Thread repair - Helicoil or TIG weld and re-tap?
cb1rocket
PostPosted: 19:27 - 27 May 2012    Post subject: Thread repair - Helicoil or TIG weld and re-tap? Reply with quote
One of my engine cases has ruined a thread, but because its so small (m4) would it be best to fill hole by TIG welding, drill hole and retap to suit
or a helicoil
Opinions please
PostPosted: 19:29 - 27 May 2012    Post subject: Reply with quote
I would run a M5 tap down it and use a M5 bolt. You'll be a bit shy on full thread engagement but it should work.
cb1rocket
PostPosted: 19:42 - 27 May 2012    Post subject: Reply with quote
fussy me here, but I would rather use an original method to get it back to how it was - I don't want to open the clutch cover hole as well.
Whats more annoying is that its on dowel location hole!
PostPosted: 20:30 - 27 May 2012    Post subject: Reply with quote
Drilling and tapping IS the original method - you're just going up a size, though it's academic unless the dowel has a 5mm hole through it.
cb1rocket
PostPosted: 20:37 - 27 May 2012    Post subject: Reply with quote
I want an M4 thou, a repair that would be possible without some clued up person knowing its even been rethreaded
PostPosted: 22:01 - 27 May 2012    Post subject: Reply with quote
My oppinion.
M4 is a bit small to be cutting into the standard of alloy the japanese use for crankcases and expecting it to hold anyway.
It's proved this by stripping.
I'd have no problem with a helicoil providing your drill hole isn't bigger than the hole the dowel seats in. It'll be stronger than the original because you don't have a weedy little thread going into comparatively crappy alloy.
I'm maybe not supposed to do this but the last few helicoils I fitted, I put green bearing fit compound on the insert then ran a standard tap down the inside once it had dried to clean any out of the threads. This was as a precaution against the insert coming out with the screw.
Raffles
PostPosted: 22:04 - 27 May 2012    Post subject: Reply with quote
That's a very small screw size and I can't think of anyone that could work to such fine tolerances..........Or can I Thinking
cb1rocket
PostPosted: 23:10 - 27 May 2012    Post subject: Reply with quote
there are another 10 of these or so holding the rest of the cover on the weedy H100!
The rest of em are ok, not bad for 22 years of abuse.
Someone's been inside the engine before me Sad
PostPosted: 10:10 - 28 May 2012    Post subject: Reply with quote
I'll probably take a MarJay raping for this, but depending on how much tension it'll be under, I'd be tempted to fill it with chemical metal and drill and tap into that.
[Puts on assless-rape-chaps]
DrDonnyBrago
PostPosted: 10:40 - 28 May 2012    Post subject: Reply with quote
Nasty.
https://cdn.cutestpaw.com/wp-content/uploads/2011/11/oh-noes-l.jpg
temeluchus
PostPosted: 11:46 - 28 May 2012    Post subject: Reply with quote
If its not holding anything too important on this works ok.
If the thread will still engage but the bolt slips over the threads when tightened, a smear of chemical metal can be strong enough to restore the thread-again as long as its not holding anything that takes much strain.
Bezzer
PostPosted: 12:11 - 28 May 2012    Post subject: Reply with quote
Is your motor still stripped down? if so use aluminium "solder" such as lumiweld and the benzomatic stuff you can get from B&Q. You can fill the hole and retap , it's ideal stuff for jobs like that, done a few with no problems at all.
cb1rocket
PostPosted: 12:44 - 28 May 2012    Post subject: Reply with quote
yes thanks for that bezz, its only holding on the clutch cover along with 10 other small bolts all round.
Only pressure on the clutch cover is the clutch pin that pushes on the clutch!
bikenut
PostPosted: 13:08 - 28 May 2012    Post subject: Reply with quote
Karma hi dude,
can u post some pics.......
cb1rocket
PostPosted: 13:27 - 28 May 2012    Post subject: Reply with quote
bikenut wrote:
Karma hi dude,
very bottom left hole
https://www.bikechatforums.com/download.php?id=84148
cb1rocket
PostPosted: 13:33 - 28 May 2012    Post subject: Reply with quote
sorry its an M6 according to the parts fische
https://www.hondaoriginalparts.com/honda_motorcycle_parts_selection_pfk.php?block_01=13KE6D61&block_02=E__0200&block_03=3243
bikenut
PostPosted: 13:40 - 28 May 2012    Post subject: Reply with quote
holes look big for m4...........
Itxi
PostPosted: 14:08 - 28 May 2012    Post subject: Reply with quote
Had the same problem with my carbs, M4 as well.
Got a helicoil kit and it worked a charm, highly recommend it Thumbs Up
The last post was made 14 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 96.7 Kb
