| ROG. |
 ROG. Derestricted Danger
 Posted: 12:40 - 20 May 2012 Post subject: Trailer towing:- B and B+E licence rules explained |
Not sure if this is the right forum to post this in but it seems from doing a forum search that some may need my help with this...
I hope you will find this useful - many other sites have.
GOOGLE (copy & paste) the title below to confirm this.
Trailer MAM means the maximum weight the trailer can be when fully loaded (weight of empty trailer plus weight of load)
Trailers over 3500 kgs plated MAM weight come under different rules which is why all the trailers towed by B class vehicles, those of 3.5 tonnes and under, are not plated at more than 3500 kgs or 3.5 tonnes MAM
Trailers without plates use the total of the TYRE LOAD RATINGS to determine the MAM.
A rating of 66 on 4 tyres would give a MAM of 1200 kgs.
Vehicles in the B licence category will have the following information on a plate in the vehicle, in the handbook or on the V5 form.
Information can also be found on many internet vehicle specification sites.
Unladen or Kerb weight - although there is a slight difference in the two it is not that much
GVW - the max weight the vehicle can weigh when fully loaded
GTW - the max weight the vehicle and trailer can ACTUALLY weigh when added together. This does not refer to the total of the vehicle GWV and trailer MAM weights.
Towing capacity - this is the ACTUAL weight that can be towed by the vehicle - it does not mean the trailer MAM weight.
None of the above weights must be exceeded
Some vehicles have a GVW, a towing capacity and a GTW. In such a case the GTW takes priority over the GVW and towing capacity when added together
FOR B+E LICENCES
Where a towing capacity is listed then this would be a legal example:-
CAR has GVW of 2000 and a towing capacity of 1800
TRAILER has a MAM of 3500 and an unladen weight of 1000
The trailer can be loaded with a maximum weight of 800
Where there is not a towing capacity listed then the GTW is used
GTW minus the GVW does not give the towing capacity unless the vehicle is fully laden
EXAMPLE: -
VAN has GVW of 3500 and GTW of 6000
TRAILER has MAM of 3500
The van and trailer can weigh 3000 each and be legal
FOR B LICENCES
The Gov sites are not that good at explaining this so perhaps my simpler way of explaining will help.....
To tow over 750 kgs with a B licence you need to comply with these rules:-
The plated MAM of the trailer must not be more than the UNLADEN/KERB weight of the towing vehicle
The GVW of the towing vehicle plus the plated MAM of the trailer must not add up to more than 3500 kgs
The ACTUAL weight of the empty trailer and its load must not be more than the listed towing capacity
Example of legally towing over 750 kgs with a B licence - made up figures but not that far from what can be found....
Towing vehicle -
Unladen/empty/kerb = 1500
GVW = 2000
Towing capacity = 1800
Trailer -
Unladen/empty = 800
MAM = 1500 (Perhaps originally a 2000 MAM but downplated by manufacturer so it conforms to B licence towing)
Load trailer with 700 max
Reasons it is legal for towing on a B licence -
The 1500 MAM of the trailer is not more than the 1500 unladen/empty weight of the towing vehicle
The 2000 GVW of the towing vehicle plus the 1500 MAM of the trailer is not more than 3500
The towing capacity/actual weight being towed does not exceed 1800
Here is another way of looking at the B licence towing rules with examples:-
RULE 1 - The gross plated weight of the trailer (MAM) cannot exceed the vehicle kerbweight.
RULE 2 - Also, the sum of the vehicle gross plated weight (GVW) and the trailer gross plated weight (MAM) cannot exceed 3500kg.
Examples:-
Vehicle 1200kg kerbweight, 1700kg gross plated weight (GVW) = maximum trailer gross plated weight (MAM) 1200kg SEE RULE 1
Vehicle 1500kg kerbweight, 2000kg gross plated weight (GVW) = maximum trailer gross plated weight (MAM) 1500kg SEE RULES 1 & 2
Vehicle 1800kg kerbweight, 2300kg gross plated weight (GVW) = maximum trailer gross plated weight (MAM) 1200kg SEE RULE 2
The weight which can be loaded on the trailer is the trailer gross plated weight (MAM) minus the trailer unladen weight
Trailer gross plated weight (MAM) 1500 with unladen weight 900 = a maximum load of 600
The listed maximum towing capacity for a vehicle must not be exceeded - that is actual weight not plated MAM weight
Although there is not a specific law which states this there are other laws which can be used if the combination (vehicle & trailer) is deemed unsafe.
Caravan weights work on a slightly different system as they take into account the recommended (not legal) 85% towing advice
SUPERVISING A B+E LEARNER
In April 2010 new rules were introduced for those supervising certain learner drivers but they only affected those supervising VOCATIONAL categories such as C1 C1+E D1 & D1+E where the supervising driver had those categories given to them for free when they passed a pre 1997 car test.
They do not affect those with a pre 1997 B+E licence who wish to supervise a B+E learner.
All B licence holders have B+E provisional on the paper part of their licence and can tow an empty or loaded trailer on all roads including motorways.
The usual rules apply when a learner is driving -
The supervising driver must be aged over 21
The supervising driver must have held a B+E licence for at least 3 years
L plates must be fitted to the front of the vehicle and the rear of the trailer
Correct insurance for a B+E learner
Many will find that passing the once in a lifetime B+E test is their best option so here is some info on that test:-
The B+E test
No medical or theory test required
Read a number plate from a certain distance
VIDEO - Show Me Tell Me Questions - usually 5
The next three can be in any order:-
VIDEO - Reversing Exercise (old measurements) - done in test centre grounds if test conducted from practical test centre - some tests are now being done from training school grounds
VIDEO - Uncouple/couple up - done in test centre grounds if test conducted from practical test centre - some tests are now being done from training school grounds
One hour road drive - includes the independent drive and is done virtually the same as the basic car test
DISCLAIMER - I have no connection to any companies which may be featured in those videos
I hope this helps those who are unsure of the rules
Please post with this info if you want me to answer a specific query - weights in kgs please
(might be made easier if the info below is copied and pasted with the weights etc put after the '=' bits)
LICENCE
B or B+E =
VEHICLE
Unladen/kerb =
GVW =
GTW =
Towing capacity =
TRAILER
Unladen =
MAM = |
| Moo. |
 Moo. World Chat Champion
 Posted: 13:27 - 20 May 2012 Post subject: |
Considering this is a motorbike forum, the main questions were about towing with an A category... trailers for motorbikes, or could a motorbike tow a motorbike that has broken down.  ____________________ A2 Passed 18/6/10 |
| ROG. |
 Posted: 13:29 - 20 May 2012 Post subject: |
I have done an internet search and it seems many motorbike transporter trailers are unbraked so perhaps this legal info will be useful:-
Any unbraked trailer must not be more than 750 kgs MAM and must not have a MAM greater than half of the towing vehicle kerb weight
That means if the kerb weight of the towing vehicle is 1300 kgs then the maximum unbraked trailer MAM (not actual weight) cannot be more than 650 kgs
If anyone has an unbraked trailer that has too high a MAM then it can be downplated by contacting the manufacturer of that trailer
The cost is usually free or for a minor admin cost ____________________ Trailer towing:- B and B+E licence rules explained |
| ROG. |
| J4mes |
 J4mes World Chat Champion
| ROG. |
| ROG. |
| st3v3 |
This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
 st3v3 Super Spammer
| Quornholio |
 Quornholio World Chat Champion
| ROG. |
| DrDonnyBrago |
| Quornholio |
| J4mes |
| st3v3 |
 st3v3 Super Spammer
| st3v3 |
This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
 st3v3 Super Spammer
| MG |
 MG Traffic Copper
| groovylee |
 groovylee World Chat Champion
 Posted: 00:19 - 21 May 2012 Post subject: |
sorry st3v3, but he is right. i have just gone through all of this as i am looking at getting a caravan soon for family hols.
cheers for the informative post ROG.  ____________________ Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R |
| Ste |
 Ste Not Work Safe
 Posted: 00:26 - 21 May 2012 Post subject: |
| Quornholio |
| J4mes |
 Posted: 08:18 - 21 May 2012 Post subject: |
| st3v3 wrote: | Well show some offcial fucking proof then, im not risking my licence based on what some clown on the internet said.
May as well take legal advice from warped!
I took my view from inspection of the Direct.Gov site.
No proof has been provided to counter it. |
https://www.direct.gov.uk/en/Motoring/DriverLicensing/WhatCanYouDriveAndYourObligations/DG_4022547
what, this direct.gov site which clearly explains the rules? You know, the "official proof" from the "official website" from the "official government" who lay down these rules?
B
Motor vehicles with a MAM of up to 3,500 kg, no more than eight passenger seats, with or without a trailer - weighing no more than 750 kg
17*
B
As category B but with a trailer weighing more than 750 kg. The total weight of the vehicle and the trailer together can’t weigh more than 3,500 kg. The weight of the trailer, when fully loaded, can’t weigh more than the unladen weight of the vehicle
17*
B auto
As category B with automatic transmission
17*
B+E
As category B but with a heavier trailer that isn't covered in the descriptions for category B
17
I looked in to it, I've taken the test. |
| ROG. |
 Posted: 11:37 - 21 May 2012 Post subject: |
I can understand some sceptisism as I am not an 'official' and if those who do not wish to believe what I am saying is correct then they have the choice to do that - no problem
My intention is to simply inform in a simple way what the Govt DVLA site says but that site does not make things as clear as it could be for many and does not have real life examples for comparison
For many it has been very useful in saving them loads of money they would have spent passing the B+E test which they did not actually need.
I would imagine that most on this site would be using cars to tow trailers with M/Cs on where, in many cases, the total MAM/GVW would be under 3500 kgs so therefore not needing the B+E?
The one rule that catches many out is the one for UNbraked trailers (750 kgs MAM or less) where it states the MAM of the trailer must not be more than half of the vehicle kerb weight
That is very easy for a roadside official to check on if stopped ____________________ Trailer towing:- B and B+E licence rules explained |
| ROG. |
| MG |
 MG Traffic Copper
| ROG. |
| MG |
 MG Traffic Copper
The last post was made 14 years, 113 days ago. Instead of replying here, would creating a new thread be more useful? |
