ZX9R wont get to 100mph or pull above 7,500rpm HELP PLEASE
duncanpage
PostPosted: 20:40 - 27 May 2012    Post subject: ZX9R wont get to 100mph or pull above 7,500rpm HELP PLEASE Reply with quote
Hi all
I have just got myself a 1999 ZX9r and on the way home from collecting it, the bike felt quite rough when I fully opened the throttle in top gear below 3,000 rpm.
Having ridden it today I've noticed it won't go over 7,500rpm and wont go above 100mph.
The bike came with receipts for a Dyno-Jet kit and has a dyno readout.
It also came with a spare set of carbs.
The previous owner never mentioned it being restricted but he only had it 4 months. He MOT'd it and then sold it on.
I've cleaned out the K&N air-filter and noticed that the two rubber plugs were missing from the air-box. I've replaced these but it doesn't seem to have made much of a difference if anything at all.
If the bike is restricted what should I be looking for and where?
I've got my full license and am 28 years old so I don't want to be riding a restricted zx9r Sad
Please help me!
cb1rocket
PostPosted: 20:44 - 27 May 2012    Post subject: Reply with quote
probably some washers between the carbs and intake manifold.
If not getting to 100mph then it def sounds restricted
CaNsA
PostPosted: 20:45 - 27 May 2012    Post subject: Reply with quote
AFAIK the restriction will be under the carbs, the carbs will need pulling off.
Sorry that i cant be more help.
cb1rocket
PostPosted: 20:46 - 27 May 2012    Post subject: Reply with quote
will it go over 7.5k in the lower gears?
duncanpage
PostPosted: 20:51 - 27 May 2012    Post subject: Reply with quote
No, it won't pull above that in any gear
PostPosted: 21:02 - 27 May 2012    Post subject: Reply with quote
33hp ZX9R... rip the carbs off, there should be washers either between the carb and engine or you'll have a restriction in the slides area.
It will shoot past that speed no worries after Laughing Laughing
duncanpage
PostPosted: 21:09 - 27 May 2012    Post subject: Reply with quote
Thanks everyone.
I'll rip the carbs off first thing tomorrow and have a look.
Does a dyno-jet kit have any significant markings?
If the other set of carbs that the previous owner gave me with the bike has a dyno-jet kit fitted will I be able to tell from looking at them or will it have to be stripped apart?
cb1rocket
PostPosted: 21:15 - 27 May 2012    Post subject: Reply with quote
parts are inside, will involve stripping the carbs
I'm surprised the bike doesn't rev past 7.5k in the lower gears......not even in 3rd?
PostPosted: 21:19 - 27 May 2012    Post subject: Reply with quote
The restriction washers have such a narrow hole that wont allow you to rev out past that point. It physically can't feed enough into the cylinder.
duncanpage
PostPosted: 21:25 - 27 May 2012    Post subject: Reply with quote
I can't be 100% certain as I was concentrating on not coming off the twisty road as it's a new bike to me, but I'm pretty sure it won't rev above that in any gear.
It will rev all the way to the red line on the paddock stand when not in gear but my dad said that's because it's not under load.
cb1rocket
PostPosted: 21:29 - 27 May 2012    Post subject: Reply with quote
hmmmm
on the other hand while being polite ( Wink ) don't rev it up to red in neutral - best way to wreck an engine!
PostPosted: 21:30 - 27 May 2012    Post subject: Reply with quote
You dad is quite right, with no load on it there's no need for a lot of fuel/air to spin it up. Revving out an engine with no load on it is a good way of throwing a rod so best cut that out if you want it to last.
PostPosted: 21:36 - 27 May 2012    Post subject: Re: ZX9R wont get to 100mph or pull above 7,500rpm HELP PLEA Reply with quote
There's a RAM air tube that goes from the two main air ducts at the front to carbs I think (though may be airbox). When I had it disconnected because I didn't have the main tubes (no fairings) and it generally ran pretty badly.
Reconnecting the main ducts and ram air tube sorted it.
moppy
PostPosted: 21:54 - 27 May 2012    Post subject: Reply with quote
Hmm. My ZZR6 won't go past 100mph, but will happily rev all the way to the 14K redline in first to 50mph.
Thoughts on the matter?
Scythe
PostPosted: 23:13 - 27 May 2012    Post subject: Reply with quote
As it's a 600 it'll be sucking less volume in, so it should still rev as the area of the inlet will be less.
2009 Yamaha YBR125 -> 2000 SV650S -> 2005 Kawasaki ZX6R 636
MattJ
PostPosted: 23:30 - 27 May 2012    Post subject: Reply with quote
My FZR600R is 33bhp and it definitely does use the full rev range. You can just tell that after about 7k that there isn't anymore power to be had but the revs do still rise very slowly in 6th gear.
As moppy said 50mph can be had in first gear still.
duncanpage
PostPosted: 17:55 - 28 May 2012    Post subject: Reply with quote
Hi everyone.
Thanks all for your help.
The bike is now cured but it wasn't carb diaphrams.
I stripped the carbs off the bike but couldn't find anything that resembled a restrictor kit until I compared the jets to the spare set of carbs I was given when I bought the bike.
It seems like each carb has 2 jets? I'm just guessing by the way! But on the spare set of carbs the holes were the same sizes, on the set that was fitted to the bike the inner jets were smaller.
Having swapped the carbs over, the bike revs all the way through the range and pulls like a train!
I haven't taken it onto a road suitable to test it properly yet (only a quick blast down the Alfreston Road) but it definitely gets above 100mph now! Laughing
The bike is a little lumpy on tickover but I'm hoping to balance the carbs before the end of the week.
At least I won't have to pray hard before trying to over take anything now!
Thanks again for all your suggestions
The last post was made 14 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 91.21 Kb
