GPZ oil leak-- sightglass completely full...
Microcut
PostPosted: 21:08 - 11 May 2012    Post subject: GPZ oil leak-- sightglass completely full... Reply with quote
Hello,
I have had my GPZ 500s for a week now and the bike is leaking oil. The leak makes it way down to the left hand side (gear side). My knowledge of bike maintenance is 'developing' so my initial thought through some reading up may suggest an issue with the gaskets...as i had some parts of casing off (front spocket area) and there is no splash back or obvious leaking when the engine runs and revs. So it seems to originate from higher up and it is a slow graduate leak.
However, it leaks 'more' when on its side stand and less so when on the center stand. I noticed today that when it's on the center stand the oil in the sight glass completely fills it. Could it simply be that the oil was overfilled???
Previously it was always left on the side stand hence me not registering the sight glass as an indicator to the potential problem. Any thoughts?
Thanks.
MaybeGuy
PostPosted: 21:17 - 11 May 2012    Post subject: Reply with quote
You've overfilled the oil, and it's splashing up the crank case breather, into the airbox, and draining out of the airbox from the airbox drain. The drain is most likely on the side of the sidestand.
jimspeed
PostPosted: 21:20 - 11 May 2012    Post subject: Reply with quote
Hi it could well be that it's overfull which may be forcing oil up a breather into the airbox as I don't think there is many places for a leak on the left of the engine apart from the gear change shaft. maybe drain the oil out and refill carefully on center stand until its just below the top of the sight glass, mine takes a while to settle while filling so I put it in slowly once it gets somewhere near the right amount.
If it is overfull you can do damage to the engine by running it so do it asap. Thumbs Up
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
Microcut
PostPosted: 21:24 - 11 May 2012    Post subject: Reply with quote
thanks guys. I have only done about 60 miles on and off over this week since i've had it. Do you think i have caused any damage ?
I'll drain some tomorrow morning to bring it down.
flumpy7
PostPosted: 21:44 - 11 May 2012    Post subject: Reply with quote
It'll be fine, just drain some asap Smile
2012 Sinnis apache
PostPosted: 22:17 - 11 May 2012    Post subject: Re: GPZ oil leak-- sightglass completely full... Reply with quote
It's got "max" and "min" lines for a reason. Wink
You don't even have to drain it out of the sump, any sort of a tube and a syringe/pump will suck the excess out (with patience).
Usher4566
PostPosted: 09:49 - 12 May 2012    Post subject: Reply with quote
May be worth replacing your primary drive seal .!! Cheap and easy
New cd200 benly owner
Usher4566
PostPosted: 09:54 - 12 May 2012    Post subject: Reply with quote
Usher4566
PostPosted: 09:58 - 12 May 2012    Post subject: Reply with quote
When I first got my bike I would take for a ride put on side stand and drip drip drip on centre stand hardly any .I narrowed.it down to primary drive seal take front sprocket off and behind there is a rubber seal pushed in casing goes hard over years and let's oil escape .cost me 3 pound and took me 20 mins to fit and no leak since amazing .not saying yours is same but could well be .check u tube watch people fitting them on other bikes
PostPosted: 10:21 - 12 May 2012    Post subject: Reply with quote
It could be the drive seal, or the gear selector seal, but since he's already said that it's over-filled with oil, that's the first thing to sort.
Usher4566
PostPosted: 10:25 - 12 May 2012    Post subject: Reply with quote
Of course but as bikes New to him I would drop all old oil out because don't no how long its been in there smell oil because if level has gone up could be fuel in there.and next call would be changing seals for wat its worth don't cost much and if dripping when leaning my guess is same as mine primary drive or gear selector seal ..
Microcut
PostPosted: 12:19 - 12 May 2012    Post subject: Reply with quote
Alrite guys. I'm going to drain all the oil and refill it so it's obviously below the max indicator. As i'm taking it over to my uncles who definitely knows what he's doing, we'll (he will) look at other areas including those mentioned above. I get to see this operation in ation and so get to learn a lot for the future, so you could say my issues will enable me to learn more about general maintenance and repairs Thumbs Up
BTW. When i got the bike it had a oil change literally the day before. Also, just noticed the inside of the filler cap is milky white and the sight glass has a white-ish appearance. Maybe condensation.
PostPosted: 12:22 - 12 May 2012    Post subject: Reply with quote
Eek, it had never even occurred to me that you hadn't done an oil change as soon as you got it. It's the first thing I do on any purchased vehicle, regardless of what it might say on any service history.
Microcut
PostPosted: 12:24 - 12 May 2012    Post subject: Reply with quote
never fear roger...see above.
smegballs
PostPosted: 12:28 - 12 May 2012    Post subject: Reply with quote
Just to be a pedant, the primary drive is between the crank and the gearbox (or the crank and the clutch). The seal behind the front sprocket would be the output shaft seal.
The "primary drive seal" would be the oil seals on the main bearings in a two stroke. In four strokes the bottom end and gearbox/clutch is normally all in the same oil bath anyway. Replacing the crank oil seals on a two stroke s quite a major job as you need to split the crankcases!
HTH Thumbs Up
Microcut
PostPosted: 15:31 - 13 May 2012    Post subject: Reply with quote
Drained the oil, put it back to a noticeably better level and the area still leaks as it did before. So that has clearly narrowed it down to the suggestions above, as shared by my uncle....so this is the next port of call.
Usher4566
PostPosted: 17:21 - 13 May 2012    Post subject: Reply with quote
So what u gna do .have u read other oil leak post ?
Robby
Dirty Old Man
PostPosted: 17:38 - 13 May 2012    Post subject: Reply with quote
Leaking down from under the sprocket cover, thick black oil, mostly after a run when the engine is hot?
Not an oil leak. Accumulated greasy crud from chain lube fling off accumulates behind the sprocket cover, melts with the heat, and drips down.
Take off the sprocket cover, clean up the area, see if your leak disappears.
Usher4566
PostPosted: 17:54 - 13 May 2012    Post subject: Reply with quote
My bets on primary drive seal or gear shaft seal
Microcut
PostPosted: 18:11 - 13 May 2012    Post subject: Reply with quote
I think it's more towards the primary seal. The oil is not dark/thick and i've had the sprokect cover off, degreased and running with no signs of spluttering/flinging etc. Thanks for the input people Thumbs Up Hopefully get this sorted soon
Microcut
PostPosted: 18:13 - 17 May 2012    Post subject: Reply with quote
Would anyone be able to describe how I would go about accessing/ removing/ replacing the primary drive seal? specifically for the GPZ 500s A3 model (1990).
I ask because I want to t sort this out but my haynes manual does not deal with this operation. I don't have that ability to just 'do it'. I kind of need some guidance to direct me.
Thanks Thumbs Up
Usher4566
PostPosted: 20:32 - 17 May 2012    Post subject: Reply with quote
Not sure on gpz try u tube but on mine remove front sprocket.and carefully prise out with screwdriver then put new one in and make sure press it in evenly don't damage New one .don't worry bout oil pudding out coz it won't but u tube helped me gain coffidence by watching some one do it on a diff bike mz sumet.
The last post was made 13 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 114.29 Kb
