Crank Arm noises and it falls off.
mm391
PostPosted: 12:42 - 27 May 2012    Post subject: Crank Arm noises and it falls off. Reply with quote
Hi,
IN the last 6 months I have been getting really bad noises, creeks, clunks etc coming from somewhere around the spindle connecting to the crankshaft. Every time I put pressure down on the left hand pedal, either the crank arm where it connects to the spindle or the spindle creeks, clunks real loud and the crank arm works itself loose and falls off.
Can anyone help explain what is wrong and how to fix it?
Thanks
Quote Me Happy
PostPosted: 12:48 - 27 May 2012    Post subject: Reply with quote
The problem is that you have pedals. Unless you're riding a moped with pedals you're on the wrong forum.
PostPosted: 13:17 - 27 May 2012    Post subject: Reply with quote
As above, this is a motorcycle forum.
Try www.bikeforums.com and lurk more.
Even then, that was a monumentally shit first post so can I recommend that should you post this question there, you include details of the make and model of the bicycle, make and model of the crank/chainset (if it's a geared chainset) and wether it has a cotter-pin, square taper or octalink bottom bracket.
On initial reading it sounds like you're missing the bolt or cotter pin that holds the crank onto the bottom bracket spindle. With this in place, it should be impossable for the crank to actually fall off.
PostPosted: 13:38 - 27 May 2012    Post subject: Re: Crank Arm noises and it falls off. Reply with quote
mm391 wrote:
Hi,
Thanks
Yeah its human powered and therefore wrong. Throw it in a skip and buy a motorcycle! Wink
nowhere.elysium
The Pork Lord
PostPosted: 13:53 - 27 May 2012    Post subject: Reply with quote
Again with the 'this is a motorcycle forum', but it would seem like your crank bolt is missing, and you may need a new bottom bracket anyway, if it's making a lot of noise.
bikenut
PostPosted: 13:26 - 28 May 2012    Post subject: Reply with quote
:karma: sounds as if the bearings are/have borken up.
get cheap 2t engine and power bike with it, or get a cg125 etc........
The last post was made 14 years, 119 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 48.94 Kb
