Are chain drive bikes faster than belt drive bikes?
juggla
PostPosted: 00:50 - 05 Oct 2004    Post subject: Are chain drive bikes faster than belt drive bikes? Reply with quote
If so should i convert my bike to a chain??
McJamweasel
BCF Junkie
PostPosted: 01:03 - 05 Oct 2004    Post subject: Reply with quote
Yes, but only because the fastest bikes happen to be chain drive.
Don't convert, its not worth the hassle.
PostPosted: 01:14 - 05 Oct 2004    Post subject: Reply with quote
Belts are actually better than chains in many ways, but are more difficult from a maintenance point of view (cannot be split, etc) and also tend to fail with far less warning.
Main reason to consider converting to a chain would be the cost of replacement parts. A belt needs no oiling, but otherwise lasts no longer and requires the removal of the swinging arm to replace (generally).
juggla
PostPosted: 01:23 - 05 Oct 2004    Post subject: Reply with quote
ah ok thanks for that you guys
PostPosted: 02:40 - 05 Oct 2004    Post subject: Reply with quote
101bhp, 90fl/lb of torque....belt drive
https://www.micapeak.com/DPG/buell/s2_thunderbolt.jpg
Frost
PostPosted: 03:26 - 05 Oct 2004    Post subject: Reply with quote
Belt drive is in theory a much better system than chain drive. however in practise belts can stretch, skip, slip, which makes them not so ideal.
So long as the belt is looked after and replaced when needed you will have no trouble from it and might actually grow to like it Wink
PostPosted: 03:57 - 05 Oct 2004    Post subject: Reply with quote
Chains also do that, however as Keith says they give more warning than a belt (although not when snapping:doh:).
NickD
PostPosted: 11:25 - 05 Oct 2004    Post subject: Reply with quote
And noted for snapping belts. Rolling Eyes
I was only doing what it said on my licence officer....
Tear along the dotted line!
Finglonga
PostPosted: 13:07 - 05 Oct 2004    Post subject: Reply with quote
Yea but when these snap they dont take out the gearbox like a chain.
VERDICT: Shaft Drive, No maintanence, No snapping, No worries.
Andy Sez....
F.Y.Y.F.F.
PostPosted: 15:12 - 05 Oct 2004    Post subject: Reply with quote
No cornering, No reduction in unsprung weight, No consistant road to tyre contact under power.
PostPosted: 17:02 - 05 Oct 2004    Post subject: Reply with quote
Chains don't always break the gearbox (or anything other than themselves) when they snap. Had one go on the at a fairly fast pace in the outside lane and it just snapped wedged itself to a gap (didn't damage anything) and that was that.
The last post was made 22 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 69.69 Kb
