PostPosted: 18:45 - 05 May 2012    Post subject: Reply with quote
It is silly that a non "approved" bike would only net you a light.. I was kind of interested in the Keeway RKV. But there is no point, as it isn't on the list...
They should update the list monthly as new bikes come out. I spied a used Aprilia Tuareg 125 in my area, but again no point in looking as it isn't on the list and is old...
Sane: To know when you are doing something crazy.
Ribenapigeon
PostPosted: 20:04 - 05 May 2012    Post subject: Reply with quote
My so called smartphone would not open the pdf of approved 125s could someone look up Yamaha WR125X for me and see if its on the list. Mucho appreciation if you can.
tbourner
PostPosted: 20:15 - 05 May 2012    Post subject: Reply with quote
It's an A2.
Trev, now a biker?
Ribenapigeon
PostPosted: 20:52 - 05 May 2012    Post subject: Reply with quote
Its an A2 but is the Yamaha WR125X on the list of motorcycles approved for doing the test on?
tbourner
PostPosted: 21:12 - 05 May 2012    Post subject: Reply with quote
If it's an A2 bike then it's approved for giving you a standard bike licence if you complete both test on it.
Trev, now a biker?
Ribenapigeon
PostPosted: 21:41 - 05 May 2012    Post subject: Reply with quote
Ah ok, I was under the impression there was a list of specific bikes that could be used.
tbourner
PostPosted: 21:46 - 05 May 2012    Post subject: Reply with quote
I don't know what would happen if you used a bike not on the list, you might have to prove it's OK, but your bike is listed on that link from the OP.
Trev, now a biker?
Ribenapigeon
PostPosted: 21:57 - 05 May 2012    Post subject: Reply with quote
Cool, thanks for looking up the list for me.
Teflon-Mike
tl;dr
PostPosted: 23:59 - 05 May 2012    Post subject: Reply with quote
OK, low down on 'THE-LIST'.
The 'standards' for a 125 Test bike to get Restricted A-Group licence are laid down in statutes 'somehwere' dont ask me which one.
'The List', is merely the DSA's published 'guide' for bikes they categorically 'accept' as being eligible.
Like the 33bhp restriction, you choose to use a bike that the manufacturers claim to be 33bhp compliment, up to YOU to make it compliant with your licence entitlement, and prove it to be so.
So, if you turn up on a Lexmoto-Vixan, lexmoto's own published specs say is only capable of 55mph.... then they examiner COULD challenge you, over it...
You could try Rogers argument that that quoted spec if from the manufacturers declared data, to meet Chinese regs... and they are actually a bit faster, because they are only 'boarder-line'....
OR you could try a bit of blarney, and suggest that your mate, did some 'tuning' and fitted a race ignition unit off e-bay, and polished the ports, and you have raised the gearing.....
How you might 'prove' it was capable of more than 62mph, I don't know...
Run what y'brung Timing sheet? Be fun, puttin a Vixen up the strip!
Might be fun just for the crack? What would the ET be does any one reckon? Maybe we could have a sweep-stakes!
Other side the list; if you were to turn up on a non listed bike, like I dont know, rare italian exotic, like an old Gilera CX... not on the list, would be capable of more than 62mph, easy to show that offering a manufacturers OE spec sheet with a claimed power of something like 26bhp.... so they would then ask for proof or restriction.
If Yam WR125 isn't listed... you take Dealer Brochure with power stats with you in case any-one asks.
If its a KTM, you take brochure and proof or restriction, a dyno-chart or something.
BASICALLY, it doesn't HAVE to be on the list, but it DOES have to meet the specs. List is just the 'safe bets'.
Anything else, up to you to have answer if you are challenged.
If you are aware of that, and prepared, AND prepared to possibly loose £75 and your slot.... its just one more 'risk' in the many that could stop you getting a licence on that attempt.
We dont have many reports of people being refused tests for not being on DSA listed bikes, we have more issues of them being refused for turning up inapropriately dressed, not having legal L-Plates, bot displaying Tax discs or having machines the examiner does not believe to be in aproprioate 'road-worthy' condition.
So, for guidance JUST becouse a bike is not on teh DSA's list DOESN'T mean they wont test you.... but even if it IS its no garantee....
APPLY COMMON SENSE.
The last post was made 14 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 105.8 Kb
