OT cars, renault clio, sorry
Git
PostPosted: 12:52 - 05 Oct 2004    Post subject: OT cars, renault clio, sorry Reply with quote
So sorry to bring a car into bike workshop, I will work and park it outside out of sight Thumbs Up
Anyway, I got a call asking if I would look at a 1.4 clio, I think it's the 8valve one, it has possibly snapped a cam belt.
the scenarios I may face.
replacing the belt and time up only
replacing broken valves which means the heads got to come off
maybe a new head and valves
could it of killed a piston?
whats a cam belt like to do, is the head easy to whip off if the need arises?
I do not often work on these small petrol engines, so as unsure as to whether I should undertake said task.
Anyone had hands on experience of this particular task?
if not I will have to find a car forum.
/sobs
any info much appreciated. Thumbs Up
Razzy
PostPosted: 12:55 - 05 Oct 2004    Post subject: Reply with quote
can't help ya m8 but maybe someone else will otherwise try here www.strathycruise.com and goto the forums there.
Git
PostPosted: 13:03 - 05 Oct 2004    Post subject: Reply with quote
Thanks Thumbs Up
that will most certainly save me looking for one. Cool
Big Pete
PostPosted: 14:20 - 05 Oct 2004    Post subject: Reply with quote
I havent done a clio but I have done a 205 cam belt, first attempt took 9 hours, and the timing was out by one tooth Mad 2nd attempt took 3 hours, started perfectly. The easiest way is to pull the engine out completely, at which point the whole job is a piace of piss. When the block is in the car there is sod all space to work.
Trust me, I`m an engineer
GarageOfPower.co.uk
PostPosted: 14:30 - 05 Oct 2004    Post subject: Reply with quote
Owned a Clio once (unfortunatly), but not a 1.4.
Depending on what speed the engine was doing at the time will greatly affect the damage. Thrashing down a motorway and the damage is likely to be severe (especially if they rammed it down a gear to try and get it to start again Shocked ). Idling at traffic lights and then not attempting to start it could well be they have got away with it.
Personally I would stick another belt on it and then try. Probably do a compression check then. However the chances are that it has been some valve.
Not sure how easy it is to tension the belt on a 1.4 Clio. On the 1.2 Renault specified some special tool.
Git
PostPosted: 17:05 - 05 Oct 2004    Post subject: Reply with quote
Space, yes, this is a very big concern, I replaced a belt on an astra a while back and it was tight but just manageable, the clio looks a bit smaller nosed and maybe tighter, if the engine has to come out I shall be walking, not that brave!
Alternatively you could always take the engine out for me so I can change the now easy accessible belt Thumbs Up
Oh, the unfortunately does not sound good already, I shall brace myself Laughing
This one is on an r plate could even be a 1.2, 1.4 rings a bell for some reason.
The speed was, school run aggressive traffic light start, apparently.
50/49 then, not looking good for me, I see the device tomorrow, work may start the weekend, a bit of time to scour the net.
Minky_monkey
PostPosted: 23:57 - 06 Oct 2004    Post subject: Reply with quote
I`ve never done one on a clio, but you may find things a bit more accessable with the plastic inner wing lining removed. That way at least you can get to some of the pulleys from under the front wing.
I`m definitely with Kickstart about putting a belt on and trying it before considering removing the head. If the tensioners are the plastic type, it's worth changing those as well as they have a habit of breaking up after a few years.
Ade067
PostPosted: 00:08 - 07 Oct 2004    Post subject: Reply with quote
I havent done a belt on a clio but have changed the belt on my renault extra van which has the same 1.9 diesel engine as a Clio and that was a right shitter of a job,diesels usually are a bit more complicated than petrols but the main problem and as someone else has mentioned is space...or rather lack of it,if you've got really small hands and are double or even triple jointed you'll be fine,if not take the engine out its much easier Thumbs Up
I worked in a garage for about 10 years or so and to be honest any French vehicle is a right sod to work on,even the simplest of jobs are so bloody awkward,give me a Jap car any day,at least when they put a car together they seem to realise that one day some poor sod has to take it apart again!
jay12329
Dr. Evil
PostPosted: 00:09 - 07 Oct 2004    Post subject: Reply with quote
I thought that if the cam belt went while running it would certanly take the valves and pistons with it.
I'm not ot hot on this subject so could easily be wrong.
J
PostPosted: 13:50 - 07 Oct 2004    Post subject: Reply with quote
Generally they will, but some cars have sufficient clearance to get away with it (so called safe engines) and even of normal cars you can sometimes get very lucky if the car is idling.
mr jamez
PostPosted: 14:04 - 07 Oct 2004    Post subject: Reply with quote
My dads car (alfa romeo something or other) had the cam belt snap while on the motorway, smashed the cylinder head to pieces and dropped a valve into one of the bores...whoops Smile
Luckily that happened when the previous owner had the car Wink
Git
PostPosted: 10:08 - 19 Oct 2004    Post subject: Reply with quote
Well, I changed the cam belt on saturday, easy as pie and not too cramped, went to start up and nothing, recheck the belt was timed and it was.
Pulled off the rocker cover to find 6 of the valves clearances were in spec, the other two, one inlet and one exhaust had like 1/2 inch of play on the rocker arm so I can only presume the valves are bent.
Will remove the head the coming weekend.
Anyone know a good engine rebuild company that supplys renault engines? 1.2 (d type motor) just incase I find a dead piston or two when the head comes off?
PostPosted: 13:17 - 19 Oct 2004    Post subject: Reply with quote
Afraid I do not know of a decent supplier of Renault engines.
Known problem. The early cam belt tensioners failed (the pulley wheels broke up), rarely lasting as long as the specified service interval (72000 miles). Most specialists recommend replacing the belt and tensioner around 50000 miles which is fairly safe (and also tend to say to replace the camshaft variator at the same time, as they do wear out and you are already doing 90% of the work when changing the belt). They have revised the tensioner now (they are colour coded, think the old style ones were black and the revised ones are white) and should now last well but nobody trusts them.
Doesn't help that many fleet owners do not bother to change the cam belts when they are due, thinking that if 1 in 10 fails before they sell them then they are still quids in. So if you buy an ex fleet car with a full service history make very certain the belt has been changed, and unless it is specifically mentioned as having been replaced then change it.
Git
PostPosted: 18:48 - 19 Oct 2004    Post subject: Reply with quote
Worth an ask, cheers anyway Thumbs Up
new boy
PostPosted: 16:33 - 20 Oct 2004    Post subject: Reply with quote
you shouldnt find a piston gone they are guaranteed to bend a valve or two Sad you can rebuild it yourself two valves are not expensive but buy from renault you may need to spend 20 quid on tools to do the job but much better than the garage bills Laughing just take them out grind the new ones in and put it together use a haynes manual if your not sure they tell you everything
good luck Thumbs Up
by the way i am a qualified mechanic so its really no difficult
I need help
Git
PostPosted: 17:17 - 20 Oct 2004    Post subject: Reply with quote
Thanks for that new boy Thumbs Up
Replacing the valves I can do, well, on a diesel anyway, I'm a diesel fitter come air con/transport refrigeration type bloke so this little 8valve engine should be a breeze. have a haynes book and all looks relatively straight forward.
You have put a smile on my face about the guaranteed to bend a valve instead of kill a piston, if all goes well I should gain a few brownie points with gf Laughing
The last post was made 22 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 94.37 Kb
