EDIT: hmmm Electrical nightmares...
Rncv
PostPosted: 15:10 - 29 May 2012    Post subject: EDIT: hmmm Electrical nightmares... Reply with quote
Hi all,
There was on alaram on my bike (not working) until i cut it out.
Now i have a few problems.....
https://i50.tinypic.com/1dzf7.jpg
this is how i had to leave the bike, I need a Wiring diagram in COLOUR if anyone knows where i can find one? a donation would head their way!
also, Anyone know what this is? the colour wires are different to the alarm (all black) should it be in the loom? i think its the alarm...
https://i50.tinypic.com/2dv3jlv.jpg
https://i47.tinypic.com/23rtjrd.jpg
When i took the alarm out i lost all electrics apart from the headlight, nothing else has power at all..
Any help would be appreciated!
Edit: The bike is a 1999 Honda CB Two-Fifty
Cheers!
Rob.
Current: 01' Bandit 600, 92' Goose 350
Previous: Lots!
Rncv
PostPosted: 09:25 - 30 May 2012    Post subject: Reply with quote
Anyone have any ideas?
Previous: Lots!
fraggie
PostPosted: 09:44 - 30 May 2012    Post subject: Reply with quote
No doubt an electrical problem.
connected to your beams.
check the wiring to see if itś been tampered with, and check the ground connections.
Rncv
PostPosted: 17:19 - 02 Jun 2012    Post subject: Reply with quote
updated post..
Previous: Lots!
bombom
PostPosted: 17:26 - 02 Jun 2012    Post subject: Reply with quote
have a ganders in here for your bikes wiring diagram
https://www.bikechatforums.com/viewtopic.php?t=184540
Current: 97 zx6r f3
Previous: suzuki gsf400 bandit
Rncv
PostPosted: 17:29 - 02 Jun 2012    Post subject: Reply with quote
Had a look already, all i can find is a Nighthawk in black and white Thumbs Down
cheers
Previous: Lots!
Nb
PostPosted: 17:33 - 02 Jun 2012    Post subject: Reply with quote
Not sure if this might help...
https://schematicwiring.com/motorcycle/honda-cb250uk-electrical-wiring-diagram/
Rncv
PostPosted: 17:41 - 02 Jun 2012    Post subject: Reply with quote
Nb wrote:
Saw that one and printed it off, its the wrong colours for the wires unfortantly Thumbs Down
as its been cut around i need to know whats what :/
cheers
Previous: Lots!
U_W v2.0
PostPosted: 18:29 - 02 Jun 2012    Post subject: Reply with quote
i think you need a multimeter lol.
once you get a wiring diagram you will most likely require a multimeter. its an essentail tool in any electrical diagnosis/repair.
if you have power to the headlamp but no where else then theres obviously a break in the line.
you may be able to get certain lights working without the diagram using the multimeter.
i'd get some self amalgamating tape and a multimeter and just strip any tape/trunking off the loom. which you will probably end up having to do anyway and give it a go.
isolate the indicator + wires from the switches and the - from the indicators. do the same for the brake lights. take the + from the switches and the - from the lights and see if you can get the connections made that way.
the engine electrics will be harder will will most likely require the diagram for that.
hoep that helps anyway
edit:
if the looms been heavily tampered with and the wire colours arent as standard, it might actually be easier to get a diagram that states the colours and buy replacement cable in all the colours and just rebuild the entire loom yourself.
Rncv
PostPosted: 18:40 - 02 Jun 2012    Post subject: Reply with quote
edit:
i have a multimeter and self amalg, i need a diagram as there are has been wires cut and joined off to this alarm (which i cut out stupidly) also 2 wires that seem to join as one Confused i will give it another tackle tomorrow evening as see where i get.
Unfortunately its a nightmare trying to get hold of bits for this model of honda Evil or Very Mad
Previous: Lots!
Casper
PostPosted: 19:08 - 02 Jun 2012    Post subject: Reply with quote
Is this it?
https://www.whileyouwereout.net/cb250/cb250-elec-schem.jpg
You should have done one wire at a time. These old alarms are quite crude and tend to just be plumbed in to a cut wire. Something like this
https://i812.photobucket.com/albums/zz43/1888pictures/Untitled-3.jpg
Rncv
PostPosted: 19:26 - 02 Jun 2012    Post subject: Reply with quote
1888 wrote:
Is this it?
i agree that just ripping it all out at once was a stupid idea, i will grab a bunch of connectors and tape/multi meter and tackle it tomorrow evening and then update again to see where im at.
Anyone have any idea whats in the 2nd/3rd pictures?
Previous: Lots!
Nb
PostPosted: 20:26 - 02 Jun 2012    Post subject: Reply with quote
The second and last pictures look like a small alarm siren to me with a keyhole to switch it off.
Casper
PostPosted: 20:58 - 02 Jun 2012    Post subject: Reply with quote
+1
Rncv
PostPosted: 10:48 - 03 Jun 2012    Post subject: Reply with quote
cheers Thumbs Up
Previous: Lots!
The last post was made 13 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.26 - MySQL Queries: 13 - Page Size: 87.06 Kb
