Clip-on mirrors
sgtcalle
PostPosted: 17:14 - 24 May 2012    Post subject: Clip-on mirrors Reply with quote
just bought some clip on mirrors for my Bros, had a look at them and cant see how im supposed to attach them. i have heated grips though so i think they might not be compatible with them. has anyone ever tried clip ons with heated grips?
CBR600F '02
Manchester
DrDonnyBrago
PostPosted: 18:19 - 24 May 2012    Post subject: Re: Clip-on mirrors Reply with quote
Do you have a link to the product you bought?
I doubt they will attach to the grips themselves or you wouldn't be able to use the mirrors and throttle at the same time Laughing .
As I have no idea what item you are actually talking about, I would assume it bolts around part of the handlebar not covered by grips, around the bar end or in place of the bar end.
johnsmith222
PostPosted: 18:35 - 24 May 2012    Post subject: Reply with quote
I had to cut the ends out of my grips to fit bar ends. If these are bar end mirrors and the end of your grips are sealed then you'll have to do the same.
Although make sure that your bike even has threaded ends for bar ends first and that the mirrors have the correct size bolt.
You could always cut a small neat hole big enough for the bolt to go in to see first.
I had to cut the whole end off on the throttle size as the bar end would grip the throttle.
sgtcalle
PostPosted: 12:02 - 25 May 2012    Post subject: Reply with quote
not sure how im gonna sort it tbh, the clip on has an expanding bolt to attach it with, but its nowhere near big enough. might have to drill a bit of wooden dowl or something and put it inside the bar end. thanks for the ideas anyway guys
CBR600F '02
Manchester
DrDonnyBrago
PostPosted: 12:15 - 25 May 2012    Post subject: Reply with quote
Ah a bar end mirror.
Could you replace the expanding bolt with your own rawl bolt? How about a rubber ring from a bit of hose to bolster the diameter a bit.
sgtcalle
PostPosted: 14:58 - 25 May 2012    Post subject: Reply with quote
yeah sorry for being unclear. i suppose i could use a rawl bolt if i could find one big enough. another problem though is that the hollow in the bar end isnt deep enough to accommodate the length of the expanding bolt, so the mirrors arent flush with the bar end. the hose idea is a good one, i might try that.
CBR600F '02
Manchester
sgtcalle
PostPosted: 22:12 - 25 May 2012    Post subject: Reply with quote
sorry to revive this thread again, but i got round the problem, might be useful for reference in future.
Had to buy some smaller bolts, which turned out to be a touch too long. i had to use expanding collars to attach the mirror/bolt/thingy solid against the stay inside the grip to stop the mirror rotating with the throttle. was an absolute arse ache, but got there in the end. (after taking apart saucepan lids to find some rubber washers. Cant beat improvisation!)
CBR600F '02
Manchester
The last post was made 14 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 51.13 Kb
