| Omar15 |
 Omar15 Borekit Bruiser
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 20:52 - 13 May 2012 Post subject: |
click my profile button at bottom.
In there is link to the 'Pup-Project' thread. Snowie's 12 month renovation of a CB125 Super-Dream.
Twelve months and the price of a Brand-New YBR125, she has a bike worth just about as much as a three year old YBR......
But she has LEARNED a heck of a lot!
Restoration Projects are all good fun, but as an economical exercise?
Well, if you pick a bike that is worth money when done, that doesn't need TOO much doing to it, you MAY if you are cute enough, end up with something that is worth roughly what you spend on it.
BUT, as a learning excersise? Well, you wont learn much by avoiding big jobs, so, chances are, doing everything you might want or need to to learn how it works and how to repair/overhaul it.... you WONT be making the finished bike ANY more valuable.
Big bikes vs little ones?
NOT REALLY true little bikes are any 'easier' than big ones. They have same number of wheels, and 'stuff' and bits work much the same. Needn't have any more cylinders or more complicated suspension or anything either.
Old or New?
Older bikes will tend to suffer from more obsolecence issues trying to track down parts; but that can be a problem on some fairly recent machines, depending. Also used to be true older bikes tended to be lower tech and simpler design, but even THAT is not so true these days and a twenty year old Honda VFR400 is probably no less convoluted than a modern ZX6R or something.
Advice?
Think long and hard what you want at the end of the day, & how much its worth TO YOU.
Bike YOU have built with your own hands, is a thing of joy, regardless, and there is no greater buzz than the shear GLEE of riding, and knowing that that piston slapping up and down is doing so becouse YOU put it there and put everything around it.
BUT.... if its not going to DO anything else, like shove you along at the rate you want to go; if its not going to be apreciated by others at meets or ride outs, or its got no other 'purpose', getting you to and from, or anything, its NOT going to ALL be worth while.
So pick something to 'restore' that you would BUY to RIDE.
THEN cost up how much it will cost to renovate and decide whether the difference.... probably a significant one, and MORE than you would pay for a rider, is WORTH the learning you hope to get from it, AND that 'feel-good' glee of having built it with your own fair hand, AND knowing that its probably a lot 'better' than anything you could have bought on the open market.
And plan on KEEPING the thing once done, and riding the value out of that premium by USING it. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Timmeh |
 Timmeh World Chat Champion
 Posted: 21:49 - 13 May 2012 Post subject: |
I went in at the deep end and got myself a non-running '95 CBR600 to fiddle with.
There isn't much difference between a single and a sensible, carbed IL4. Both have forks, suspension, wiring loom, controls and lights.
For example; you rebuild virtually every RWU fork the same way; the only thing that changes is the size they are. Brakes, whether it be single-piston, two pot slideys (like the CBR) or four pots (like my RVF) are all done using the same method.
The only real difference is the engine and that an IL4 is bigger and will require some more specialist tools if you fancy rebuilding it.
However, if its your first go and rebuilding an engine then I'd suggest a stroker as they are far easier and have no valves or cams to worry about. 125 2T engines are fabulously simple things and quite easy pull apart and rebuild. It's also fairly hard to make a complete mash of it and unlike an engine with cams you won't destroy your head if you get the timing wrong.
  ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
| temeluchus |
| pepperami |
 pepperami Super Spammer
 Posted: 22:14 - 13 May 2012 Post subject: |
A single cylinder two-smoke, has to be about as easy as it gets  ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| ruck bodgers |
 ruck bodgers Trackday Trickster
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 09:53 - 14 May 2012 Post subject: |
| stupidgit wrote: | you dont have to go for restoration . you can mix and match find some wheels pick a frame get some forks and so on maybe start with a rolling chasis or a complete bike perhaps youd want to swap the engine or lower it and opt for a single sided swing or wtvr you want . you may well learn to weld and work metals along the way doing your own fabrication and adapting parts to fit you will learn a lott more that way about all aspects needed to make a good bike . for instance say you had a cx500 and you was restoring it you would have to source parts specific and wouldnt be doing much more than tidying it up and bolting pieces on possibly rebuilding an engine . but if you dont make your objective to restore a bike . and instead just to make a bike your not so limited you can build somthing really special to yourself and using second hand parts that are overlooked or you can find cheaper after having researched sizes and to see what will fitt or you can make fit to your fixtures . restoration jobs can be exspensive but making a bike may turn out cheaper . it would most probably take more time as theres more thought to go into it but you will learn more . thats how i learned on my own .
ps .you may also end up spending more time making them than riding them in the end wich is a trap i have fallen into . i love to build them as much as to ride them.|
have fun |
Tend to find that doing a renovation, I will incorporate more than a 'few' improvised repairs, adaptations & custom 'features'.
Well, while you have it apart.... yeah, why NOT use the handle-bars that you like, or put the pegs where you REALLY want them, or while dealing with the wrigglies, add a fag lighter socket or LED flashicator, or whatever.
For a rebuild virgin though....... KISS....... Keep-It-Simple-Silly.
And top Tip I forgot in earlier post; PICK A BIKE YOU CAN GET A WORKSHOP MANUAL FOR!
If you HAVE a book, you can do it BY the book.... anything you want to know, will USUALLY be IN the book, so there ought not be anything in there that you cant 'solve', its just a matter of gettig the parts.
When you start trying to mix and match; very easy to start with an 'Idea'... "Geez! They want £70 for a fucking FOOT-PEG! Stuff that, I'll get one of a Honda and make it fit MY bike....."
After spending £20 on the bit that dont fit, and scratching your head trying to work out HOW to make it fit, and without the engineering skill or resources, you can end up having to fork out the £70 you didn't want to at the beginning, over whatever you have wasted, or, you end up paying some-one £50 to knock you up a bracket to make the wrong bit fit.... then find you cant line up the exhaust..... "Ah! Oh well, I JUST need to bend this pipe a bit and move that hanger bracket...."
does give you more scope for being creative, and can make oportunities to 'improvise' to save money....
BUT, risks are that it WONT save you money, WILL cause 'knock-on' problems, and ultimately not do anything particularly 'useful'.
My 750, was a 'Cheap-Hack', and I've improvised fixes and fabs along the way. Used foot-pegs as an example; it's one of the 'custom' features of my bike. My DARLING little brother, decided to 'help' by moving the bike for me so Step-Dad could put his car on teh drive when I was visiting.....
OK.... so I need a new foot-peg hanger then.... Thanks BRO!
Of course, its the aluminium casting that's cracked clean through, and gawd-awful thin wall thing that is not going to be glued or easily welded, and SILLY money to replace new from honda, and £70 a side, offered from breakers on the bay.....
Pondering what to do, looking whether after-market rear-sets may be a cost effective solution..... pegs are a bit far forward for me anyway..... I ponder making my own, but dont have suitable steel, though do have basic welding kit & skill to use it... a 'mate' who has a fab-shop suggests he can knock up a pair of brackets for me, and doing a favour for him, with some Landy-Bits he needs for his comp-buggy... we wicky-worky and I clear some clutter and gain a pair of custom rear-sets.
Good-Good.......
But I NOW have 'another' declarable mod on the insurance....
Yeah, didn't cost me anything..... at least not ion cash, at the time... but does cost, and every year come renewal.....
And these sort of things NEED to be taken into consideration.
Many insurers wont take bikes with more than three declarables now.
1/ Dawg is knacker-Blacked.... according to Insurance thats 'Non-Standard Paint'
2/ Has an after-market exhaust - declarable mod.
3/ Has 'custom' footrest hangers - declarable mod
4/ has non original handlebars - declarable mod
5/ had non original headlamp - delcarable mod
6/ has after market 'Hagon' shock - declarable mod
Add a fag-lighter accessory socket for a sat nav; you have another, add heated grips, yet another, add a luggage rack, more still, and do it goes on.
This bike is NOT particularly 'custom' and hardly 'accessorised'. It's just an 'old' bike, with worn out or broken bits repaired with 'available' spares.
Yet; with more than three declarables, list of insurers that will offer cover shrinks drastically, so chances of finding savings drops, and I'm down to specialists, and talking to people who insure 'customs' asking daft questions like, 'Do you have an engineers report for the rear suspension modifications' - its a pair of Hagon shocks FFS!
Not insurmountable, but unnecessary 'hassle', for something that was SUPPOSED to 'save' money and 'hassle'. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Blau Zedong |
 Blau Zedong Banned
 Posted: 10:19 - 14 May 2012 Post subject: |
Suzuki X5.
HTH  ____________________ 18:54:48 Rob Fzs: jews don't give away stuff for free
18:54:59 Rob Fzs: unless its their clothes/ hair/ golden teeth |
| jjdugen |
 jjdugen World Chat Champion
| ruck bodgers |
 Posted: 13:08 - 14 May 2012 Post subject: |
i agree . infact after posting i thought i should of kept it simple for him .
i dont know about all that insurance buisness mike i dont really tell them anything . have some v5s and a reg . the rest is a secret. |
| Efes123 |
 Efes123 World Chat Champion
 Posted: 18:44 - 14 May 2012 Post subject: |
Listen to the Tef, he knows
I've just embarked on exactly this. I ended up with a pretty old (1984) Suzuki GS 125. I went for the 125 because it is simpler than a bigger bike, maybe not by much, but when you're starting out from scratch like me, it all helps.
I also went for it because there are still plenty of parts available for it (thanks Nick). Also, a 125 is light, that means you don't need any lifting equipment.
What's probably going to cost you, if you don't already have them, is money for tools. Why is it that the size of the nut is dictated by the size of the socket you haven't got I ended up spending a fortune and getting a big fuck-off set of everything But, now I can't afford to buy any bits for a while
You certainly need to resign yourself to spending a lot more than you're going to get back from the sale. But just think of all the knowledge you'll have, and that's going to be priceless when it comes to maintaining your own bike.
After last weekend, this is where I'm up to;
https://www.dogfriendlysuffolk.com/bikepics/IMG-20120512-00042.jpg
Minus the pegs, shocks, and chain guard. Just now waiting for my new frame to arrive along with its V5 (mine's a cat B).
Whatever you decide to get, post up the pics. ____________________ Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD |
| grant965 |
 grant965 Brolly Dolly
| Omar15 |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 21:07 - 14 May 2012 Post subject: |
| grant965 wrote: | if its purely to learn, get a cheap chinese 125, spares/repairs come up for sale all the time for barely any money. |
did you get the bit where I said, "Pick a bike you would would buy to ride"
Canton-Kintukki-flied left-overs are cheap, granted, and pulling one to bits to see how it works probably one of the few worthy uses for one...
But to learn mechanics, and how to overhaul, recondition, and repair, you have to start buying bits to make 'good'... and lets face it, most of these Clinky-Chinkies aren't very good to begin with.
Parts can be fairly cheap and are readily available, BUT?
For what one costs, and what one's worth, might as well fork out that LITTLE bit extra and get a real Deal Honda CG or CB/CM/Rebel, and do that....
You'll end up using self same chinky bits of e-bay for exact same price....
But instead of having, probably one of the BEST built Chinky bikes on the road, thats still only worth £400 taxed, tested and ready to ride.... at a maximum of 62Km/h or whatever the legal speed limit in Kawloon is.... you'll have something with a genuine Honda maker's plate, worth twice that much, for self same money and effort, that can probably do 62mph ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
The last post was made 14 years, 157 days ago. Instead of replying here, would creating a new thread be more useful? |
