Gilera Rcr Help ..
sm164
PostPosted: 23:14 - 25 Apr 2007    Post subject: Gilera Rcr Help .. Reply with quote
Hi,
ive just received a gilera rcr 50 as a replacement bike .. and the engine appears to flood and wont start without being bump started.I know this is going to sound dumb but does anyone know where the choke is on these bikes ? or has any got any ideas what could be the problem.. Bearing in mind is is the 2007 model and has onli covered 40 k/m.
There is a gap of 5 years, 30 days between these two posts...
karl davison
PostPosted: 21:54 - 24 May 2012    Post subject: Reply with quote
hi there iv just went and bot a gilera rcr 50cc and it is completely standard has olny done 5000 miles it only does 40 mph oi have took the washer tyope thing out of the exhuast and thats all that i have derestricted i would like it to go faster does any one know how too get it to go faster and what parts i would need thanks karl
Usher4566
PostPosted: 07:29 - 25 May 2012    Post subject: Reply with quote
Hi Karl there are lots of threads on here for you bike use search box.there may be more than one washer in exhaust .I would now check between carb and manifold and carb and air box there may be a metal plate with hole or holes restricting air or fuel .but if you search for your bike in search box then there are a few that have done these and you can read there problems and successes.
New cd200 benly owner
at106
PostPosted: 08:21 - 25 May 2012    Post subject: Reply with quote
If you've taken the washer out the exhaust you should also upjet the carb otherwise it may run lean. Check the spark plug colour if it's white or grey then the bike is running lean.
The last post was made 14 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 39.06 Kb
