| Meshuggah |
 Meshuggah Scooby Slapper
 Posted: 19:18 - 16 May 2012 Post subject: downgrade front sproket |
Hello everyone, searching the net I've found out that if you replace the standard front sprocket (16 teeth) with a 15 one the bike responsivness in the lower range should be much better. for my 2005 fz6 I've found this one https://www.ebay.co.uk/itm/290691282115?_trksid=p5197.c0.m619.
I would like to have your opinions about this.
will it be quite simple to replace the sprocket? I suppose just remove the old one and put in the new one.
Do I need to modify the chain anyhow?
is the brand of this sprocket renthal a good one?
does this mod affect the speedometer?
thanks again for your input. ____________________ Triumph Tiger 800 2012 |
| Sload |
 Sload World Chat Champion
 Posted: 19:37 - 16 May 2012 Post subject: Re: downgrade front sproket |
| Opeth wrote: | Hello everyone, searching the net I've found out that if you replace the standard front sprocket (16 teeth) with a 15 one the bike responsivness in the lower range should be much better. for my 2005 fz6 I've found this one https://www.ebay.co.uk/itm/290691282115?_trksid=p5197.c0.m619.
thanks again for your input. |
Its down size or down tooth or down gear really, down grade would suggest you are fitting a lower quantity part.
It will adjust your gearing increasing your potential acceleration whilst reducing your top speed.
It should be a fairly easy task if you are ok with spanners. As to the chain, it will depend on how much adjustment you have. You are in effect taking out a links worth of circumference from the sprocket so you may need a smaller chain, I don't know specifically on your bike. If you are serious you may be able to get a suitable front and rear set with chain for your bike. If you are doing the front and chain you want to fit a new rear anyway. Just remember going down one on the front is about the same as going up 3 on the rear. Another consideration is by dropping the front sprocket you may cause the chain to foul on the swing arm or chain guard etc, you need to check this really.
As to the speedo, it will depend where your pickup is. Mine is on the front wheel so it has no effect for me personally. ____________________ Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx |
| Sako |
 Sako World Chat Champion
| G |
 G The Voice of Reason
| Sako |
| G |
| Taught2BCauti... |
 Posted: 20:26 - 17 May 2012 Post subject: |
My Varadero 125 has a 14 tooth front and a 44 tooth rear as standard. I use a 15 tooth front for longer journeys where I can maintain a good cruising speed with lower engine revs, and reach higher road speeds before the rev-limiter kicks in.
I also use a 13 tooth front for better acceleration around town and on journeys where steeper hills would be a problem for the 15 tooth - and where higher top speeds are not required.
I don't bother much with the 14 tooth, but the difference between 13 and 15 is quite noticeable! ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
The last post was made 13 years, 220 days ago. Instead of replying here, would creating a new thread be more useful? |
