Difference between nikasil and steel linears
cb1rocket
PostPosted: 12:50 - 11 May 2012    Post subject: Difference between nikasil and steel linears Reply with quote
Is there a picture showing the obvious difference between the two?
How would one go about knowing what to look for?
Teflon-Mike
tl;dr
PostPosted: 15:05 - 11 May 2012    Post subject: Re: Difference between nikasil and steel linears Reply with quote
Steel liner is steel, a slight dull blue-grey colour and usually cross-hatched in the honing marks.
Nikasil, is a Hard Chrome plating. It will be a lot shinier, and more silvery.
Look at the 'hard Chrome' on your forks, THAT is more like what Nikasil will look like.
Look at a bearing, from an engine or wheel, or better still a soft white metal bearing from a big-end cap; THAT is more like what a steel liner will look like.
You may also tell from the top of the barel. Nikcasil chrome is often applied direct to the aluminium of the barel. Steel liner will be a thick tube of steel shrunk into the ali, so you ought to see the actual material boundry in distinct concentric circles around teh bore... but not always, sometimes barels have nikasil chromed steel liners.
PostPosted: 17:16 - 11 May 2012    Post subject: Reply with quote
Nikasil will still be fairly dull. Needs the same style of hatched finish to hold the oil and stop it seizing.
However the easiest way to see is to look at the top and bottom of the barrel. A liner should be obvious.
PostPosted: 20:05 - 11 May 2012    Post subject: Reply with quote
Use a magnet. If it sticks - steel/iron, if it doesn't - aluminium ally & nikasil plating.
cb1rocket
PostPosted: 21:08 - 11 May 2012    Post subject: Reply with quote
Brill, thanks guys, the last one sounds good about the magnet use. Of course as Keith says it could still be a steel linear underneath! And thanks Tef!
Cheers for the tips!
The last post was made 13 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 46.37 Kb
