Chicken Strips?
frostage
PostPosted: 21:36 - 21 May 2012    Post subject: Chicken Strips? Reply with quote
Just got home from scrubbing in a new rear tyre and had a little look at the chicken strips, noticed something I thought was strange.
On the rear tyre, I have about 15mm of clean rubber on either side, whereas on the front tyre its more like 20-25mm.
Is this a common thing or does it indicate a shortcoming in my cornering technique?
Any opinions would be appreciated
2000 Gixxer 750
1995 RM 250
Gone2mars
PostPosted: 22:02 - 21 May 2012    Post subject: Reply with quote
Could be preload or your lean angle around corners ... You can probably go a little further Smile
WannaBeDude
PostPosted: 22:11 - 21 May 2012    Post subject: Reply with quote
Front is harder to rid of strips than reAr and harder on 125s
Afaik ... Embarassed
MaybeGuy
PostPosted: 22:19 - 21 May 2012    Post subject: Reply with quote
Chicken strips are pretty much non-indicative of ''ability''. Front is always more unless you drop the forks through the yokes a little.
Sam_Y_93
PostPosted: 22:35 - 21 May 2012    Post subject: Reply with quote
Mines the same, got about 3mm on the rear and about 8mm on the front which is annoying as it means my front tyre still has those little nobly bits on it still Laughing
MattJ
PostPosted: 22:37 - 21 May 2012    Post subject: Reply with quote
What matt said. Mine are bigger on the front than the rear by a long way. Just the way the tyres are made. I can only speculate why.
hornetmike
PostPosted: 22:40 - 21 May 2012    Post subject: Reply with quote
I've got none on the rear 20mm on front, but rear is only a 160
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
MattJ
PostPosted: 22:49 - 21 May 2012    Post subject: Reply with quote
Does the width make a difference? How far you can lean with grip is down to the angle of the tyre at the edges, I wouldn't have thought there would be a direct correlation between width and angle, I would think it depends on the type of tyre. Does anybody know?
Edit: I have 120 and 160 and the front has 5-10mm more than the rear.
Mikey3
PostPosted: 22:52 - 21 May 2012    Post subject: Reply with quote
I think the front has a lot tighter curve on it than the back, mine has like, hardly anything on the back, about 1mm ish, and the front like a good cm. but the sides of teh front are far more curved round than the back one.
Mike
'04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it'
Acemastr
PostPosted: 23:04 - 21 May 2012    Post subject: Reply with quote
I've got about 6mm on the rear, can't bloody get rid of it!
Front has a good 10mm or so
2016 Toyota Tacoma Limited
Old Git Racing
PostPosted: 23:10 - 21 May 2012    Post subject: Reply with quote
How come I don't have any on the front then with forks where they are set OEM, might just have a really little bit to do with ''ability''. Bikes are designed with aspect ratio (that's what they call it) of the tyres to use both fully, but only if you have the ability of course.
OGR
(Ducks back down behind the parapet and waits for the incoming Smile )
lihp
PostPosted: 00:02 - 22 May 2012    Post subject: Reply with quote
https://a1.sphotos.ak.fbcdn.net/hphotos-ak-prn1/535631_10151430761615324_763710323_23035314_1607900580_n.jpg
That is my rear
https://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash3/574987_10151538703615324_763710323_23397025_1055484276_n.jpg
And that's the front.
OGR, You think that rear can go far enough to use the remainder of the front?
T0MMY
PostPosted: 00:13 - 22 May 2012    Post subject: Reply with quote
OGR
It might still be the profile of the tyres. It's not possible to reach the edge of my front tyre because the profile makes it too steep.
Not sure if what you say is true about how the profiles are selected as mine are non-standard sizes but the above is certainly true for me...it's not physically possible on my bike to remove the chicken strips on the front tyre.
ZX6R + CBR600RR
Walloper
PostPosted: 01:07 - 22 May 2012    Post subject: Reply with quote
I have Chicken Strips on my shoulder pads.
Cool
Front tyre profile is different from the rear which means a bigger or smaller 'relative percentage' of the surface can contact the road.
It could be an un-matched pair.
.Bishbash.
PostPosted: 10:47 - 22 May 2012    Post subject: Reply with quote
It's the profile of the tyre chaps. Look at this....here are my Hornet numbers;
Rear - 180/55/17
Front 120/70/17
First part is the width of the tyre
Second is the height of the tyre
Third is the diameter of the tyre
The 2nd part is making the difference here regarding chicken strips on the front, it will go evenly if you lean your bike over more as the front has a steeper edge.
HTH
Current bike - GSX-R1000 k8
keggyhander
PostPosted: 11:38 - 22 May 2012    Post subject: Reply with quote
Was wondering this myself. I've only got 10mm on the back and yet 20mm on the front.
robbieguy2003
PostPosted: 13:17 - 22 May 2012    Post subject: Reply with quote
For me it changes from bike to bike. I suspect riding style and the tyre profile play a big part.
My 1250 has maybe 10mm on the back and maybe double that on the front. My 600 has bigger strips on the back and front despite me riding it significantly quicker through corners on the same routes.
I tend to ride the 1250 and 600 very differently though, I'm relatively still on the 1250, upper body movement and move my arse off a little bit if anything, but I'm all over the 600 and hang off more which keeps the bike more upright.
I've rode it without hanging off and it doesn't feel as happy, but you can get rid of strips much easier.
Current Bikes: Honda CBR 600RR - '07, Suzuki GSX1250 FA ST '11
Old Bikes: Suzuki Intruder 125 LC - '2001, Honda CBR 600F - '92, Honda CBR 600RR - '03
Fizzer Thou
PostPosted: 13:35 - 22 May 2012    Post subject: Reply with quote
On my R1 I am using a 120/70x17 Pirelli Diablo Corsa 3 and a 190/50x17 on the rear.The unused band on the front is a good 20mm whereas on the rear it is more like 5mm.
But if it were to be the size of the tyre as a contributing factor,the 120/70x17 Pirelli Dragon Corsa that I have on the front of the Exup1000 would wear similarly.But the unused band is more like 5mm whereas the 180/55x17 rear is about 10mm.
I think that it may well come down to tyre pressures,which will dictate the contact patch and how much the tyre deforms,as well as the weight of the bike and profile of the tyre.
Always have a 'Plan B'
MG
PostPosted: 13:41 - 22 May 2012    Post subject: Reply with quote
Mike
+1 Thumbs Up
Bang on
'03 Honda Cityfly 125 > '02 Honda CB500S > '98 Honda CBR600F
The last post was made 14 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 113.08 Kb
