Novice biker - chain cleaning.
Maddsto
PostPosted: 10:30 - 07 May 2012    Post subject: Novice biker - chain cleaning. Reply with quote
Hey guys,
Still new to the forums and still pretty new to the biker scene (always been a scooter driver) but got myself a GN125 a few months ago - best thing i've ever done!
Now my chain is looking pretty dirty/gunky so i'm thinkinig its in dire need of a good clean and oil.
My question : what should I use to clean it, i've seen those cleaning 3 brushed tools but havn't got one yet, so would a new toothbrush do the trick? Also what washing fluid is best? And finally, once cleaned, is it just a drop of standard engine oil in the links of the chain to re-lube?
Many thanks,
Matt
Current : Honda XL Varadero 125
Old : Suzuki GN125, Suzuki GZ125 Marauder
Sako
PostPosted: 10:33 - 07 May 2012    Post subject: Reply with quote
toothbrush, a rag and some paraffin will do fine.
Taught2BCauti...
PostPosted: 10:39 - 07 May 2012    Post subject: Reply with quote
I use a spray de-greaser (like 'Gunk') and an old paintbrush before drying it off with some old rag and re-greasing.
I have a Loobman Chain Oiler fitted, so don't need to do this too often.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Maddsto
PostPosted: 10:43 - 07 May 2012    Post subject: Reply with quote
Brilliant, cheers for the fast replies Very Happy
So as for re-greasing, standard engine oil will be fine? I dont want to over or under lube the chain Embarassed
Kingstondavo
PostPosted: 11:38 - 07 May 2012    Post subject: Reply with quote
I wouldn't use engine oil, go for some dry chain lube in an aerosol, it's way easier/quicker to put on and won't flick off all over your bike...
I use whatever is cheapest generally, have a can of mucoff at the moment as it was on offer, seems to be pretty good, lasts ages and doesn't throw off the chain as soon as you ride away!
Current Ride - 2010 Hornet 600
Maddsto
PostPosted: 12:50 - 07 May 2012    Post subject: Reply with quote
I getcha, will pop down halfords tomorrow and see what they have got there (from what i remember they have a big range of mucoff products)
Cheers once again for all the help Very Happy
orac
PostPosted: 13:31 - 07 May 2012    Post subject: Reply with quote
i wouldn't use any form of degreaser, dont forget the chain is suposed to have grease on and in it. i tooth brush, rag and a can of wd40 is fine, then relube with a quality chain lubricant.
honestly a little extra money spent on doing it right no will save money on buying new chain and sprockets due to increased wear down to bad maintianence
Maddsto
PostPosted: 13:56 - 07 May 2012    Post subject: Reply with quote
I mean, I know the chain is ment to have a good layer of grease on it, however mine is now 1part grease with about 3parts muck and grime.
I'll try the WD40 trick first, as i have all that at home, just need to get a good chain lube.
Ta Orac Very Happy
PostPosted: 14:57 - 07 May 2012    Post subject: Reply with quote
orac wrote:
i wouldn't use any form of degreaser [...] a can of wd40 is fine
WD40 FAQ wrote:
4 litres of paraffin costs about the same as 600ml of aerosolised WD-40.
Paraffin, toothbrush, engine oil, wipe off excess, job done.
The last post was made 14 years, 142 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 60.74 Kb
