Rear brakes failed
Bubbs
PostPosted: 18:08 - 14 May 2012    Post subject: Rear brakes failed Reply with quote
Just riding home and my rear brakes just failed. They were working intermittently then went to use the rear while coming up to a roundabout and nothing, had to use front brakes instead.
Just got it home and pushed the footbrake to check the brakes and brake fluid came shooting out....fuck.
Need to get to work tomorrow, think I could get away with using just the front?
Sako
PostPosted: 18:09 - 14 May 2012    Post subject: Reply with quote
if my rear brake failed it would be a looong time before i noticed!
never really use it!
anthony_r6
PostPosted: 18:13 - 14 May 2012    Post subject: Reply with quote
On a sports bike, probably yeah. I'd always be concerned about not having the back as a backup to the front though. Mind you, I rode mine recently without any front brake and got to my destination okay. Just think ahead and don't race around using harsh braking.
moppy
PostPosted: 18:17 - 14 May 2012    Post subject: Reply with quote
I honestly wouldn't know if my rear brake was working or not. It is never used by itself, always with the front brakes...
Bubbs
PostPosted: 19:03 - 14 May 2012    Post subject: Reply with quote
I use it for scrubbing off speed in corners and when it's not there I really notice it. You'd be suprised how much it's actually used.
iooi
PostPosted: 19:09 - 14 May 2012    Post subject: Re: Rear brakes failed Reply with quote
So did the fact that they were not working all the time prompt you to look at them Rolling Eyes
Well you do have ALL evening to look at the brakes and fix them before tommorow. Thumbs Up
Bubbs
PostPosted: 20:03 - 14 May 2012    Post subject: Re: Rear brakes failed Reply with quote
No they were working fine, then suddenly today on the way home started playing up. They just failed as if there was no fluid in lines. Then pumping got them working again. I can't fix them myself as I don't have a paddock stand to get the rear wheel off, which is a bit shit. Still in the process of moving house and that is the item I don't have.
Wish the brake was like my SV and just undo the bolts to take the brakes off.
anthony_r6
PostPosted: 20:34 - 14 May 2012    Post subject: Reply with quote
What do you want the back wheel off for?
Check the line for leaks, check the caliper for leaks, check pads, and disc, bleed brakes?
Bubbs
PostPosted: 21:01 - 14 May 2012    Post subject: Reply with quote
the brake fluid is leaking from inside the brake caliper assembly which i cant get to without disconnecting it from the bike... with my ninja that means wheel has to come off. Sad
Fizzer Thou
PostPosted: 00:23 - 15 May 2012    Post subject: Reply with quote
It does sound as though the distortion seal has split.Or is the caliper a two piece design where the two bolt together?In which case it might be the small 'O' ring that seals the two together.
Always have a 'Plan B'
Walloper
PostPosted: 00:30 - 15 May 2012    Post subject: Reply with quote
What's a rear brake?
Only use it to pass your bike test then you can remove it.
CaNsA
PostPosted: 00:31 - 15 May 2012    Post subject: Re: Rear brakes failed Reply with quote
You can.....
There are 2 bolts holding the caliper to the hanger.
Undo them - fix it - win
Bubbs
PostPosted: 07:47 - 15 May 2012    Post subject: Re: Rear brakes failed Reply with quote
CaNsA wrote:
You can.....
I don't think there is on my model. Will check though.
sickpup
Old Timer
PostPosted: 08:13 - 15 May 2012    Post subject: Reply with quote
What are you talking about?
Acemastr
PostPosted: 08:43 - 15 May 2012    Post subject: Reply with quote
I got an advisory last year on my MOT for low rear brake pads, I got the same advisory on Friday... for the same pads Very Happy
That's how often I use the back brake, it's shockingly useless.
Should be easy to fix too, barely anything to it.
2016 Toyota Tacoma Limited
The last post was made 14 years, 150 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 85.87 Kb
