The BlackBird not responding after 4,000 rpm
dahhbuzz
PostPosted: 13:26 - 05 Oct 2004    Post subject: The BlackBird not responding after 4,000 rpm Reply with quote
Hi I have a 1997 Honda Blackbird with Carburettor. It moves ok on 1st gear. But from gears 2 - 6 when ever I hit about 4,000 rpm pls it begiuns to jerk and never passes 5000 rpm.
I have checked all the fuel lines, the jets nothing . I have used the brain box on another bike and it works fine, but when I re attached to my bike it was the same prob.
Can anyone help me with this
Thx
NickD
PostPosted: 14:03 - 05 Oct 2004    Post subject: Reply with quote
The carburated Blackbirds were noted for having a flat spot at around 4k, can you not pass through it at all?
I was only doing what it said on my licence officer....
Tear along the dotted line!
stryker
PostPosted: 14:27 - 05 Oct 2004    Post subject: Reply with quote
Is your battery well charged? A power dip owing to flat bat or duff alternator can starve the electric ignition of the power it needs to spark.
PostPosted: 14:29 - 05 Oct 2004    Post subject: Reply with quote
How long have you had the bike? If you have just bought it I would suggest checking to see if it is restricted to 33bhp!
Sounds silly but I reckon such a restriction might make the bike behave as you describe.
If you have had the bike a while, can you describe what lead to this loss of power?
Another possibility might be an air leak in the intake somewhere.
dahhbuzz
PostPosted: 18:08 - 05 Oct 2004    Post subject: Blackbird Issue Reply with quote
The bike was in an accident and was 'repaired' . Apparently I have been told that this is the 3rd Honda this is happening to by a friend of mine. All after crashes. Could this be a safety mechanism when a vital component has been damaged as even with a new carb the same prob still arises
Finglonga
PostPosted: 23:36 - 05 Oct 2004    Post subject: Reply with quote
Very very long shot.......
But is there a blockage in the fuel tank breather, as if there isn't enough air getting into the tank a vacuum will form and the engine will suffer from fuel starvation.
You can tell as If you open the tank after a ride the cap will hiss.
Like I said long shot.
Andy Sez....
F.Y.Y.F.F.
zzr_peak
PostPosted: 11:56 - 06 Oct 2004    Post subject: Reply with quote
i have the same problem with my kawasaki zzr 400 but it cuts out at 10,000 revs, and wont get round to 16,000
i have pretty much striped the whole;e thing, changes plugs, fule lines, about everything
i havent checked the tank breather (good idea)
and i have been told the problem can come from the ht leads where the join the caps. the can get corded and not make a strong enought spark, so.... chop half inch off and reattach the, worth a try.
The last post was made 22 years, 25 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 51.21 Kb
