| coggie |
 coggie Two Stroke Sniffer
 Posted: 21:14 - 12 May 2012 Post subject: NEED MAJOR HELP, fuel spitting derbi |
hi guys,
i really need some help.
I've been building my derbi gpr 50cc (72cc) from ground up.
new crank shaft n seal, airsal tuned 72cc top end.
Metra kit exhaust, tnt 21mm carb. k and n.
I'm now having a bit of trouble,
the bike had been sat in the garage a week and fuel is ending up sitting in the exhaust (stupidly left fuel on). i emptied it and
the bike start up after a few seconds on the starter motor.
but as soon as its running its spitting fuel out the exhaust,
a fine mist at idle but when you rev it ( not gone over 6K) it seems to spit splashes of fuel out the exhaust.
id really appreciate so help if any one has ideas,
thanks very much guys. ____________________ 2005 Derbi Gpr Replica, Airsal 70cc kit, K&N, Doppler Racing Crank, Metrakit Pro Carbon Exhaust, Metrakit Carbon Reeds - Currently Being Build (Project)
(SOLD) 2005 Derbi Senda SM Limited Edition 656/999 (SOLD) |
| mickfulton |
 mickfulton Nova Slayer
| Usher4566 |
 Usher4566 Spanner Monkey
| renzhuow |
This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
 renzhuow L Plate Warrior
| coggie |
| Usher4566 |
| coggie |
| HD |
 HD World Chat Champion
| coggie |
 Posted: 20:37 - 17 May 2012 Post subject: |
| HD wrote: | Well you know its seriously overfuelling.
So I would look at, as you have said already, main jet being screwed all the way in. The needle and its position, if the slide is stuck, the float and its height and also the float needle valve. Should be pointy with no grooves in. |
lol yeah serious.
yeah hopefully not the main jet is screwed in correctly its it lol
that's one thing i don't understand the needle and how it works,
the slide operates fine,
the floats are fine
height got to get looked at.
needle valve does seal off the fuel as i did it by hand, held the float up put fuel in fuel pipe, let go of the floats and fuel came out.
thanks ____________________ 2005 Derbi Gpr Replica, Airsal 70cc kit, K&N, Doppler Racing Crank, Metrakit Pro Carbon Exhaust, Metrakit Carbon Reeds - Currently Being Build (Project)
| HD |
| coggie |
 Posted: 21:03 - 17 May 2012 Post subject: |
its a brand new carb if this helps
in the picture i uploaded it was running quite nice and smooth, probably just excess in expansion chamber,
in the update i had the exhaust off and spark plug cap off,
ah i basically see, should have really known how the needle works ( completed level 1 and 2 motorcycle and studying level 3)
ill have a dig around the carb again, everything looks fine but doesn't mean it is lol.
ill try over the week end and update.
cheers ____________________ 2005 Derbi Gpr Replica, Airsal 70cc kit, K&N, Doppler Racing Crank, Metrakit Pro Carbon Exhaust, Metrakit Carbon Reeds - Currently Being Build (Project)
| HD |
 Posted: 21:25 - 17 May 2012 Post subject: |
Sorry yeah, didnt read the first post again. Hopefully you can get this sorted man. Wierd that it will still run with that much excess fuel though
Is your airfilter clean and not blocked? ____________________ Rusty '02 Vito Camper + CBR600F3 |
| coggie |
| coggie |
 Posted: 20:18 - 23 May 2012 Post subject: |
update.
Problem solved
don't ask me what is was but its fixed after the last carb strip lol
also found out choke is off up and on down even though the instructions said it was on up off down lol
so that wouldn't have helped when trying to start.
thanks guys for all your help
video will be uploaded soon
edit: https://www.youtube.com/watch?v=T4OHXYnJ4ok ____________________ 2005 Derbi Gpr Replica, Airsal 70cc kit, K&N, Doppler Racing Crank, Metrakit Pro Carbon Exhaust, Metrakit Carbon Reeds - Currently Being Build (Project)
The last post was made 13 years, 224 days ago. Instead of replying here, would creating a new thread be more useful? |
