How Do I Remove This?
johnsmith222
PostPosted: 18:23 - 24 May 2012    Post subject: How Do I Remove This? Reply with quote
Hi guys.
I was wondering if anyone could help me. My speedo drive is knackered.
I have all the bits to form one fully functioning speedo drive. The only problem is, I need to replace the worm (41060) but don't know how to do it.
There's a "pin-spring" (41082) that obviously needs to be removed but don't know how. It doesn't have a screw head on it or anything like that.
Thanks for any help. The bike is a ZZR600 and shares a similar set up of speedo drive to other Kawasaki bikes.
https://i14.photobucket.com/albums/a324/david_m213/speedo.jpg
Thanks for any help. Thumbs Up
Nick_Giles
PostPosted: 19:37 - 24 May 2012    Post subject: Reply with quote
Going to take a guess here.
Is 41082 a 'drift pin' ?? i.e. nothing more than a tight fitting peg that is tapped out and back in again.
Nick
johnsmith222
PostPosted: 19:42 - 24 May 2012    Post subject: Reply with quote
Nick
It looks like a very tiny gudgeon pin. Laughing
Only problem is it's only got one open end. Easy to tap it in. Not so easy to remove it.
Possibly just have to drill it out and buy another. Sad
Casper
PostPosted: 19:46 - 24 May 2012    Post subject: Reply with quote
Are you sure 41063 is not threaded? Stick a small alen key in, it might be or twist out.
johnsmith222
PostPosted: 19:50 - 24 May 2012    Post subject: Reply with quote
It was worth a shot but no luck.
andym
PostPosted: 20:21 - 24 May 2012    Post subject: Reply with quote
Something looked very familiar about that speedo drive... turns out it's the same one they used on the GPz 750 Very Happy
SOOOO.... from the 900 manual:
https://img.photobucket.com/albums/v320/andy36586/speedogearhousing.jpg
Ariel Badger
PostPosted: 20:23 - 24 May 2012    Post subject: Reply with quote
Try drilling it from behind (where there would have been a hole if they had drilled all the way through) and try drifting it out.
Ariel Badger
PostPosted: 20:25 - 24 May 2012    Post subject: Reply with quote
Beat me to it Andy!
andym
PostPosted: 20:34 - 24 May 2012    Post subject: Reply with quote
Just had a thought.... I might give it a bash on mine and see if it would work... was thinking maybe try finding a small screw and screwing it into the pin then use a claw hammer to pull it out (might need a quick spray of WD40 first though (the pin not the hammer))
johnsmith222
PostPosted: 20:35 - 24 May 2012    Post subject: Reply with quote
Thanks guys. Karma all round. I'll do what it says in the haynes manual.
Karma for all.
johnsmith222
PostPosted: 20:40 - 24 May 2012    Post subject: Reply with quote
Andy, don't try anything that might damage your speedo drive.
The good worm is needing to be removed from a case that has split in two. I can abuse that and experiment with that first rather than you damaging your speedo drive case.
I'll need to do the same on the good case so at least I get a practice run. Thumbs Up
andym
PostPosted: 20:46 - 24 May 2012    Post subject: Reply with quote
it wouldn't be the first part I've damaged by experimenting LOL
I did have it off the bike a few weeks ago and thought about stripping it and cleaning it... I decided to just spray it then wash it out with white spirit then repack the grease after a few days to dry out.
I've found there is a lot of things the manual says you 'should do', doesn't always mean it's the quickest or easiest way (as I've found out quite a few times... but then I'm sure in the manual they aren't left with a large tub of bolts afterwards)
Johnser
PostPosted: 21:54 - 24 May 2012    Post subject: Reply with quote
"pin spring" sounds like another name for a roll pin to me?
essentially a piece of sprung steel rolled into a tube:
https://www.partsreloaded.com/images/rollpin.jpg
if it is one, just the sproing of the pin will be holding it in place. a drift of the correct diameter will help (sacrifice a drill bit the correct size?) along with heat, plus gas and patience.
Of course it may not be a roll pin... but if it is...
bikenut
PostPosted: 11:14 - 25 May 2012    Post subject: speedo drive Reply with quote
Karma hi dude,
a soild pin ( tapered ) or roll pin ( hole in middle, sprung )??
in blind hole?
drill hole same size as pin on blind side, and tap out.
take your time....dont rush it and all will be well. Very Happy
The last post was made 14 years, 112 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 80.93 Kb
