Are these baffles removeable?
EazyDuz
PostPosted: 16:42 - 15 May 2012    Post subject: Are these baffles removeable? Reply with quote
Cant find much info on the exhaust. It sounds nice but was wondering if it is possible to remove the baffles too. Its a Remus one. All i could find were 2 bolt things on the inside side of the exhaust, but they arent allen head bolts, they are just circular...
https://i605.photobucket.com/albums/tt134/Kurt_V/SV206322.jpg
https://i605.photobucket.com/albums/tt134/Kurt_V/SV206332.jpg
https://i605.photobucket.com/albums/tt134/Kurt_V/SV206327.jpg
EazyDuz
PostPosted: 16:48 - 15 May 2012    Post subject: Reply with quote
Oh just found some info of them:
https://translate.google.co.uk/translate?hl=en&sl=de&tl=en&u=http%3A%2F%2Fforum.milwaukee-vtwin.de%2Fthread32515-biete-remus-slip-on-endschalldaempfer-eg-genehmigung-r7-e4-0061.htm
These are slip on...well i checked my plugs and the are a nice tanned colour, so its running right regardless.
Does this suggest my carbs have different sized jets in them? Thanks
keggyhander
PostPosted: 18:06 - 15 May 2012    Post subject: Reply with quote
They're rivetted in. Don't take them out, they're too large in diameter to run open pipes. It would run like a pig, even jetted up.
What I did was drill several holes using a 400mm long, 10mm diameter drill bit through the back plate and right through any subsequent baffling.
It allowed a portion of gas and noise to bypass the baffles whilst still maintaining a modicum of back pressure.
If you want open pipes, you'll have to get some straight drag pipes about 40mm diameter.
EazyDuz
PostPosted: 18:11 - 15 May 2012    Post subject: Reply with quote
Your bike won't have been jetted up already, that system is designed as a stock replacement, despite the visual differences from standard.
Ive only seen Viragos with proper pipes built for them, like highway hawk or jardine. Take it i couldnt use 2 slash cut generic slip ons could i? Do you think my carbs have been rejetted, or maybe the Remus was made for the virago so its running standard jets
EazyDuz
PostPosted: 22:45 - 15 May 2012    Post subject: Reply with quote
bump
EazyDuz
PostPosted: 08:55 - 17 May 2012    Post subject: Reply with quote
anyone?
nisp
PostPosted: 12:07 - 17 May 2012    Post subject: Reply with quote
I would just drill them out, and if it dosn't sound good rivit back in Thumbs Up Mr. Green
but thats just me
Suzuki TS 50 1999 Honda CB 125 t2 1981 Yamaha XJ 600 s Diversion Honda cx 500 MZ ETZ 250 1985 Yamaha FZR 400 1981 Suzuki TS 185 1984 Triumph bonneville 790 2001 MZ TS250 1979 Suzuki sv 650 1999 KTM exc RFS 450 2007 Hercules mx 125 1976
nowhere.elysium
The Pork Lord
PostPosted: 12:15 - 17 May 2012    Post subject: Reply with quote
It won't sound good. I can guarantee it.
The budget slashcuts won't really do your bike any favours; they'll eliminate almost all of the backpressure, and won't sound great. More to the point, if they're the proper el cheap-o-rama ones that I'm thinking of, then they'll look like crap in about fifteen minutes, anyway. I fitted one of the bean-can ones to my 125, and there was about 5mm of baffle material around the outer skin of the thing, and that's it. It did nothing to limit noise, and was clearly not designed to actually do anything, as such.
The last post was made 13 years, 229 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 57.25 Kb
