Oil Message On Dash, Just Passed 600 Miles, Normal?
Ribenapigeon
PostPosted: 13:20 - 07 May 2012    Post subject: Oil Message On Dash, Just Passed 600 Miles, Normal? Reply with quote
Just noticed a message on my dash saying OIL. I have just passed the first 600 Miles on my WR125X. Is this just a normal messasge to get my service done (which ive already booked for next week)?
I actually checked fluid levels a week ago and they were fine.
Derivative
PostPosted: 13:22 - 07 May 2012    Post subject: Reply with quote
Check it now?
Oil level takes seconds to check.
FerretFing
PostPosted: 13:45 - 07 May 2012    Post subject: Re: Oil Message On Dash, Just Passed 600 Miles, Normal? Reply with quote
Shocked It certainly isn't normal & needs investigation Thumbs Up
PostPosted: 14:02 - 07 May 2012    Post subject: Reply with quote
Don't know the bike, and possible it is just a message based on mileage to tell you to service it. Also possible it is based on oil level or pressure, in which case running it without sorting the problem could do severe damage.
Pete.
PostPosted: 14:24 - 07 May 2012    Post subject: Reply with quote
https://www.motorkari.cz/upload/files/manualy/3160_yamaha-wr125r-2010-u22be1.pdf
Page 20 explains it.
This indicator flashes at the initial 1000
km (600 mi), then at 3000 km (1800
mi), and every 3000 km (1800 mi)
thereafter to indicate that the engine oil
should be changed.
After changing the engine oil, reset the
oil change indicator.
TIP
The oil change indicator can only be reset
when “OIL” flashes in the multifunction
display.
To reset the oil change indicator, select
it by pushing the “RESET/SELECT”
button briefly (less than one second),
and then pushing the button again for at
least five seconds. When the oil change
indicator stops flashing and stays on,
release the “RESET/SELECT” button
within three seconds; the indicator will
go off.
TIP
If the oil change indicator still flashes after
the reset procedure has been completed,
repeat the reset procedure.
a.k.a 'Geri'
Ribenapigeon
PostPosted: 14:53 - 07 May 2012    Post subject: Reply with quote
I checked the oil level and it was fine. Then I just passed by the Yamaha dealership and spoke to a mechanic he confirmed its just the computer flagging up the oil change interval for 600Miles. Phew.
FerretFing
PostPosted: 15:31 - 07 May 2012    Post subject: Reply with quote
Well f_ck me Shocked .....does it come with a toaster as well?
blurredman
PostPosted: 15:35 - 07 May 2012    Post subject: Reply with quote
I know right, the techonology of today. Laughing
Ribenapigeon
PostPosted: 15:37 - 07 May 2012    Post subject: Reply with quote
At least it does`nt speak to me!
The last post was made 14 years, 142 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.61 - MySQL Queries: 13 - Page Size: 62.39 Kb
