honda vfr400r nc30
bike crazy
PostPosted: 19:12 - 17 May 2012    Post subject: honda vfr400r nc30 Reply with quote
Hi.
I have honda vfr400r nc30.
I have the 180kp/h speedo on.when my speedo shows 100kph I am apparently
actually doing 132kph according to my brother in law when he rides next to me.
How can I fix this?
2nd.I have a top end of 230kph on the dyno.but on my speedo it never even reaches 180.
I know apparently there is a restrictor plate built into the speedo that can be bypassed.
I know it has not been done on mine.so if I do it will it give me even more top end?
Apparenty there is also a "black sector on the indicator needle shaft"
Where do I find this shaft.
Can anyone help?
bike crazy
PostPosted: 19:29 - 17 May 2012    Post subject: Reply with quote
Just another question.
How could I increase my acceleration?
It is quite sluggish at the moment on pull off.
I know its not my motor as I had it checked.
Its almost as though my clutch is sticking, but only on pull off.the rest of the gears
It runs smooth?
Please help
Richy CB1000
PostPosted: 21:22 - 17 May 2012    Post subject: Reply with quote
Don't know about your specific model, but my import has the clocks to 180km/h ( 112mph?)
This I believe is the restricted speed imposed on Japan's roads, including monsters like the Nissan GTR etc...
My bike ( Honda CB1000) has the clocks and therefore restrictor originally and would not go over 115mph.
Also there is a "limiter wire" or something connected up in the speedo, no one with the Big One's seems to sure about it.
However the solution that works on mine and others, fit a speed converter between the end of the speedo cable and the clock housing, these reduce via gearing inside the input speed of the cable into the speedo.
So when mine says I'm doing 60kmh on the clock it's really now 60mph so no need to cover over the numbers on the face etc...
This tricks the speedo as obviously I cant get to 180kmh on the clock (which would now be actually 180 mph) so the limiter does not come into force anymore allowing me have had a go upto 135mph after which I gave up as I couldn't hang on!
They're around £25 so worth a punt......
bike crazy
PostPosted: 21:33 - 17 May 2012    Post subject: Reply with quote
Thanks.I will look into it.
It makes sense that it is showing mph.
The max I get it to show on my clock is 160kph on a nice long stright road.
Wich there is a lot of on my way to work.
But I will have a look at a converter
Jim Mc
PostPosted: 05:03 - 18 May 2012    Post subject: Reply with quote
If your stop speed is indicated @ 160 it wont be mph, it must be out a fair bit.
bike crazy
PostPosted: 05:12 - 18 May 2012    Post subject: Reply with quote
That's the problem.
How can I fix it.
Its a bit difficuilt when you go past a speed trap not to get caught
craigs23
Mr Muscle
PostPosted: 05:59 - 18 May 2012    Post subject: Reply with quote
Couple of points I can think of:
- Is your brother's speedo accurate (as all speedos are inaccurate to a degree, albeit not to the amount you mention)?
- What gearing are you running on your bike? The speedo drive works from the front sprocket on an NC30, if the gearing's out, it will effect your speedo reading.
- Easiest way I found to bypass the 180kph restrictor is to fit a Motrax speedo convertor (or similar) - it makes the speedo read in mph rather than kph, so as the bike will never hit 180mph, the restrictor won't activate anymore.
MaybeGuy
PostPosted: 07:02 - 18 May 2012    Post subject: Reply with quote
Isn't there a restriction in the clocks on an nc30? It's as simple as bending a metal tab out of the way. Fitting a mph conversion to it also fixes it.
bike crazy
PostPosted: 07:12 - 18 May 2012    Post subject: Reply with quote
My brother in law rides a suzuki tl1000s with a digital clock.so I am sure he's is rite.
The problem is my sppedo never reaches 180.
But I know for a fact my top end is round 240.I have tested that theory on the dyno machine and the track.using a radar.
So the limiter in the clock probably never kicks in as it only reaches 160kph on the clock.
But by then I'm doing about 240 actual speed
Formerly known as
P.
PostPosted: 07:35 - 18 May 2012    Post subject: Reply with quote
So you think your VFR400 will do 150mph.
Laughing You'll get 130mph at best. Even then...that would be indicated.
A digital clock doesn't make it correct.
Is leepick your brother in law? Are you related to the cumberland sausage family?
Check your gearing against the stock gearing for the VFR.
Choices are to either fit a resistor (see 400greybike forum) or quit bitching and only do 160kmh... its still around 100mph
bike crazy
PostPosted: 08:17 - 18 May 2012    Post subject: Reply with quote
Actually I have a full yoshi system, big bore pistons, gas flowed head,different sprockets.
So trust me.its not just 160kph.
My only question "paddington" is will it make a difference if I benf the limitor plate back inside the speedo.
Or how to get my speedo to show the correct speed without changing the clock?
Formerly known as
P.
PostPosted: 08:19 - 18 May 2012    Post subject: Reply with quote
Then its not a VFR400 then, its something like a VFR460 with an super duper exhaust and the wrong gearing.
The best way to check your actual speed is a GPS. That will give you a closer genuine speed.
bike crazy
PostPosted: 08:23 - 18 May 2012    Post subject: Reply with quote
Thank you.
That's what I needed to know
shereen
PostPosted: 08:27 - 18 May 2012    Post subject: Reply with quote
Even 130mph is optimistic. Top speed out the factory was 128mph I believe, I doubt 20 years on its is still doing anywhere near that. My nc30 over read massively at top end, I was off the clocks several times. Laughing My dyno read out was impressive, however dynos do not take into account wind resistance.
Formerly known as
P.
PostPosted: 08:40 - 18 May 2012    Post subject: Reply with quote
I know Laughing Was like..shit its still pulling?? Its at the end of the clock Laughing
map
Mr Calendar
PostPosted: 08:55 - 18 May 2012    Post subject: Reply with quote
Getting back to basics and as said above I wouldn't depend on anyone else's speedo either. Best bet would be to try a sat-nav system and get the speed reading from that. Several million dollars of US military hardware versus a few pounds on a cable and gear system - you know it makes sense Very Happy
Failing that you could try another digital speedo system. I think there are those similar to found on push-bikes that you can use if correctly calibrated (magnet on wheel with pick-up on forks).
HTH Thumbs Up
Richy CB1000
PostPosted: 20:58 - 18 May 2012    Post subject: Reply with quote
Seems like you have a couple of issues,
1 A speed converter is needed to remove the top end restriction
2 As said by others above, check the sprocket as it reads of the front one so if it's not standard it will be displaying the wrong speed
The last post was made 13 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 93.33 Kb
