Stalls following some maintenance
fatjames
PostPosted: 07:39 - 30 May 2012    Post subject: Stalls following some maintenance Reply with quote
Good morning all,
Following on from my mechanical fun on the weekend I seem to have developed an issue keeping the bike running. First, let me give you some background as to what work I've done.
Work done - I snapped one of the exhaust studs going into the rear elbow. This is yet to be fixed and is only being held one with one of the bolts. There were no gaskets in there, these have been replaced with copper o ring style gaskets.
I've wrapped the exhaust, although this was a few weeks ago and hasn't been an issue.
I changed the oil (10/40) and filter (HiFlo Filtro)
I changed the fuel and air filter.
I checked and adjusted the valve clearances.
And I replaced the spark plugs (and gapped them correctly)
Symptoms - I was riding for about 10 mins, had a chance to get upto about 40, stopped for some lights and as I pulled off the bike spluttered a bit, followed by a loud back fire and then the bike stalled. It started on the button straight away after. This happened a few times, but progressed to happen mid ride.
This happened again after coming down from high speeds on a motorway.
This morning it seemed even worse, the bike was giving me the impression I could save the stall with revs but it just spluttered, dropped to about 5mph and I couldn't bring the revs back up, this time the back fire was so loud I though the engine had blown up! Again, the bike was happy to start again on the button.
Conclusion - I'm hoping its due to air getting into the exhaust at the elbow joint and all can be fixed once my new irwin set arrives?
Does anyone have any ideas? Prior to this, the bike was running fine, except the loud ticking (thought it was the valves)
I've posted this on viragotechforum too, but that site is not quite as busy as here
Thanks all, and sorry for the long post.
FJ
Eddie Hitler
PostPosted: 08:43 - 30 May 2012    Post subject: Reply with quote
Chucking it out there as it has happened to me, exactly the same symptoms but turned out to be a dodgy ignition barrel. Theres a metal plate and 2 screws, it somehow wasn't making contact and the bike stuttered/backfired like mad.
Replaced and worked perfectly. May not be your problem but it had my head scratching for a while, worth a look. Bike was a FZR600.
fatjames
PostPosted: 08:48 - 30 May 2012    Post subject: Reply with quote
Thanks, I'll have a look.
Quote Me Happy
PostPosted: 09:35 - 30 May 2012    Post subject: Reply with quote
Are you sure there were no exhaust gaskets already in there? It can be very hard to tell sometimes but if you carefully pick at them with something like a small screwdriver you can see that they are actually there after all.
fatjames
PostPosted: 09:46 - 30 May 2012    Post subject: Reply with quote
Will that make much difference? If there is, and I remove them, do you think that will solve the problem?
DrDonnyBrago
PostPosted: 09:58 - 30 May 2012    Post subject: Re: Stalls following some maintenance Reply with quote
The old gaskets are probably so caked in old crap that they are impossible to see. I was adamant that mine had no gaskets, they had just got caked in white powdery stuff and blended in with the rest of the head. If (and they almost certainly are) they are still in there then the new gaskets probably wont seal as well. If you are going to be disturbing a lot of hard dusty shite in that area, block up your exhaust ports with some clean tissue to stop bits going in to the engine.
If you have a weak seal and only one stud on one of the downpipes then the leak could throw out the fuelling, you should be able to feel leaking exhaust gases or shut the door and turn off the lights in the garage. Light a cigarette and use a torch to see if the smoke is being blown away by the leaks.
Also check that you haven't knocked one of the carb/throttle body rubbers loose and that the airbox is seated properly. Worth checking that the air filter is in properly too.
TBH I'd put off most of that until the exhaust stud had been sorted properly as it may solve it.
fatjames
PostPosted: 10:06 - 30 May 2012    Post subject: Reply with quote
That's the conclusion I've come to. I can check the breathers/rubbers at the same time.
Thank you (again) for some very helpful advice. lots x Karma
FJ
daemonoid
PostPosted: 10:58 - 30 May 2012    Post subject: Reply with quote
Checked there's no air getting in the carb? The symptoms are very similar to my fiat when I left it at a dodgy mechanic who failed to screw the carb back on properly.
Big air gap between the carb and the top of the engine, lost the throttle adjust bolt too. Exactly the same issues as you've had, but also had low power when cold.
current: ducati monster 750
mysterious_rider
PostPosted: 11:17 - 30 May 2012    Post subject: Reply with quote
Hm my zzr has the worst seal to the head. EVA. Runs alright.... I'd be more inclined to double check the tappets were adjusted correctly.
Good luck with her mate.
fatjames
PostPosted: 11:26 - 30 May 2012    Post subject: Reply with quote
Thanks, although..I was really hoping this wasn't the case! The covers are a real sod to get off, I think I'll try everything else first!
mysterious_rider
PostPosted: 11:32 - 30 May 2012    Post subject: Reply with quote
Out of interest what fuel filter did you use? Are you using the same one that was on there or a different one?
fatjames
PostPosted: 12:31 - 30 May 2012    Post subject: Reply with quote
Looks the same, I got it from Wemoto. It's not branded or anything, just came in a clear packet. It looks like a fat syringe filled with pink highlighter fluid.
mysterious_rider
PostPosted: 12:35 - 30 May 2012    Post subject: Reply with quote
Hm. Well I don't know if you added any tubing (on my gs, I added some tubing to make taking the tank off easier, and added a fuel filter, a small car one) and It caused weird running like what you said. Also when the tank got near reserve it would refuse to run without constant throttle.
Just something else to eliminate. Might be putting stress on the fuel system if it's not fed by a pump.
fatjames
PostPosted: 12:46 - 30 May 2012    Post subject: Reply with quote
It's a good point, the more I can eliminate the better.
Thanks
fatjames
PostPosted: 17:48 - 01 Jun 2012    Post subject: Reply with quote
My conclusion on this was the exhaust. I was really hoping that once that was fixed, everything would be ok again. So I spent most of yesterday extracting the broken stud, replacing the gaskets (there were a some in there under the ones I put in!) and re fitting the exhaust.
This did not fix the issue. The bike is still bogging down and following a loud backfire, stalling.
There is a good spark. No kinks or breaks in the fuel lines, breather cables etc. Loads of fuel. Good battery. etc etc
And ideas?
Thanks
Fatjames
DrDonnyBrago
PostPosted: 19:50 - 01 Jun 2012    Post subject: Reply with quote
Lol, knew the old gaskets would still be there Laughing .
My guess is "still" Wink that the carb/throttle body rubbers have been knocked loose or that the airbox isn't fitted properly.
How confident are you that you did the valve clearances properly?
fatjames
PostPosted: 08:56 - 02 Jun 2012    Post subject: Reply with quote
At the time, very confident. My confidence is somewhat dropping now though.
I think I'll check them again, along with the air box and carb boots etc.
Quote Me Happy
PostPosted: 09:32 - 02 Jun 2012    Post subject: Reply with quote
Did you set them with a stone cold engine on the compression stroke?
fatjames
PostPosted: 12:10 - 02 Jun 2012    Post subject: Reply with quote
I followed Mr Haynes to a tee. Gunna try again though just make sure.
A further development - the bike will start and idle, but as soon as I try and give it some revs it just splutters. However...if the starter is being held down, the bike will rev quite happily..(don't ask how I found that out!
whadyathink?
fatjames
PostPosted: 10:19 - 04 Jun 2012    Post subject: Reply with quote
Just a quick question RE: the valves. The Haynes manual shows 3 markings, 1. T (tdc) 2. F 3. Mark
For the front cylinder, should it be on the mark, or on F?
I assumed F but now have doubts.
FJ
neil.
PostPosted: 11:30 - 04 Jun 2012    Post subject: Reply with quote
Should be on T. F is when the spark happens, just before TDC.
fatjames
PostPosted: 12:47 - 04 Jun 2012    Post subject: Reply with quote
T is for the rear cylinder.
Anyway, I've rechecked the clearances, they were all ok. I've still got issues.
The bike will idle fine, and even rev up with no load, but as soon as I try and move it just bogs down. It feels like it wants to go, but just wont.
Any other ideas before I have to visit a mechanic?
Johnser
PostPosted: 17:26 - 04 Jun 2012    Post subject: Reply with quote
all good suggestions.
quick and painless test - change the spark plugs back to the old ones. its unusual for a plug to be duff out of the box but it'll at least rule it out.
does sound like an air/fuel issue to me. maybe changing the fuel filter dislodged some crap in the lines which is blocking a carb jet.
or maybe the air filter caused a carb rubber to not seal/split?
iooi
PostPosted: 19:20 - 04 Jun 2012    Post subject: Reply with quote
Not pulled the HT leads or damaged them have you ?
Spark plug caps OK?
fatjames
PostPosted: 19:22 - 04 Jun 2012    Post subject: Reply with quote
I'm not sure about this. There are a few joints in the HT leads which seem quite easy to connect/disconnect. Is there a test I can do to check them? Or are they easy(ish) to replace?
The last post was made 14 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 125.32 Kb
