Patten Gaskets
Nick_Giles
PostPosted: 16:56 - 05 May 2012    Post subject: Patten Gaskets Reply with quote
OEM gaskets ain't particularly cheap. Patten ones are.!
Are they OK or more trouble than they are worth and the higher cost of the OEM ones is soon out weighed by less hassle.?
Cheers, Nick.
reckless_b
PostPosted: 17:26 - 05 May 2012    Post subject: Reply with quote
Only ever used pattern gaskets, never been a problem.
40 years on the road on and sometimes off bikes with a very recent OFF
karthead This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
lihp
PostPosted: 09:36 - 06 May 2012    Post subject: Reply with quote
andresoccer10 wrote:
If it is a head gasket, a little trick is to use a really skinny gasket, in doing this you will decrease the 'explosion distance' which should give the engine a little more power.
Pretty stupid idea tbh unless you know what you're doing.
For somebody asking about an air filter that can't rejet a carb, you're hardly in a position to recommend changing compression ratio
PostPosted: 09:48 - 06 May 2012    Post subject: Reply with quote
Used pattern on a full RS125 rebuild. You'd need to check with G as to whether they are lasting but they were fairly decent. I'm using a nowhere.elysium pattern gasket made from a Budweiser box which hasn't leaked yet Laughing its a year old too
V2
PostPosted: 09:57 - 06 May 2012    Post subject: Reply with quote
Lul 2strokeoil Wut? put the gasket paper onto the thing you want a gasket made for then tap round the edge with a ball pein hammer to cut out your gasket!
Nick_Giles
PostPosted: 10:04 - 06 May 2012    Post subject: Reply with quote
Cheers for the posts so far folk.
Its not a high pressure point (in this case) Its just the clutch cover housing.
So it seems that Pattern gaskets are fine, hunky-dory & spiffingly-dandy for this. Wink
Cheers, Nick
karthead
PostPosted: 10:38 - 06 May 2012    Post subject: Reply with quote
What do you have against me? You dont even know how much i know about engines, ect. Just because i dont know how to rejet a carb, that has nothing to do with changing head gaskets. It wasnt my idea, it was a trick i was taught by a moto-maniac. Carbs and air filters are much more difficult and delicate to deal with, if you get it off balance by a little bit, it'll change how the engine runs and can possibly ruin it.
Anyway, surely by making the head gasket thinner by like .1/.2 of a mm, it isn't going to make a heck of a lot of difference to how the engine runs.
karthead
PostPosted: 10:39 - 06 May 2012    Post subject: Reply with quote
Yeah i was taught that also, but in my motor class so many people are getting it wrong and it can ruin the engine if you hit it too hard. My method (or so i was taught) is a bit more safe. Wink
PostPosted: 10:40 - 06 May 2012    Post subject: Reply with quote
lololol circlips init
Srs, you need to leave the workshop section Laughing
karthead
PostPosted: 10:55 - 06 May 2012    Post subject: Reply with quote
It was an idea. just because i made a stupid idea (which others approved of) doesnt mean i know nothing.
Nick_Giles
PostPosted: 11:04 - 06 May 2012    Post subject: Reply with quote
I think the point that Paddy was making was :-
"Before you break rules you first have to understand those rules"
Nick
PostPosted: 11:16 - 06 May 2012    Post subject: Reply with quote
Lol, was merely stating.. I do some dumb shit, but this guy, he's off the chart.
What next..?
I have a coke can, my rear wheel is buckled, can I use this if I find a twig to put through the middle of can and glue it on so I has small rear wheel?
Do you have a girlfriend...if so please tell me safe sex isn't a sock Praying
lihp
PostPosted: 11:22 - 06 May 2012    Post subject: Reply with quote
If you don't understand why changing compression ratio will affect how the engine runs then you shouldn't be doing it.
karthead
PostPosted: 11:33 - 06 May 2012    Post subject: Reply with quote
By making the volume smaller the expanded gasses need more room to escape. This will make it more powerful but not by much... I do understand, but its not going to make a great difference.
groovylee
PostPosted: 12:39 - 06 May 2012    Post subject: Reply with quote
unless of course someone has already skimmed the head / used a thinner gasket. then you end up with the piston making sweet sweet love to your valves.........
i can see where you're coming from, i'm just not sure where you're going to end up if you keep coming out with very short sighted ideas like you have been so far. trying something different is all well and good, but giving out advice to others who may think you know what you're talking about could have catastrophic effects on someone elses pride and joy.
if you're not 100% certain about the advice you're about to give, don't give any
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
PostPosted: 12:57 - 06 May 2012    Post subject: Reply with quote
If you up the compression too much then the mixture in the combustion chamber will spontaneously combust rather than burning, and this violent explosion can easily cause very large amounts of damage. Hole burnt in the piston being the most likely damage, but knocking out the big end bearing is also a distinct possibility.
The last post was made 14 years, 192 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 99.73 Kb
