Are there any really bad bikes ?
allweatherbik...
PostPosted: 23:35 - 06 Oct 2004    Post subject: Are there any really bad bikes ? Reply with quote
When reading through all the various posts I get lots of different opinions from lots of different people about which bikes are better than others. While I understand that we don't all have the same abilities as riders and need our bikes for different uses are there any really bad bikes that we shouldn't touch with a barge poll
Ian
jay12329
Dr. Evil
PostPosted: 23:38 - 06 Oct 2004    Post subject: Reply with quote
Anything that isnt my bike is a realy bad bike.
IMO
J
PostPosted: 23:44 - 06 Oct 2004    Post subject: Reply with quote
Loads. Ages ago I typed up some of the worst reviews from the Used Motorcycle guide (who pulled no punches) they make entertaining reading:
Extracts from the used Motorcycle guide.
Do you own one of these bikes??
I have lifted these directly from the magazine with no alterations. Performance statistics and prices have been missed out unless particularly humerous.
Honda CD185T: Update on the CD175 which retained its reliability, was less frugal and had a quickrot chassis. Build quality astonishingly poor. In the unlikley event that you find one, put a lighted match in the fuel tank!
Honda FT500: The FT messed up completley, ending up with the same power as a 350 thumper and the same vibration as an old Brit single. Nasty! The engine also suffers rapid top-end wear and a clunky transmission. Upgrading the suspension fixes most of the handling problems, but it’s hard to know why you’d want to…..
Kawasaki Z400J: Underpowered and overweight four. Wallows on worn suspension. Durable to 40k when camchain goes, then electrics, rusted cycle parts, ruined discs and disintegrating seat, knocking mains and primary drive dies. Still only just adequate transport if very, very cheap.
Kawasaki Z750 Twin: An old horrorbag with a complex engine, too much mass and too little power even for the 1970s. Being as slow as a 250 and as expensive as a four makes it something of a dog with fleas these days, but still laid back and mostly reliable.
Kawasaki ZR-7: A missed opportunity. The Big Four must have decided that the 750 roadster category was a lost cause as they’ve made some dismal machines for it. Motor:fine. Chassis:fine. Package:fine. The best thing you can say is that the tank range is excellent. But the vibes will kill you before then. Only for the skint/desperate. Nose fairing on S improves higher speed comfort but hardly looks a pretty picture.
Yamaha RS100/125: Most rusted to death. Small-end rattles first; engines tough for 20k, tuning kills them. Handling at speed jittery, quick wear suspension wrecks the steering. Frames bend easily. Even good ones rot rapidly.
Yamaha XVS125 Drag Star: Just as with larger cruisers, the learnerbike Virago mutates into a Drag Star. But it’s longer and heavier and has no more Go. Is this progress?
Yamaha XS250/400: Gutless but simple motor combined with quick-rust cycle parts. Crankshaft and gearbox problems after 30k when the head gasket often blows. Chronic starting hassles, usually from a combination of hard to trace problems (killswitch, carbs, rotted wiring, dying ignition etc.) Also rare dohc, spine frame XS400. Are you really this desperate? It must be very cheap.
Yamaha XS500: 8-valve twin with troublesome chain-driven balancer. OK frame but engine burns valves, strips plug threads and needs constant fettling. B model has two piece cylinder head that leaks oil. C model quickest, E slowest; D model on has easier to adjust balancer chain. Ferrodo pads cure wet weather lag. Very few left that don’t have terminal mange.
Yamaha XZ550: Strange V2 with jerky power delivery, clunky gearbox and heavy clutch. Some engines OK, others leak coolant, eat valves, pistons and electrics. Handling dodgy on early bikes and wear makes later ones as bad. Definatley a mistake to try to run one on non-standard filters or exhaust, but even stock the carburation was poor. Little to recommend.
Aprillia Caponord: Oh look, it’s the Mille motor yet again. This time the bikes too high, too bulky, too heavy and far to wide. Imitating all the bad things about the Varadero. But at least it’s not much more expensive.
BMW R1200C: Completley crazed cruiser for those with vast wallets who just must be different. A total waste of technology. Does everything in an average way and looks astonishing. Depreciates faster than other BMWs. Is this some kind of Teutonic humour which doesn’t quite translate?
CZ125: Jurrasic-on, 124cc 2-str sgl. 10bhp 60mph, 60mpg, 250lb Plodding Czech-built commuter with nothing to recommend it. No, perhaps that’s being too hasty. Let’s think. Hmmm. No, nothing at all. Not even cheapness. Yuk. C1 £450, C2 £200, C3 £nothing
CZ350: Did you know that the 350 came with a rev-counter? That’s the best bit. Buy one and weep. Early ones even had a grease nipple for the engines centre main bearing. Even CZs can be tuned, you know. C1 £250, C2 £50, C3 £nothing, or less
Jawa 500R: 494cc, sohc single. NU7, no performance… (or figures) Mongrel marriage of Rotax single and 350 Twin chassis. A real bastard in the true sense of the word (honest). Buy almost anything else instead.
[/b]
iCraig
PostPosted: 23:49 - 06 Oct 2004    Post subject: Reply with quote
You forgot the CBX550 too.
PostPosted: 23:56 - 06 Oct 2004    Post subject: Reply with quote
CBX550: Extremely usefull device spoiled only by a naff camchain tensioner that can destroy camchains in 10k miles. Various fixes, eg fitting later model tensioners and give it a monthly greasing or WD40 session. Slick gearbox a sign of a good engine, goes off with mileage and beware of rattly clutches as the bearings are weak. Enclosed discs make for brake fade and troublesome wheel removal. Little choice on aftermarket exhausts and no pattern silencers
Doesn't seem all that bad a review to me.
mr.z
PostPosted: 23:58 - 06 Oct 2004    Post subject: Reply with quote
stinkywheel wrote:
CD175
This is the last bike my dad every had, he rode motorcycles from the age of 15 up untill he was 45(?) allthough it NEVER went wrong he never got another bike again....
Its so shity it put him off bikes for the rest of his life, he now drives a for fiesta and is looking to buy a vaxhaul Crying or Very sad (The shammmme the shameeee boo hoo hoo.....)
Did you not own all the bottom three bikes at some point SW? Eh? Thinking
Ive had people tell me how unrelyable CX's are* i even saw a review recently mention they could be problematic :/ , broken tensioners (theres no way any of those are still on the road!!) ammong other things, ive been rideing it for a year, others have been rideing them a couple of decades and such failiings are very rare indeed, but still the reputation sticks...
all bikes will have a lemon or two (or three or four if they are italian Razz ), i spoke to a woman who had a BRAND NEW sv650 which lept out of gear reguarly, she got rid sharpish... turns out it was a manufactureing fault... but she will never buy a suzuki again she said...
So sv650s are unrelyable?
Makes sense to get allot of opinions together before writeing a bike off as a crap heap... even then it dosent gaurentee it wont be, or will...
*all of which would not have been an issue if maintainance was done properly, not design/manufacutre faults.
PostPosted: 00:18 - 07 Oct 2004    Post subject: Reply with quote
No, I have never owned a CZ model but I am something of an anorack about them. I have commended them to others as dirt cheap wheels for the terminally skint...which they are. You will notice there is no great long list of faults and breakdowns with them unlike the various jap bikes.
TheShaggyDA
Repost Police
PostPosted: 00:24 - 07 Oct 2004    Post subject: Reply with quote
Haywards (where I just bought my Enfield) has a Jawa 350 going for £395 - tempted to get it for winter Smile
https://www.btinternet.com/~haywards.cambs/haywards/partex_jawa.jpg
PostPosted: 00:40 - 07 Oct 2004    Post subject: Reply with quote
I wouldn't for that money, it is a bitsa. The frame is off a model 638 but they didn't use that sort of exhaust manifold on that model. The engine is an earlier one, possibly a 1970s oilmaster judging by the square alternator cover but with 638 alloy cylinder heads on the 70s cast iron barrels (the 638 should have alloy barrels with iron liners).
The fact that the rear plastics are a different colour to the tank and sidepanels also suggests it has had a fairly serious off since those plastics are very difficult to damage due to the two metal rails along the side of them.
If you go and look at it, there will (is supposed to be) be a VIN plate attached to the headstock with the model number, chassis number and engine number on it. I garantee the engine number stamped on the plate does not match the one on the engine. Look for scuffing on the undersides of the exhausts. If it runs well there should be no problems (the parts used are perfectly interchangeable) but it isn't worth 350 quid, I payed that for a mint (200 miles) 638 with a sidecar on it ten years ago.
[/anorack]
PostPosted: 14:09 - 07 Oct 2004    Post subject: Reply with quote
The CX had very serious design faults when launched. The cam chains rarely lasted long enough for the bike to reach its first schuduled maintenance. A guy I know was a mechanic at a Honda dealer at the time. He says that they had to rent loads of garages just to store all the bikes waiting to be fixed under warrenty.
Honda followed this up with the short lived cam chain on the CBX550, and the terminally unreliable VF750.
Ironically early late 70s and early 80s Hondas had reliable regulator / rectifier units, something they seemed to forget how to make in about 1990.
billy whizz
PostPosted: 20:01 - 07 Oct 2004    Post subject: Reply with quote
Crap bikes? Well now let me see.... ah yes, anything that was made in the USA or Italy both are either unreliable or unrideable, not nescersarily in that order! Laughing Laughing Laughing
Here comes the summer! Smile
PostPosted: 12:39 - 08 Oct 2004    Post subject: Reply with quote
Anything that isn't British or comes from a company that has gone bust is rubbish. Cool
The last post was made 22 years, 5 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 83.94 Kb
