front sprocket removal
el_oso
PostPosted: 11:02 - 24 May 2012    Post subject: front sprocket removal Reply with quote
what do you do when a 120psi air impact gun doesn't want to get a front sprocket (bolt) off?
Duke 390
Car: Jeep Wrangler 4.0L
Fizzer Thou
PostPosted: 11:19 - 24 May 2012    Post subject: Reply with quote
I would use a three leg puller like these
https://www.toolstation.com/shop/Automotive/Mechanics+Tools/Gear+Puller+Set+3+Piece/d60/sd180/p79243
Always have a 'Plan B'
Fizzer Thou
PostPosted: 11:25 - 24 May 2012    Post subject: Reply with quote
The OP says get the sprocket off - nothing about the bolt.
But - if the bolt is difficult to shift,put the chain back on,put the bike in gear with a lump of wood through the spokes and resting on the top of the swing-arm,hold the back brake on and undo the retaining nut/bolt.
Is there a tab washer holding the nut against the shaft?
Suntan Sid
Breaker bar, exert as much pressure as you can, while a mate wallops the end with a mallet.
Are you sure you're Unscrewing in the right direction?
MG
PostPosted: 11:30 - 24 May 2012    Post subject: Re: front sprocket removal Reply with quote
the_godfather wrote:
what do you do when a 120psi air impact gun doesn't want to get a front sprocket off?
Breaker bar?
'03 Honda Cityfly 125 > '02 Honda CB500S > '98 Honda CBR600F
MG
PostPosted: 11:33 - 24 May 2012    Post subject: Reply with quote
Yeah but why would he be using an impact wrench if he's already got the bolt off?
EDIT: Damn beaten to it Crying or Very sad
Fizzer Thou
PostPosted: 11:38 - 24 May 2012    Post subject: Re: front sprocket removal Reply with quote
EFA Rolling Eyes
lihp
PostPosted: 11:38 - 24 May 2012    Post subject: Reply with quote
Have you folded tabs back on the washer if there is one?
el_oso
PostPosted: 11:40 - 24 May 2012    Post subject: Reply with quote
thought it was obvious because of the use of the air gun.
just for clarification, it is the retaining bolt. tried a 5/6ft breaker bar and air gun from a workshop.
it's not my bike, asking on behalf of one of the guys in the university motorcycle club. i haven't had a look or a go myself, but before i start suggesting splitting the bolt, want to know what else to try.
Duke 390
map
Mr Calendar
PostPosted: 12:11 - 24 May 2012    Post subject: Re: front sprocket removal Reply with quote
<wrote a lot of waffle so edited it out>
Impact drive or applying some heat perhaps.
Suntan Sid
PostPosted: 12:12 - 24 May 2012    Post subject: Reply with quote
You need to "shock" the nut to break any corrosion holding it in place, hence walloping the end of the breaker bar with a mallet, while the breaker bar is under tension.
el_oso
PostPosted: 17:27 - 24 May 2012    Post subject: Reply with quote
apparently he took it down a different workshop this afternoon. came straight off. thanks guys
Duke 390
Johnser
PostPosted: 17:40 - 24 May 2012    Post subject: Reply with quote
Fizzer Thou wrote:
But - if the bolt is difficult to shift,put the chain back on,put the bike in gear with a lump of wood through the spokes ....
just in case anyone stumbles on this; I'm sure you were thinking of a bike with alloy wheels when you wrote this but not a good idea with actual spokes!!
The last post was made 14 years, 107 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 88.32 Kb
