| dextersaurus |
 dextersaurus World Chat Champion
 Posted: 23:18 - 30 May 2012 Post subject: CBR600f electric failure! |
So my CBR died on me a while ago. turned out the battery was on fire due to the reg/rec failing and the battery overcharging.
Anyhoo, i've now replaced the battery and the reg/rec. Key in, ignition on... Neutral, oil and stand lights all came on, horn works, all lights work etc.
Went to press the starter button and.... nothing. Not even a click. It's like the button isn't connected. I tried to bump it but never got anything.
The engine cranks when i bridge the starter solenoid, but doesn't want to start. I've checked the spark and there isn't one.
The carbs were recently cleaned along with the plugs changed, and it was running perfectly before the thing died, so compression is fine, i'm just missing the bloody spark.
So - The fuses are fine, lights etc work, engine cranks when the solenoid is bridged, doesn't want to fire.
What else should i be checking? I'm guessing a replacement solenoid may sort it, but don't want to waste my money if it's something else.
Cheers |
| Casper |
 Casper World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 06:20 - 31 May 2012 Post subject: |
No spark and no crank = duff alarm/immobiliser. ____________________ a.k.a 'Geri'
| mab |
 mab Nitrous Nuisance
| dextersaurus |
 Posted: 15:50 - 31 May 2012 Post subject: |
Think rolf may have it.
It's not got an immobiliser, it's a '92.
And it won't start in any case, yes, i'm not that silly  |
| mab |
 Posted: 18:48 - 31 May 2012 Post subject: |
Checked your fuses? specially the 30A one, under the seat by the battery
edit: never mind. Just re-read your post
Edit 2: Have you double checked all your connectors? |
| MaybeGuy |
 MaybeGuy Super Spammer
| dextersaurus |
| Casper |
| dextersaurus |
| Casper |
| dextersaurus |
| Casper |
| Pete. |
 Pete. Super Spammer
 Posted: 14:25 - 03 Jun 2012 Post subject: |
| Mr Dunkable wrote: | Right, bike is now stripped and i'm looking through the wires. have the coils off and plugs out, and they're coming out wet, and i dont have a spark.
I've checked the wires as much as i can without a multimeter and they don't look burnt out or anything, but i'm obviously stuck without one at the moment.
Also re-checked all the fuses. The ones in the fusebox are all fine, as is the one on the solenoid.
Cleaned up the earths just in case, but no change.
What's the next step, other than checking the wires with a multimeter? (R/W wire goes from the solenoid to the reg/rec, so i'm checking continuity between those two points, right?)
Dunc |
Your bike a F3, with 2 coils? If so, the black wire from fuse 2 feeds the stop switch which feeds the starter switch and coils via a black/white wire. If your run switch is on and you have no power to the black/white coil wires, then pull fuse 2 and check for power both sides, one side should be live. It should be live because it's on the same feed as fuse 3 which puts the lights on as you say.
If you have power at fuse 2 but not at the coils then either the fuse is broken or the run switch faulty. ____________________ a.k.a 'Geri'
| dextersaurus |
| dextersaurus |
 Posted: 17:47 - 03 Jun 2012 Post subject: |
| Pete. wrote: | | Mr Dunkable wrote: | Right, bike is now stripped and i'm looking through the wires. have the coils off and plugs out, and they're coming out wet, and i dont have a spark.
Dunc |
If you have power at fuse 2 but not at the coils then either the fuse is broken or the run switch faulty. |
Checked the things you've mentioned.
With ignition on, the terminal for the fuse is live on one side as it should be, but there's nothing to the coil wires.
I've checked continuity between the starter switch and the kill switch though, and there is something there on both points when it's at 'run', and only 1 when it's at 'stop', which is normal.
Gonna trace the coil wires and see what i can find that way, because from the above, i'm pretty sure the switch is fine.
The bike normally turns over whether the kill switch is on or off. All it does is kill the spark.
The bike isn't turning over at all. All wires i've looked at so far are absolutely fine, other than the coil wires...
Any ideas? |
| dextersaurus |
 Posted: 18:26 - 03 Jun 2012 Post subject: |
Right. looked through this a bit.
Managed to find an F2 wiring diagram, and it's quite different.
going from the wires coming from the kill/starter switch - as everything but the coils seem to be getting power.
Black/white - goes to the ICM and coils.
Black/brown - goes to the lights, temp gauge, fuse 3, brake light switch and indicator relay
Black- goes to fuse 2, starter and kill switch.
Now all these wires are fine, everything that should have power, has power, but the only thing i'm missing now is power to the coils.
Red wire is live with ignition on, red/white wire is also live with ignition on. still no change in anything despite checking the connections.
I think there's something wrong with the ICM going from this
Anyone that can shed some light on this, it'd be a great help.
Edit: also got a connection between the black/white wire going INTO the ICM and the coils&switches. |
| Casper |
| dextersaurus |
| Casper |
| dextersaurus |
| Pete. |
 Pete. Super Spammer
 Posted: 20:38 - 03 Jun 2012 Post subject: |
I tried to look at that schematic but TBH it's so poor it's making me feel ill. ____________________ a.k.a 'Geri'
| dextersaurus |
| dextersaurus |
| dextersaurus |
The last post was made 13 years, 208 days ago. Instead of replying here, would creating a new thread be more useful? |
