Has something fallen off my front wheel?
allotriophagy
PostPosted: 20:48 - 06 May 2012    Post subject: Has something fallen off my front wheel? Reply with quote
This is so dumb but I don't know anything about my bike. Today the handling felt really different, especially going around corners. When I parked up, I looked around and it looks like something has fallen off?
I've looked in the service manual and online but can't find any clear pictures of this bit of the wheel. Is it normal or should it have like...a pin or something?
I've attached a picture. It's a 2004 CBR600F.
mab
PostPosted: 21:08 - 06 May 2012    Post subject: Reply with quote
There is nothing that need to go in those holes. they are there to remove the spindle. A tool slots through them so you can turn it.
kingsmith
PostPosted: 21:09 - 06 May 2012    Post subject: Reply with quote
front tyre going down????
honda cg 125 copy cheap and crap, perfect for work..
suzuki gsxr600 srad 2000
passed 12/11/09 happy boy
Noxious89123
PostPosted: 21:12 - 06 May 2012    Post subject: Reply with quote
Nope, it's so you can put a screwdriver through the holes to pull the axle out.
HTH Thumbs Up
PS. Mine is the same Wink
Ariel Badger
PostPosted: 21:16 - 06 May 2012    Post subject: Reply with quote
Check tyre pressures on both wheels.
Moxey
PostPosted: 21:35 - 06 May 2012    Post subject: Reply with quote
This and look to see if any of the weights have come unstuck from the wheel, it may just need rebalancing.
They're normally held on with an adhesive (or sometimes double sided tape on a budget) and can come off.
allotriophagy
PostPosted: 09:52 - 07 May 2012    Post subject: Reply with quote
Glad I didn't go to the garage in a panic and look like a mong, as usual. "Why does the accelerator on the left handlebar not turn! How do I make the front wheel speed up!"
Tyre pressure and rim weights are all fine. I'm starting to wonder if it is just because the roads are dry for a change and I had got used to riding in the wet. Plus the petrol tank is nearly empty so that might be a factory.
Thanks for the info guys. Very Happy
Taught2BCauti...
PostPosted: 10:01 - 07 May 2012    Post subject: Reply with quote
Its worth checking your front wheel bearings if you can get the front wheel off the ground, by checking for play - grab the tyre top and bottom and try to rock it, then do the same left to right.
They can go suddenly!
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Ichy
PostPosted: 10:41 - 07 May 2012    Post subject: Reply with quote
Maybe you are leaning it a bit more and the tyre has squared off after the extended cold and wet weather.
Noxious89123
PostPosted: 14:59 - 07 May 2012    Post subject: Reply with quote
Did this actually happen? Laughing
shereen
PostPosted: 15:32 - 07 May 2012    Post subject: Reply with quote
This.
Have you got a picture of your tyres? If they are very squared off the bike will feel terrible.
bikenut
PostPosted: 11:12 - 08 May 2012    Post subject: manual Reply with quote
:karma: hi dude,
you need to get a manual and read it, the lhs twist grip doesnt do anything except comfort your hand which shouild be in a glove.
get a manual and read it, then join a mc club
PostPosted: 11:20 - 08 May 2012    Post subject: Re: manual Reply with quote
bikenut wrote:
Karma hi dude,
https://i0.kym-cdn.com/photos/images/original/000/000/151/n725075089_288918_2774.jpg
The last post was made 14 years, 190 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 83.27 Kb
