zzr600 airbox causing splutter?
mysterious_rider
PostPosted: 15:41 - 11 May 2012    Post subject: zzr600 airbox causing splutter? Reply with quote
Hi guys, got my zzr on the road now and it will severely splutter if you try and go over 6krpm. She's restricted to 33bhp though.
it will happily go over 6kprpm without an airbox, why is it doing this? Is there anything else I can do other than run airboxless? Air filter is clean, and just to make sure I've cleaned it by hand.
cheers.
jjdugen
PostPosted: 16:35 - 11 May 2012    Post subject: Reply with quote
Is it a D or an E model? The E can be rekognised by the pointy frame member under the seat panels and air ducts in the nose of the fairing.
If an E then there is plenty for you to do.
mysterious_rider
PostPosted: 16:43 - 11 May 2012    Post subject: Reply with quote
it's a 1995 E model. cheers
PostPosted: 17:05 - 11 May 2012    Post subject: Reply with quote
Check the float bowls are getting pressurised from the airbox. Not sure how it is plumbed in for that on the ZZR though.
mysterious_rider
PostPosted: 17:06 - 11 May 2012    Post subject: Reply with quote
You mean that little contraption that forces air through? Does it make a difference? I disconnected it for the time being. I'll connect it back up then maybe? Cheers.
PostPosted: 17:11 - 11 May 2012    Post subject: Reply with quote
Depends if the airbox is still pressurised.
Carbs work by causing a low pressure point at the jets (by a small restriction, which causes the air to speed up, and faster moving air has a lower pressure), so the normal atmospheric pressure acts on the fuel in the float bowl and pushes it through the jet.
If you pressurise the air through the carb then you land up with a higher pressure above the jets than normal atmospheric pressure, so no fuel gets from the float bowl.
Solution is to pressurise the float bowls by the same amount as the intake air.
mysterious_rider
PostPosted: 17:32 - 11 May 2012    Post subject: Reply with quote
how would i do this? There is a tube that goes from carb to airbox. I cant remember If i connected it or not. Is it best just to block it off?
PostPosted: 17:45 - 11 May 2012    Post subject: Reply with quote
No, make very sure it is connected to the airbox.
jjdugen
PostPosted: 18:07 - 11 May 2012    Post subject: Reply with quote
Oh dear, the idiot Kawasaki 'ram air' system strikes again.
Take off the airbox, pull the large rubber tubes that go through the frame holes off the plenum chamber in the fairing sides. Now get some spray can caps and wrap some tape around then until they sit firmly in the frame holes.
Now take off the plastic tapered tubing that sits on top of the carbs, but leave the two rubber tubes connected to the carbs.
Next, disconnect the small bore tube that connects with the fresh air gubbins on top of the motor (it connects to the carb inlet rubbers via a plastic T piece). Block that with a suitable stopper, a bolt is fine.
You have now disconnected all the things that cause rough running. The fresh air thingy causes the middle two cylinders to run slightly lean so you will need to adjust the air screws a half turn or so, listen to the engine, it will run smoother as you get the right mixture. There are some carb iceing pipes in the way but these can be eased clear of the airscrew outlet.
Whilst in there, you might as well replace the plugs and check the HT leads and plug caps for any cracks.
All the above is a good thing to do, but, just to save you a little time, make SURE that the choke bar is returning fully to the off position, even a slight bit of choke will give some really rough running symptoms.... dont ask how I know. ( well, I chased a rough running engine around the workshop for two days before noticing the choke was ever so slightly 'on', Ho Hum we all learn).
mysterious_rider
PostPosted: 22:44 - 11 May 2012    Post subject: Reply with quote
can that ram air really make a difference? It's mostly only in 1st gear. It just hesitates a lot around 4k after that it pulls really well.
Other gears seem a bit better oddly enough.
Also, when its cold and i just start it, a few minutes on choke isnt enough. I have to revv it up quite a bit before it will revv over 5k at all, if i hold the throttle on full it'll just stop at 5-6k unless its warm. then it holds at about 12k.
Right, so I'll refit the airbox tomorrow but block off the ramair. I'll just remove the tubes and stuff old shirts down the large intakes Laughing
Oh yeah that weird load of tubing going to the middle cylinders WTF Just WTF. They suck better than a thai hooker! So block them off too? I will give it a go. Thumbs Up
moppy
PostPosted: 23:51 - 11 May 2012    Post subject: Reply with quote
I have a similar kind of problem with my ZZR6 E (99). Between 3 and 4K, there is absolutely no increase in power, feels very flat. But I think my bike is restricted, so it does make sense.
jjdugen
PostPosted: 07:25 - 12 May 2012    Post subject: Reply with quote
I shoud have asked what kind of exhaust you have fitted, too. The general opinion is that a four into one will give flat spots around 5K and 7K RPM. Mine did have that kind of hesitation with a Micron Nexus fitted, but the airbox work and some vary careful airscrew setups have eliminated that entirely.
Just to make life even easier for you, you can now safely disconnect the carb heating plumbing too, this gives really easy access to the airscrews.
It would seem that, when all the airbox/carb pressurisation system is new and properly sealed, it all works well. But, as soon as the ducting gets a little distorted it upsets the fine balance between air into the carb mouths and the air pressurising the float bowls. In turn, all the colder air from the front fairing scoops leads to the carb icing syndrome that these Kwaks are very prone to. With the airbox now breathing the warmer air within the frame, this does not happen any more.
Purists will say that cold air gives a better charge to the cylinder and this is true. However, carbs really like still air to breath rather than the turbulent stuff being forced in by the frontal air scoops.
Suffice to say, no other manufacturer has gone this route on carburettor fed engines.
mysterious_rider
PostPosted: 09:39 - 12 May 2012    Post subject: Reply with quote
Cheers.
Right I will do this today!!
I'll leave the carb cooling on for now, unless It's required to remove?
Seems like the whole air ram idea is a bit stupid really. Just aint workin' Laughing
also the exhaust is the standard 4 into 2 system. So twin cans.
I'll close it all up soon, I'll report back today. Thumbs Up
mysterious_rider
PostPosted: 11:10 - 12 May 2012    Post subject: Reply with quote
Hi mate printed out what you said and followed it to the letter. You were BANG ON! Bike runs like a dream!!!!! Airbox is all on and sorted and it runs really well. You absolute legend! Mr. Green Karma
thanks matey!
jjdugen
PostPosted: 13:38 - 12 May 2012    Post subject: Reply with quote
Thanks and a good job well done. Please tell Sickpup who thinks I am some kind of back street bodger.... Well... I do work in a backstreet.... and I suppose.......
mysterious_rider
PostPosted: 14:20 - 12 May 2012    Post subject: Reply with quote
Well it worked mate. So I'm happy. Will go and take her for a proper good spin now. Cool
PostPosted: 18:30 - 12 May 2012    Post subject: Reply with quote
It should work with the ram air in place.
However Kawasaki tended to jet their bikes to run at the lean end of normal. Fine normally, but anything that makes them run a touch lean (build up of cack in the jets, etc) lands up making them run too lean
mysterious_rider
PostPosted: 19:00 - 12 May 2012    Post subject: Reply with quote
Jets were 100% clean as were the carbs. I even blew through all the back passages behind the jets.
No idea what the problem was, maybe a split tube or something, however it runs so smooth now. Done a few miles today and the bike hasn't faultered. Twisted Evil
jjdugen
PostPosted: 22:58 - 12 May 2012    Post subject: Reply with quote
As I've said many times before, the little ZZR is a damn good bike. I bought mine as a £400 ratter to do up and sell on. Suffice to say its stilli in the garage. Mine came with a rough running motor that I initially put down to gummed carbs and dud plugs. It took me a good month or two of trying various fixes before I went the route I described. Basically, you are putting it back to 'D' spec, which is no bad thing.
The trouble with forced induction on carbs is that the incoming forced air is trying to push the mixture back down the jet tubes. So you have to counter this by pressurising the floatbowl by the same amount. All fine if the balance is kept, but hoses leak, airboxes distort, air filters become less porous, the balance can go out too many ways for my comfort. A bit of judicial pilot screw adjustment and you have a powerful and smooth motor. Spend a bit more time on suspension tweaks and the Z is just about the most accomplished of the affordable bikes out there.
PostPosted: 10:43 - 13 May 2012    Post subject: Reply with quote
Yep, doesn't take much. Worn needle, slightly sticking slides, float heights out a touch, split hose from the airbox to the float bowl, possibly even a float bowl leaking air slightly, etc. Any can affect the mixture.
mysterious_rider
PostPosted: 09:33 - 14 May 2012    Post subject: Reply with quote
Cheers guys. Done over 150 miles on her and it's ace. Thumbs Up It's not too bad on petrol either!
gotta sort out a few pieces, namely warped front discs. Rolling Eyes Laughing
Cool
There is a gap of 311 days between these two posts...
podge1967
PostPosted: 20:17 - 21 Mar 2013    Post subject: ram air problem Reply with quote
jjdugen
Think your onto summat there, i have a zzr 600e7 that has caused me no end of problems since i changed to s/s headers, which meant stripping down the front end, could i have missed a ram air pipe when i put it back together ?? it seems to stutter at 8-9000rpm in 6th effectively restricting the bike to 90mph unless i gear down to 4th and leather it which isnt really how it was designed to be ridden. Does the ram air system cause this if it isnt right ?
Thanks
mysterious_rider
PostPosted: 22:15 - 21 Mar 2013    Post subject: Re: ram air problem Reply with quote
podge1967 wrote:
jjdugen
Thanks
Well mine wouldn't rev over about 7k I think mate. Lowered even if in gear. It's worth a try to be fair.
KAWASAKIIIII
PostPosted: 23:22 - 21 Mar 2013    Post subject: Reply with quote
Are they standard headers? Or an aftermarket 4>1 system?
sickpup
Old Timer
PostPosted: 23:42 - 21 Mar 2013    Post subject: Reply with quote
Thing is you haven't actually cured the problem. It is a good work around but potentially introduces a new problem, tell us what it is?
The last post was made 13 years, 241 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 132.79 Kb
