Motorbike coolant
lama16
PostPosted: 23:35 - 26 May 2012    Post subject: Motorbike coolant Reply with quote
Hi all...
just noticed today the coolant is running a bit low. Checked the manual and its recommended product was ENI Antifreeze Spezial (fluid without amines, nitrites or phosphates)... Cant find it anywhere... so I guess its a foreign brand. Can someone recommend a coolant for the Aprilia rs4 125. (currently its pink fluid inside) Got Halford near me so I might go there tomorrow .
Current: Suzuki GSX R 600 L2
Ex Bike: Aprilia RS4 125
temeluchus
PostPosted: 23:56 - 26 May 2012    Post subject: Reply with quote
Try and buy coolant concentrate, alloy engines need it 50/50 mixed with water.
I dont think you will need anything special.
lama16
PostPosted: 11:29 - 27 May 2012    Post subject: Reply with quote
Car coolant and motorbike coolant, is it the same?
Thanks
temeluchus
PostPosted: 13:00 - 27 May 2012    Post subject: Reply with quote
I have never heard of "motorbike coolant".
Get concentrate coolant from your local motor factor and mix it 50/50 with distilled water.
PostPosted: 13:07 - 27 May 2012    Post subject: Reply with quote
I've heard of it, apparently its better for radiators with smaller channels like motorcycle radiators.
I use it a lot.
temeluchus
PostPosted: 13:13 - 27 May 2012    Post subject: Reply with quote
I use it a lot.
not the usual motorbike tax where they put "bike" on the label and charge you 4 times as much for the same stuff?
guile
PostPosted: 13:16 - 27 May 2012    Post subject: Reply with quote
Is coolant universally a certain shade of blue? Can you tell how concentrated your coolant mixture is by the shade of blue?
PostPosted: 13:25 - 27 May 2012    Post subject: Reply with quote
Temeluchus wrote:
I use it a lot.
Well, not according to the bottle, no. Its no more expensive than normal coolant where I buy it from.
temeluchus
PostPosted: 14:12 - 27 May 2012    Post subject: Reply with quote
glycol is glycol, colour is just dye.,
acid drop
PostPosted: 18:36 - 27 May 2012    Post subject: Reply with quote
No
The last post was made 14 years, 117 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 65.64 Kb
