cbf 125 air box..
LockyUK
PostPosted: 19:32 - 21 May 2012    Post subject: cbf 125 air box.. Reply with quote
i did this out of interest https://www.youtube.com/watch?v=U1HCv9S2Axo, is there any downsides to it ?? it looks to me like the only possible reason for that plastic bit is solely to reduce the noise ?? thanks...
neil.
PostPosted: 19:43 - 21 May 2012    Post subject: Reply with quote
It's called a resonator and is meant to reduce air intake noise. Because you removed it, you'll also be sucking unfiltered air into the engine, not to mention increasing the airflow, possibly making the engine run lean unless the fuel injection system compensates by adding more fuel, but then you'd lose fuel economy.
LockyUK
PostPosted: 19:47 - 21 May 2012    Post subject: Reply with quote
so the only potential down is the unfiltered air ? im gonna see how it is and go out for a ride when i change the exhaust Smile
neil.
PostPosted: 19:50 - 21 May 2012    Post subject: Reply with quote
Unfiltered air and a lean mixture (do you want a hole in your piston?), or at best reduced fuel economy if the FI system can compensate. I would leave it alone.
LockyUK
PostPosted: 19:56 - 21 May 2012    Post subject: Reply with quote
i see, probably best to leave it then..
dungbug
PostPosted: 19:57 - 21 May 2012    Post subject: Reply with quote
You don't want filtered air getting through chap, you let no end of cack into places you don't want it. Wink
CBT: Pass 25/06/2011 Theory Test: Pass12/06/2012 Mod 1: Fail 08/07/2012
Mod 1 Retest: Pass 15/0702012 Mod 2: Pass 03/08/2012
Suzuki GN125 (Sold) ~ Current bike: Yamaha YZF 600R Thundercat
LockyUK
PostPosted: 16:37 - 22 May 2012    Post subject: Reply with quote
ok i have ruled that out, now what about this..
it is french btw https://www.honda125cbf.com/topic/2825/la-solution-ultime-admission-directe/start/51/
would this void my warranty, i assume so ?
There is a gap of 351 days between these two posts...
Tellstar4000
PostPosted: 21:50 - 08 May 2013    Post subject: Reply with quote
Have just done this mod for noise purposes( staying alive) but have adapted it to at least try and protect engine,buy a cheap plastic kitchen sieve,cut a round in the thin plastic mesh big enough to cover hole and go round the outside,then use compression clip which was holding original on to seal around. Tube with mesh over hole and down side.simples,can double up mesh or use inline washing Maschine pipe filter from water inlet feed pipe with tape to secure,at least will give some filtration but increased noise will keep dozy drivers awake,hope helps
Zzzz
PostPosted: 22:59 - 08 May 2013    Post subject: Reply with quote
Urgh. Just rip out the whole airbox and slap on a cone filter.
J.M.
PostPosted: 23:01 - 08 May 2013    Post subject: Reply with quote
Lol.
Lol.
2004 R1 & 2018 XSR900
bodger
PostPosted: 08:52 - 09 May 2013    Post subject: Reply with quote
Tellstar4000, I think what J.M. is trying to say is as follows-
Bodging on a piece of wire mesh over the hole is not going to make any difference to the filtration.
It will still be unfiltrated air getting into the engine.
Also as already been mentioned, the carburation will be adversely affected, giving a weak mixture, possibly resulting in a damaged engine.
Bike manufacturers dont spend large sums of money on developing engines only for someone to come along and "tune" them by sticking a panscrubber in the inlet..
Best advice , leave alone, or, if you must, buy an aftermarket air filter, and if you do that you may still have problems with weak mixtures
J.M.
PostPosted: 10:03 - 09 May 2013    Post subject: Reply with quote
Also that making your bike "louder" by drilling holes in the airbox is not going to make car drivers hear you and therefore be "safer".
Tellstar4000
PostPosted: 21:14 - 10 May 2013    Post subject: Reply with quote
Thought it would at least help but have taken your advice and am going to wait till gbmoto exhaught back in stock,no performance gains but at least my son hopefully will be heard and therefore seen.in meantime air filter back to normal
Zzzz
There is a gap of 8 years, 242 days between these two posts...
neil.bardsley
PostPosted: 09:44 - 06 Jan 2022    Post subject: Reply with quote
New to the forum and working on bikes. My son recently bought a Honda cbf 125. I checked the air filter. I was surprised how hidden away the intake was. I saw this thread. Does the engine have a pre/post air/fuel sensor to adapted the mixture? I'm guessing not from this post?
Evil Hans
PostPosted: 10:09 - 06 Jan 2022    Post subject: Reply with quote
Welcome.
Telling us the year of the bike might get a more informed answer.
And not making me read through a ten year old thread to get to your question would make me a lot happier ... Wink
It's entirely possible that the bike is newer than this thread Smile
neil.bardsley
PostPosted: 10:26 - 06 Jan 2022    Post subject: Reply with quote
Evil Hans wrote:
Welcome.
Thank you.
2017 Honda cbf 125. Just found this
https://bikesandtravels.com/biker.aspx?ride=750
Appears that the 125 injection does have an air flow sensor so would correct the mixture for more air coming in.
My other son bought a yamaha 125. Which seems a little simpler to work on.
Easy-X
PostPosted: 12:40 - 06 Jan 2022    Post subject: Reply with quote
Is there an actual problem at the end of this thread resurrection?
xX-Alex-Xx
PostPosted: 13:46 - 06 Jan 2022    Post subject: Reply with quote
I've said it before .... the option for autolocking old threads needs to be turned on.
DILLIGAF
Rob Fzs
PostPosted: 14:44 - 06 Jan 2022    Post subject: Reply with quote
This forum is half dead and doubt the Admin visits once a year, scroll on
'00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30> Yamaha RD350 YPVS F2 > Kawasaki ZZR 600 D1 > Yamaha TZR 250 2MA >Suzuki TL1000R > Yamaha TDR250 > Honda 929 blade > Suzuki SV1000 > Honda H100
Mod 2 Passed 09/06/2011
PostPosted: 15:13 - 06 Jan 2022    Post subject: Reply with quote
You're familiar with the features of phpBB in 2002?
Evil Hans
PostPosted: 17:15 - 06 Jan 2022    Post subject: Reply with quote
neil.bardsley wrote:
2017 Honda cbf 125.
Told you.
If it's a 2017, are you sure it's a CBF125 and not a CB125F ?
The last post was made 4 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.86 - MySQL Queries: 13 - Page Size: 111.12 Kb
