Oil the Chain?
Ribenapigeon
PostPosted: 17:19 - 06 May 2012    Post subject: Oil the Chain? Reply with quote
Ive booked my Yammy WR125X in for its first service as i`ve now done 600 miles on it. Should i oil the chain before putting it in for the service? also should i buy an chain oiler device? In fact any advice on oiling the chain is welcome Smile
Derivative
PostPosted: 17:26 - 06 May 2012    Post subject: Reply with quote
I've only done a motorcycle chain once but I did road bikes quite a bit.
It all depends on how much life you want to get out of your chain really.
If it's covered in bits of grit etc then you might want to give it a go with a brush and degreaser to try and get as much out as reasonably possible without taking it off the bike. Then use a rag to get off as much grime as you can.
On the CG I dropped the back wheel and just took the chain off to do it, but I don't think it was necessary, more of a tarty thing of having it look perfect for a bit.
You are aiming to grease the links to lubricate them, not cover it in oil to prevent rust. So you want to put a drop or two on each chain link, roll the back wheel along (IN NEUTRAL), do the next link, etc.
Easy with a centre stand, not sure about without.
If you can get replacement chain/sprockets cheap or can justify buying new ones often then don't bother cleaning it hardcore, just make sure the oil is on there.
arry
PostPosted: 17:53 - 06 May 2012    Post subject: Reply with quote
If it's looking dirty or dry then clean it and oil it. Wouldn't bother with an oiler TBH
carvell
Scuttler
PostPosted: 17:57 - 06 May 2012    Post subject: Reply with quote
An aerosol 'chain lube' would be easiest.
Just hold it over the chain by the back sprocket, then spray and spin the wheel. 10 seconds - job done.
Yamaha TDM 850
Ribenapigeon
PostPosted: 20:15 - 06 May 2012    Post subject: Reply with quote
Yup i will just spray some on tomorrow when i get home from work.
Ed Case
PostPosted: 20:17 - 06 May 2012    Post subject: Reply with quote
If you're using your bike in all weathers, leaving it outside at work , using it as a 'workhorse'..........check out 'Loobman' on the net....I've got one on my CB250RS which with no discernable cush-drive + being a single cylinder it gives the chain a bloody hard life...works for me.
tomh
PostPosted: 20:23 - 06 May 2012    Post subject: Reply with quote
If you're going to use chain lube in a spray can, hold a piece of kitchen roll underneath the chain and spray from the top. This way will mean you don't end up with excess oil all over your swingarm/wheel.
neil.
PostPosted: 21:45 - 06 May 2012    Post subject: Reply with quote
Get hold of some paraffin - sold as Parasene lamp fuel in places like Homebase. Put it in a squirty bottle and spray the chain with it. Use a 'gunge brush' 3 sided brush and give the wet chain a good scrubbing, then rinse it off with more paraffin and dry it with a rag. Next grab some engine or gear oil and apply it to the bottom run with a paint brush. When you've finished, go over the chain with a rag to aviod any excess fling. Thumbs Up
Ribenapigeon
PostPosted: 22:02 - 06 May 2012    Post subject: Reply with quote
The loobman looks good, nice and simple and not too expensive.
Taught2BCauti...
PostPosted: 09:24 - 07 May 2012    Post subject: Reply with quote
+1 for the Loobman - cheap and easy to fit. I use a mix of car gearbox oil and STP to reduce flinging.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
The last post was made 14 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 62.13 Kb
