Steering Problem
iCraig
PostPosted: 20:42 - 05 Oct 2004    Post subject: Steering Problem Reply with quote
Well I noticed when I set off from a set of traffic lights yesterday, that when I pulled away (rather quickly) the front end began to, how can I put it, wiggle from side to side like it was beginning to tank slap and then settled down.
I also noticed it when I took both hands of the bars it did it then too for a short period.
I have checked the steering head bearing and it seems normal, and all the front end seems all tight and everything, so I am thinking it may be down to the tyre pressures, I changed them from what Kawasaki recommended to Bridgestones recommendations and the bike felt more stable with these but do you think it could cause this phenomina or could it be something else I haven't checked?
Thanks In Advance
Craig
PostPosted: 20:53 - 05 Oct 2004    Post subject: Reply with quote
maybe this just happens to all bikes when they pull away briskly. Especially those that are slightly faster than a GS500E! Wink
billy whizz
PostPosted: 20:58 - 05 Oct 2004    Post subject: Reply with quote
There has been millions of pounds spent researching the "tank slapper" phenomena but no real evidence points to any one factor being the major cause of one. They do know that a combination of things will cause one more readily i:e tyre pressures, steering geometry, suspension and wheel base. You could spend a lot of time and money and still get one just when you don't want it, my best advice is to fit a good quality steering damper as your bike has shown that it is susceptible to them.
Here comes the summer! Smile
PostPosted: 21:31 - 05 Oct 2004    Post subject: Reply with quote
I notice that you rated that 'funny' Craig. Nah, I mean it. My SV used to do that, my Trumpet does it occasionally too. Its nowt to worry about unless it does it when you /aren't/ pulling away! Smile
iCraig
PostPosted: 22:03 - 05 Oct 2004    Post subject: Reply with quote
I rated it funny, cos the GS was so sodding slow and crap and I thought that was what your hinting at Laughing.
As you say most bikes may do it just thought there maybe something wrong, but I've never ridden something this fast and handles so well (compared to a GS500 that is).
PostPosted: 22:09 - 05 Oct 2004    Post subject: Reply with quote
A soft rear tyre will do that though, especially if you take a pillion without increasing the tyre pressure.
iCraig
PostPosted: 22:24 - 05 Oct 2004    Post subject: Reply with quote
The rear tyre is at 2.7 BAR, which is what Bridgestone recommend.
And my tyre pressures are checked weekly Confused.
jonboy
PostPosted: 23:22 - 05 Oct 2004    Post subject: Reply with quote
If the front wheel lifted off the floor slightly and then touched down slightly off straight, it would explain it. All bikes have a tendency to do that.
PostPosted: 23:46 - 05 Oct 2004    Post subject: Reply with quote
They are listed in the workshop manual as 32psi rear, so 2.7 bar sounds quite high.
However it is a GPZ500. Check for play in the rear suspension linkage. Find it then get a bush made up (the bushes new from Kawasaki are just as bad).
Also really check the steering head bearings carefully.
PostPosted: 12:11 - 06 Oct 2004    Post subject: Reply with quote
Forgot you were talking about a GPZ500s.
If there is less than 2mm of tread on your front tyre it will do this and get progressivley worse as the wear increases.
I also find that BT45s also go through a 'phase' about 3-500 miles after they are put on of 'odd' handling which passes within about 50-100 miles.
It is just a 'feature' of the bike. If you want to see how bad it can get, put continental tyres on it! (actually, don't, you will fall off)
iCraig
PostPosted: 14:59 - 06 Oct 2004    Post subject: Reply with quote
The bike has had 2 brand new BT45's fitted about a 1000 miles ago, so theres plenty of tread on them and the tyre pressures are set at what bridgestone say.
Weirdly the bike didn't do it today when setting off from the same lights it has done it at before :\.
iCraig
PostPosted: 22:40 - 06 Oct 2004    Post subject: Reply with quote
I had a ContiBlitz on the rear when I first got it (along with the OE Dunlop on the front) And I know what you mean the rear end slid about like it was on ice even when the roads were dry Shocked.
iCraig
PostPosted: 11:04 - 16 Oct 2004    Post subject: Reply with quote
Well following on from my first few posts I have noticed that the wheel is moving about very slighty on the axle, I will tighten the bolts to see if that makes any difference if I doesn't then what else could it be? Wheel bearings?? Confused
PostPosted: 11:11 - 16 Oct 2004    Post subject: Reply with quote
99% likely to be the wheel bearings.
PostPosted: 20:17 - 16 Oct 2004    Post subject: Reply with quote
The front wheel bearings went on my GPZ500 at about 28k miles if that is any help.
If you are going to replace them, don't get them from a bike dealer, they take the piss with their prices. Look in the yellow pages for a bearing factor, if you go in with the number stamped on the side of the bearing race (or take the old one with you), they will do them for 2.50 to a fiver each. They will have them in stock as it is a very common size.
iCraig
PostPosted: 11:23 - 17 Oct 2004    Post subject: Reply with quote
Your telling me, I went to Millenium Motorcycles, my local Kawasaki dealer and they were quoting £25 for 2 wheel bearings and 2 oil seals he said I needed too!
I'm not really confident in doing it myself anyway, as I think I was the one that damaged the bearings when I took the front wheel off last month for a new tyre so I think I'll buy some bearings from elsewhere and get someone who knows what there doing to fit them!
PostPosted: 12:11 - 17 Oct 2004    Post subject: Reply with quote
Grab the bearings. The seals should be replaced but I would not bother normally if you are getting rubber sealed bearings ("6202 2RS" I think for the front of a GPZ500S). I am free next weekend I think so if you want you can wander down and we can fit them.
PostPosted: 12:31 - 17 Oct 2004    Post subject: Reply with quote
What I usually do with those bearings is to prise one of the rubber seals off each one, fit the first one with the open end towards the centre of the wheel, install the tube-spacer then pack the gap round it with grease, I then fit the other bearing over the top of it. This gives you a 'pool' of grease rather than just relying on what is inside the bearing.
iCraig
PostPosted: 17:23 - 17 Oct 2004    Post subject: Reply with quote
Well having checked the bike out this morning and a friends checked it out too there doesn't seem to be any play what so ever in the front wheel, and my mate said he didn't reckon the wheel was moving at all on the axle, so it must just be my defective eyes. Confused
Yet the bike is still showing signs of the "wiggling", I've now also noticed it doing it about 30-50MPH If I take my hands off the bars or just have them lightly in my grip. So I am still non the wiser of whats up with the bike Confused.
Oh and Keith thanks for the offer of helping me do them, I may have take you up on it Thumbs Up.
Hex
Party Boy
PostPosted: 18:11 - 17 Oct 2004    Post subject: Reply with quote
Wheel out of ballance or head bearings?
Or just your looking for something to be wrong as you think it feels different. Razz
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
PsychoHippy
Jammy Git
PostPosted: 18:16 - 17 Oct 2004    Post subject: Reply with quote
I had this on the ZZR when I didn't align the rear wheel correctly after adjusting the chain. Just because it's affecting the front end, you can't rule the back end out.
I spend all my money on bikes and beer, the rest I simply waste!
iCraig
PostPosted: 19:30 - 17 Oct 2004    Post subject: Reply with quote
Would sort of explain why it only started shortly I had my rear tyre replaced.
Oh and Hex, I would expect a bike to be steady when I take my hands off the bars on a smooth road like the rest of my bikes have been so yes its all in the feel.
iCraig
PostPosted: 15:52 - 19 Oct 2004    Post subject: Reply with quote
Well thanks for all the help guys but I am still non the wiser of what is up with the front end as its still feeling a tad weird so to put my mind at rest I have decided to book the bike in with a session with the local mechanic who hopefully will diagnose any problems he finds Smile.
iCraig
PostPosted: 23:07 - 25 Oct 2004    Post subject: Reply with quote
Cheers guy for all the help, it was the tyre pressures after all as the mechanic said.
I rang Kawasaki today and they confirmed they recommend 32PSI in the BT45's and not the 36PSI Bridgestone recommend!
So Middle Finger to Bridgestone and Thumbs Up to Kawasaki Smile.
The last post was made 21 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 128.92 Kb
