A lot more wind noise with windshield attached
EazyDuz
PostPosted: 14:34 - 21 May 2012    Post subject: A lot more wind noise with windshield attached Reply with quote
Since attaching my windshield it has made high speed riding more comfortable, however anything over 40mph and i hear much more wind noise than without a screen. Is there a way to fix this? I have the screen tilted back at the same angle as the front forks, thanks
map
Mr Calendar
PostPosted: 14:49 - 21 May 2012    Post subject: Re: A lot more wind noise with windshield attached Reply with quote
EazyDuz wrote:
...anything over 40mph and i hear much more wind noise...the screen tilted back at the same angle as the front forks, thanks
Suggest you change the angle or get a different size screen.
The extra noise is because the wind is being deflected onto your helmet. It needs to go either over your head or onto your chest (although that would defeat the object of a screen). Some screens have an extension piece that breaks up the airflow around it.
Just some thoughts.
t121anf
PostPosted: 14:49 - 21 May 2012    Post subject: Reply with quote
has it just raised the wind from your chest to your head?
.Bishbash.
PostPosted: 14:52 - 21 May 2012    Post subject: Reply with quote
100% what map said, it's being deflected onto your head, as a test, when said wind hits you, slowly duck down until it goes away.
Different angle or a taller screen is needed.
Current bike - GSX-R1000 k8
EazyDuz
PostPosted: 15:56 - 21 May 2012    Post subject: Reply with quote
Well at faster speeds it is a great improvement, but the wind noise is horrible. If i duck my head its not as bad, but if i move my head side to side even slightly i hear wind coming from the sides too
Walloper
PostPosted: 16:07 - 21 May 2012    Post subject: Reply with quote
The screen makes an area of low pressure behind it. This sucks air in at high speed which in turn whips around your head, neck and chest.
You need to break the vacuum somehow or deflect the air current.
You can but things to clamp on top to do this but I am not convinced they offer all that they say they do.
The screen on my big bike is electric adjustable. The standard screen I found for my height was shit no matter where is was positioned.
I asked for the longer screen but even this is about 2" too short as I can only find a 'quiet' zone if I lean forwards and hunker down a bit which is useless.
I may look at the clip on things designed for this problem.
The only thing is I don't know if it don't work I can send it back. I will ask that before I buy.
This is what I'm banging on about.
https://www.nippynormans.com/products/f650stcsgsdakar/item/wunderlich-universal-screen-extension-clear-wun-8110025
EazyDuz
PostPosted: 17:25 - 21 May 2012    Post subject: Reply with quote
Might sell it then. Its a tough one, did 90mph earlier comfortably except for the noise, whereas without the screen even 60mph is uncomfortable due to wind throwing me about but then i dont go deaf, so i dont know which is better.
It is a cruiser after all though, not like i'll be going fast on it much anyway...
snikks
PostPosted: 17:40 - 21 May 2012    Post subject: Reply with quote
Keep screen, fit it for any longer journeys and wear ear-plugs? if it seems fine other than noise..
- CBT: 02/01/11 Theory: 26/04/11 Mod 1: 19/05/11 Mod 2: 19/08/11
- 2007 Honda XL125V Varadero (Sold), 1999 Yamaha FZS600 Fazer (Sold), 2001 CBR600F
keggyhander
PostPosted: 17:44 - 21 May 2012    Post subject: Reply with quote
90 is too fast really for the 535. The front end is not heavy enough.
PostPosted: 18:00 - 21 May 2012    Post subject: Reply with quote
Cut a hole in the middle of the screen.
HJM
PostPosted: 18:12 - 21 May 2012    Post subject: Reply with quote
snikks wrote:
wear ear-plugs?
"90% of all statistics are made up"
CBT-18/04/2013
EazyDuz
PostPosted: 19:44 - 21 May 2012    Post subject: Reply with quote
It performed well considering.
And screw it im selling the screen, hate the stupid thing anyway, i feel less freedom with it on as well.
keggyhander
PostPosted: 08:23 - 22 May 2012    Post subject: Reply with quote
Good man. Now your bike won't look terrible.
The last post was made 14 years, 111 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 76.79 Kb
