| Mungel |
 Mungel Scooby Slapper
 Posted: 08:11 - 26 May 2012 Post subject: Removing sprocket carrier bearing remains... |
Found the source of the strange clunking noise when moving off from stand still....
https://cdn.bikechatforums.com/files/bearing1.jpg
That is the remains of my sprocket carrier bearing
Those are the few ball bearings which remained intact.
The squashed bits were also ball bearings, once..
Now I have a problem. As the bearing has collapsed, the outer ring of the bearing is stuck in the sprocket carrier and despite soaking it all night with plus gas, it just won't budge. I'm thinking I might try to dremel it out, but I don't want to bugger up the carrier. Any ideas?
https://cdn.bikechatforums.com/files/bearing2.jpg ____________________ Mungel
ZZR600 (dead) - ZX9R (sold) - FZ1S |
| alun111 |
 alun111 World Chat Champion
| Mungel |
| Walloper |
 Walloper Super Spammer
| Nick_Giles |
 Nick_Giles Could Be A Chat Bot
 Posted: 10:17 - 26 May 2012 Post subject: |
Similar happend to me the other week changing a sprocket bearing on an ER5
I GRADUALY tapped it out with an old screwdriver and hammer.
first few 'whacks' quite hard to break its self created seal.
Then gentle hit / tapping order of :-
12 o'clock - 6 o'clock
9 o'clock - 3 o'clock
Take your time and dont rush even when its nearly out.
I know its far from textbook bearing removal but it worked for me. Then used the old bearing ring to drift the new bearing back in.
Nick
p.s. -------- Did I mention. Take your time, tap it gradually & dont rush.  ____________________ Peter Cook: "I have learned from my mistakes, and I am sure I can repeat them exactly". |
| stinkwheel |
 Posted: 10:33 - 26 May 2012 Post subject: |
Take the rubbers and sprocket off and put the whole thing in the oven for an hour or so at 200 degrees.
Set it with the open end of the bearing seat facing down and it might even fall out itself.
If it doesn't, lift it out (carefully), set it on a couple of bits of wood and see if you can get a punch on the edge of the race from the back.
If it is your own oven, carry on. If it is likely to cause domestic strife, make sure it's fully degreased then washed in hot soapy water before proceeding out or the kitchen will smell of burning oil when they get back and they'll know you were up to something.
A small groove in the bearing seat cut with a dremel shouldn't prevent the new bearing seating. Good luck cutting it with a dremmel though. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Mungel |
 Posted: 11:30 - 26 May 2012 Post subject: |
Thanks for all the advice.
| Quote: | If you can get the wheel to an engineers, garage, welding shop they can run a bead of weld around the inside of the old outer race.
When it cools the bearing will fall out when the wheel is turned over.
How will this work? Will outer race contract inwards with the weld cooling?
| Quote: | I GRADUALY tapped it out with an old screwdriver and hammer.
This is what I have been doing, but the bloody thing is not budging.. I can't get any purchase on the race with the drift.
| Quote: | Take the rubbers and sprocket off and put the whole thing in the oven for an hour or so at 200 degrees.
That's a big no no.. I'd never hear the end of it if the kitchen or oven smelt even slightly..
| Quote: | You could cut a groove in the bearing with your Dremmel and try knocking it from the other side using a punch. |
This is my next attempt, if I can get my hands on a dremel today. I should be able to get more of a grip on the race with the screwdriver head. ____________________ Mungel
| Nick_Giles |
| stinkwheel |
| Casper |
 Casper World Chat Champion
| Mungel |
 Posted: 13:13 - 26 May 2012 Post subject: |
Well, I've had no luck locating a dremel and my hands are sore from hitting the bloody thing with a chisel/screwdriver/punch. It won't budge. Not even slightly.
I have a blowtorch to hand. Maybe some heat can help things along? What bit should I try to heat up? The race or the carrier? Will it even help?  ____________________ Mungel
| mentalboy |
 mentalboy World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 14:26 - 26 May 2012 Post subject: |
That's an easy one. Re-build the bearing without the cage by putting all the balls in one side, offering up the centre part and then moving the balls around to distribute them evenly. Use grease to make them stick in place. You need to use a minimum of three balls but six or more would be better.
Now you can whack out the bearing using a drift on the inner race. ____________________ a.k.a 'Geri'
| The Artist |
 The Artist Super Spammer
| Mungel |
 Posted: 15:30 - 26 May 2012 Post subject: |
| Pete. |
 Pete. Super Spammer
 Posted: 15:58 - 26 May 2012 Post subject: |
Cool  ____________________ a.k.a 'Geri'
| Casper |
| Mungel |
 Posted: 17:10 - 26 May 2012 Post subject: |
There is a slight recess on the inner and outer races that the bearings sit in. Its very slight but once you have the bearings spaced equally around, the inner race won't fall out. It makes perfect sense, but I would never have thought of it..  ____________________ Mungel
| Casper |
| stinkwheel |
| Sako |
 Sako World Chat Champion
 Posted: 07:23 - 28 May 2012 Post subject: |
that is a brilliant piece of advice, impressed!  |
The last post was made 14 years, 109 days ago. Instead of replying here, would creating a new thread be more useful? |
