UK Exhaust law! Catalytic converters
claypigeon101
PostPosted: 20:22 - 24 May 2012    Post subject: UK Exhaust law! Catalytic converters Reply with quote
Hi guys! Newbie to BCF here, how are you all doing.
Can anyone explain to me a brief summary of UK exhaust law?
Specifically what's the deal with catalytic converters. Are after-market exhausts illegal now because of catalytic converters not being present?
I'm on Ls on a 125 at the moment, looking at a 250 like the Ninja or the Hyosung GTR, taking my test this summer. Next bike I have needs to be light on fuel but powerful enough to cruise motorway miles from London to Stoke on occasion and other than that just quick enough to be fun and a good step up from my CBR125. That's why I thought of a 250.
Anyway that aside the first thing I'd do is put a nice sounding exhaust on my bike, 250 or otherwise. A great sound means a lot to me.
If my bike had a cat as stock, I presume putting a slip-on on would incur removing the cat and therefore would I be riding something illegal?
Can anyone shed any light as I did a bit of googling and mustn't have found the right pages cos I'm no clearer on it than I was an hour ago.
Thanks!
PS If you have any bike suggestions for first big bike let me know because I'm after something that's not too brutal for a first bike but has the power to cruise at 60-70 if I go 160 miles home for the weekend etc.
Taught2BCauti...
PostPosted: 20:33 - 24 May 2012    Post subject: Reply with quote
Catalytic converters are usually fitted closer to the headers, so are not part of the end-can.
In a fully 'closed loop' system, there will be an O2 (or Lambda) sensor before and after the 'Cat' so you should be able to locate it easily by looking for where the wiring goes - but you should find that changing the end can and link pipe doesn't affect the Cat.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
claypigeon101
PostPosted: 20:37 - 24 May 2012    Post subject: Reply with quote
That's brilliant, thankyou!
If anyone wants to elaborate on first bike ideas then please do.
grant965
PostPosted: 21:12 - 24 May 2012    Post subject: Reply with quote
on my z750 the catalytic converter is in the end can, only found out when I cut 9'' of the can off and realised I had a divider splitting the converter from the silencer.
Doh!
Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R
Taught2BCauti...
PostPosted: 21:17 - 24 May 2012    Post subject: Reply with quote
Make sure your 125 is suitable for the standard (25kW) test, or you could end up with just a 'light' category licence and be restricted to 125cc and 11kW until you take another test. See Here for more info.
I would suggest you look for at least a 400cc bike for that sort of distance on the motorway - maybe even thinking about getting a 600cc with a 25kW restrictor kit fitted.
I don't think a 250cc machine would be up to the task.
Someone will be along soon to suggest you do your test on a bigger bike and getting an un-restricted licence at the first go - but I'm guessing you will still be under 21 by Jan 19th?
lihp
PostPosted: 21:30 - 24 May 2012    Post subject: Reply with quote
Only if its an obd2 system as they require self monitoring emissions systems, it could also have just 1 lambda sensor and still run closed loop. It may even have no lambda.run open loop and.still have a cat.
Either way a cat in the system is easy to.spot.
Benson_JV
PostPosted: 21:42 - 24 May 2012    Post subject: Reply with quote
Don't get a 250.
You may as well get a 500 commuter (GPZ500, GS500, CB500, ER5) as the price difference will be negligible, slightly worse on fuel (only very slightly!) yet the consumables will cost the same, yet underneath you is a machine with quite a bit more oomph that'll gobble motorway miles.
Plus, as of 2013 they will be worth, precisely, shit.
PostPosted: 21:47 - 24 May 2012    Post subject: Reply with quote
There is currently no emissions test for motorcycle MOT's, so the cat only has to be present at manufacture. This is likely to change soon though.
PostPosted: 23:19 - 24 May 2012    Post subject: Re: UK Exhaust law! Catalytic converters Reply with quote
Illegal is rather different to something you are likely get done for. It is not an MOT issue, and never heard of anyone remotely getting done for it.
That said, technically any exhaust louder than standard (even if still quieter than the legal limit) is illegal, but the chances of getting done for an exhaust that is loader than standard but still quieter than the limit is pretty much zero.
claypigeon101
PostPosted: 09:28 - 25 May 2012    Post subject: Reply with quote
Thanks so much guys that's loads to think about.
To answer some questions yes I'm 19 at the moment so the DAS or whatever the big bike test is is out.
Also I'll take it on the instructor's bike rather than mine, I like his YBR.
What's the 2013 change you're talking about?
0l0dom0l0
PostPosted: 11:17 - 25 May 2012    Post subject: Reply with quote
Just take your test on a 125, you can then ride any motorcycle as long as the power output is no more than 33bhp for 2 years. Then get a 500/600cc commuter and restrict it to 33bhp.
There is no market for 250's at the moment, because they are stupidly priced and don't really serve any purpose.
The change in 2013 means that you will no longer to be able to take that test, and for 2 years you will be restricted to a 125. Then a bike with no more than 45bhp (can be restricted from no greater than 90bhp) for another 2 years and ride any size motorcycle after that.
Walloper
PostPosted: 12:06 - 25 May 2012    Post subject: Reply with quote
The Cat can cost you a bit of power due to volumetric efficiency.
I took the cat out the system of my BMW R1200GS and fitted Remus pipes and can.
Passed two MOTs without issue.
stevo as b4
PostPosted: 17:25 - 25 May 2012    Post subject: Reply with quote
I think a newish Ninja 250, thats well maintained would be perfectly happy to sit on the motorway at 12500rpm for as long as the tank range will take you, every single day. And that rpm is alot faster than 70mph too.
Prove me wrong and i'll accept your wisdom, but i don't see many Ninja 250's blowing up from a 100mph Motorway blast.
Of course a 500/600cc bike is more capable and relaxed at these speeds, but as seen in the recent thread that Teflon Mike was responding to, where does it end?
Your suggesting a bike for a 33bhp limited rider. IMHO he/she really does'nt need a 600cc machine that cannot be utilised to anywhere near it's full potential for a whole two years!
I'd never buy a 600 thats spent 2years with a 33bhp restriction kit fitted, as i can't see how it would make the engine run better or as well as std.
I know it's an old argument now, but i just don't see the point in the running costs and insurance and fuel costs for a 600cc for two years, when all you can have is 33bhp.
Get a bike thats within 10bhp of the limit naturally, and it has to be so much more fun to ride IMO!
PostPosted: 17:39 - 25 May 2012    Post subject: Reply with quote
Having gone from a 305 making just about 25kW (which rides much like a Ninja 250 that I tried) to a 500, I would recommend that you go the restricted 500+ route. The bigger bike is more stable, much nicer to ride, and won't become unsellable next year.
The last post was made 14 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 84.94 Kb
