Anti freeze
buddha
PostPosted: 21:19 - 06 Oct 2004    Post subject: Anti freeze Reply with quote
Im notices the anti freeze in the bike is getting low, just wondering can i use the same stuff for the car on the bike?
Milo
PostPosted: 21:26 - 06 Oct 2004    Post subject: Reply with quote
Yeah, you can use the very same stuff as both systems work identically.
Shaft drives rule. Razz
Rollins
PostPosted: 21:31 - 06 Oct 2004    Post subject: Reply with quote
AFAIK, there isn't any car/bike specific anti-freeze, unlike lubricants.
"... I wouldn't mind doing 130 up to a T junction, but unfortunately my bike tops out at 120 which is gay..."
2005 CBR600RR
iCraig
PostPosted: 21:35 - 06 Oct 2004    Post subject: Reply with quote
Make sure you use the green anti freeze as its for all year round use and not just summer use.
Also make sure you make up the proper anti-freeze/water mixture for your bike as recommended by the manufacturer.
mr.z
PostPosted: 21:49 - 06 Oct 2004    Post subject: Reply with quote
Stick with which ever colour you have in at the moment, if your changeing colour then flush it out first, mixing colours is not good.
Depending on how low it is you might be better off toping up with deionised water and refilling properly at a later date..
Though 99% of the time they mix fine they dont allways, personally if it ment draining it out and refilling... i would... that is of course unless you can find out which anti freeze (brand type e.t.c.) was used on it?
Unless your resivoir is empty (and if it is keep a VERY close eye on it) then you can dump either the anti freeze thats allready in or (DE IONISED) water with no effect (unless you live in alaska that is)
iCraig
PostPosted: 21:52 - 06 Oct 2004    Post subject: Reply with quote
If the anti freeze/coolant level is going down drastically, I would be thinking where is it all going?
If it is going down alot, then it maybe a few things.
The last post was made 22 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 47.73 Kb
