| U_W v2.0 |
 U_W v2.0 World Chat Champion
| herulach |
 herulach World Chat Champion
| U_W v2.0 |
| cb1rocket |
 cb1rocket World Chat Champion
| U_W v2.0 |
 Posted: 09:27 - 07 May 2012 Post subject: |
definatly not a "loose" wire.
possibly a broken wire though.
i went over all of the connections in and out of the headlamp and the switches prior to replacing them. and against after i did.
i'll check the systems over with a multimeter tomorow.
unfortunatly for me, i've been up all night and now i really must go and get some sleep  ____________________ BCF's biggest cunt list: Cansa, Pits, Rob |
| Ichy |
 Ichy World Chat Champion
| Taught2BCauti... |
 Posted: 09:52 - 07 May 2012 Post subject: |
You need to check what is happening at the switch - and your screwdriver/circuit tester will do just fine, with one side connected to permanent earth and the other as a probe.
Check the wiring at the bulb holder and see if you can physically trace it back to wherever it goes.
Its also possible that you have a duff bulb - even though the filaments look sound!
I have seen some strange wiring setups on Chinese bikes - one that I looked at had the low beam fed from a changeover relay so that it came on with the ignition. The main/Dip switch was just an on/off switch that worked the relay!
I have also seen examples that had a separate fuse for main and dip, and one that had a dual filament bulb fitted, but no wiring for the high beam - and it looked like it had left the factory like that! ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| U_W v2.0 |
| cb1rocket |
| U_W v2.0 |
| U_W v2.0 |
| U_W v2.0 |
| U_W v2.0 |
| Ichy |
| U_W v2.0 |
 Posted: 21:37 - 07 May 2012 Post subject: |
i've taken the switches apart and allowed them to hang down, clear, not touching anything and the problem persist so its not a short in the switches also wouldnt that stop the front lamp from working too? seeing as the front lamps working i wouldnt have thought it a short forward of that.
next thing to try? ____________________ BCF's biggest cunt list: Cansa, Pits, Rob |
| Ichy |
 Posted: 21:50 - 07 May 2012 Post subject: |
Welcome to the world of Chinese electrics
Best advice is to try finding a wiring diagram.
Run a piece of wire from an earth to the tail light. Same again with 12v. The tailight, clock lights and maybe other stuff are on a different circuit than the headlights. Is the position light still working? ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| U_W v2.0 |
| Ichy |
| U_W v2.0 |
| U_W v2.0 |
The last post was made 14 years, 190 days ago. Instead of replying here, would creating a new thread be more useful? |
