First gearchange is clunky
tbourner
PostPosted: 07:56 - 30 May 2012    Post subject: First gearchange is clunky Reply with quote
I mean the first gearchange of the day, so get on bike and start it, clutch in, gearlever down and the bike lurches forward slightly. If I go into first on the centre stand (with clutch in) the rear wheel just spins.
As soon as I've gone back to neutral it's OK after that, no spinning wheel. I haven't tried stopping and restarting the bike to see if it's a cold oil thing or whatever - not sure what experiments would help to diagnose?
I tried using the rear brake last night when I had spinning wheel on the stand, the bike revs died a bit but the wheel didn't continue spinning afterwards. So it seems like a very initial condition when it happens, then it's fine afterwards.
Trev, now a biker?
Looking for first big bike.
UnknownStuntm...
PostPosted: 08:46 - 30 May 2012    Post subject: Reply with quote
Most bikes I've had a go on seem to do this, first gear drags a tiny bit. So long as your brakes work, there shouldn't be a problem though.
garth
PostPosted: 09:03 - 30 May 2012    Post subject: Reply with quote
Hold the clutch in for a while, and paddle the bike so it's moving before you engage first. Will probably snick in then.
scarecow
PostPosted: 22:18 - 30 May 2012    Post subject: Reply with quote
I had with clutch / 1st gear problems - was down to having a cable that was worn(stretched), and un-lubricated.
You could have a go at oiling the cable, or replacing the cable, and oiling that, or tweaking the bite point out a tiny bit to see what happens.
Karma
GREENI3
PostPosted: 23:04 - 30 May 2012    Post subject: Reply with quote
It's normal.
There's meant to be a 'thunk' when you change down to first after starting the bike from cold.
janner_10
PostPosted: 05:50 - 31 May 2012    Post subject: Reply with quote
Perfectly normal, mine does similar things, even when warm.
cb1rocket
PostPosted: 12:20 - 31 May 2012    Post subject: Reply with quote
Just make sure the clutch cable is properly set up and lubricated Thumbs Up
The last post was made 13 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 50.34 Kb
