BCF Workshop Guides & Handy Links
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2, 3, 4
Nb
PostPosted: 05:50 - 22 May 2012    Post subject: Reply with quote
Not sure if theres a noob guide to using a multimeter on here, there seems to be tons of electrical problems lately.
Arrow https://www.genebitsystems.com/david/MotorcycleElectrical/index.htm
TheSmiler
PostPosted: 21:25 - 01 Sep 2012    Post subject: Reply with quote
Cg125 Manual
https://cpi.shs.net.pl/files/Poradnik%20warsztatowy%20Honda%20CG125%20(Workshop%20Manual).pdf
DMCpro
PostPosted: 16:36 - 22 Jan 2013    Post subject: Reply with quote
Does any one have a PDF service manual for a "Suzuki ts 125 x"
Would really appreciate it thanks.
Honda CB-1, TS125X
VW Golf Estate
TheSmiler
PostPosted: 03:56 - 30 Jul 2013    Post subject: Reply with quote
https://www.themotorcyclemedic.com/
fireball1111
PostPosted: 08:08 - 13 Aug 2014    Post subject: FX 650 starter problem Reply with quote
I have just purchased a 2001 Vigor.
It is a non runner and at first check it seems the starter is constantly engaged. Where can I find information on fixing this problem?
Thanks Richard
tifrap
PostPosted: 23:53 - 26 May 2015    Post subject: Re: Small DIY motorbike repair guides collection Reply with quote
250xc wrote:
My buddy is an ex pro mechanic with a passion for repairs which don't cost money!
some of his repairs are at https://howto.werideonsundays.com, but please excuse the poor spelling as we are stil in the process of tidying up the English.
some of the topics covered:
Repairing your old and or beaten-up seat cover
Plastic fuel tank repair
Fixing dents on your fuel tank (good before trying to sell!)
Fuel tank rust removal
Dead contact points
Repair broken spark plug / high tension wires
Bringing dead spark plugs back to life (for the ultra-budget conscious!)
Getting home on busted radiators/radiator hoses (test scenario)
Cracked clutch cover
Unsticking your engine’s piston rings
Cracked carburetor insulator tubes and air filter box tubes
Overhauling old carburetors
Repairing an exhaust pipe full of holes
Repairing 2 Stroke Performance chambers with glass wool inside
2-stroke muffler overhaul
EMERGENCY CHAIN REPAIR
DAMAGED RIMS AND SPOKES
RIM BEAD STOPPER
FUN WITH OLD TIRE INTERIOR TUBES
TUBE TIRE PUNCTURE REPAIR
REAR SHOCK ABSORBER REPAIR
HOW TO CHECK SWING ARM LINKAGE
MORE FORK REPAIR TIPS
FORK ALIGNMENT
HOW TO REPLACE NEW FORK OIL SEALS THE CHEAP WAY
Shaking steering head
HOW TO CHECK THE STEERING STEM FOR ALIGNMENT
SQUEAKING BRAKES
BRASS WASHER REPAIR
HOW TO REPAIR STUCKED BRAKE /CLUTCH / AND MASTER CYLINERS
My cable snapped, I’m f#$ked!!!
HOW TO REPAIR CLUTCH / BRAKE THROTTLE WIRE CABLES
HOW TO REPAIR A BENT CLUTCH OR BRAKE LEVER
HOW TO REPAIR A BENT HANDLE BAR
HOW TO REMOVE AND TO REUSE OLD HANDLE BAR RUBBER OR PLASTIC GRIPS
Mickey Mouse turbocharger repairs
Radiator Repair
Power Antenna
Can Spray Painting
How to clean old dirt bikes plastics
Water damaged engines
Do I need to remove the entire cylinder head?
Improvise
Checking swing arm’s linkage (easy way)
Automatic gear box problem
Fork oil change
How to clean performance chambers that have sound baffles or glass wools inside
2 stroke muffler Overhaul
Sticky Cables
How to change fork oil seals the cheap way
Getting home (MacGyver-style)
How to use carburator cleaner and engine conditioner
How to make plastic shine again
How to reuse a used brass/copper washers for pipe fittings
Easy tire change for tubeless tires
Stucked brake/clutch master cylinders
Tips on clutch disc replacement
How to change new handle grips
Handle bar, Steering stem and Fork alignment
Dead battery and electrical components
don't know if that'll help anyone, but thought it might belong on the list.
Cheers,
Leon
I was curious enough to want to read some of these, but found that the site was long dead - but then remembered this:
https://archive.org/web/ and there it all is.
might be useful for other non forum threads here too.
bikertomm
PostPosted: 20:45 - 30 Jul 2015    Post subject: Reply with quote
I have recently written a thread in the workshop that's very detailed and pic heavy on how to change your bikes oil / service your bike.
Aimed at the newer riders.
https://www.bikechatforums.com/viewtopic.php?t=304726
Hope it's of use to someone, cheers. Thumbs Up
SamanthaBfast
PostPosted: 16:42 - 25 Jan 2019    Post subject: Reply with quote
Hi there could someone share a haynes manual for a 06 Yamaha Cygnus X 125 Furl Injection Model Please?
https://www.facebook.com/smartanddesigns/?fref=ts
Groovin
PostPosted: 19:01 - 08 May 2020    Post subject: Reply with quote
This is a very helpful thread, with lots of good information, even if some of it is quite old, its still very relevant in lots of areas.
Thanks for thinking of providing it.
valentino_wp This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
MCN
PostPosted: 03:14 - 11 Dec 2023    Post subject: Reply with quote
We like decals of other guy's Dik-Piks.
I hope that helps. Thumbs Up
Page 4 of 4
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 79.84 Kb
